POV-Ray : Newsgroups : povray.general : Internal Nesting Limit Server Time
17 Apr 2026 13:40:41 EDT (-0400)
  Internal Nesting Limit (Message 1 to 10 of 20)
Subject: Internal Nesting Limit
Date: 2 Apr 2014 02:50:01
Message: <web.533bb22160a99e42effb1f90@news.povray.org>
I know this issue has frequently been discussed, but I would like to understand
the reason with the goal, to adjust my scene:
In a scene with many transparent objects with emitting media such as:
sphere{P, r pigment{rgbt 1} hollow no_shadow interior{media{emission rgb 1}}}
rendering stops with the message:
Internal limit exceeded in FixedSimpleVector
Fatal error in renderer: A POV-Ray internal nesting limit was reached.
Render failed
if
1) the number of objects exceeds a certain number
2) the objects come close to each other and overlap
Changing bounding on/off or max_trace_level does not help.
Is there anything I can do?
Thank you!
Subject: Re: Internal Nesting Limit
Date: 3 Apr 2014 05:38:34
Message: <533d2c1a$1@news.povray.org>
Le 02/04/2014 08:45, Sereib a écrit :
> Hi,
> Render failed
> if
Nope, not directly. But the number of media might.
Neither.
Without seeing your code, it's difficult to say.
The limit is inherited from old code (that used static C array in
structure). When the conversion was done, I guess the single allocation
aspect was kept for simplicity of handling failure (and speed!)
(allocate the whole array on first element). It has been tagged to be
corrected... later.
Workaround: If you are compiling your own povray, you can raise the
values which sizes the various FixedSimpleVector:
* LIGHTSOURCE_VECTOR_SIZE
* MEDIA_VECTOR_SIZE
* MEDIA_INTERVAL_VECTOR_SIZE
* LIT_INTERVAL_VECTOR_SIZE
* LIGHT_INTERSECTION_VECTOR_SIZE
* RAYINTERIOR_VECTOR_SIZE
* WEIGHTEDTEXTURE_VECTOR_SIZE
Just because nobody complains does not mean all parachutes are perfect.
Date: 3 Apr 2014 07:35:00
Message: <web.533d46bfc1f5941aa69b8e140@news.povray.org>
thank you!
However, I can confirm 2)
In one scene, I have approx. 5000 spheres (hollow, with emitting media in the
interior statement) which - as "photons" travel through a lens system depicting
how light diffraction works. If these photons come closer and closer and finally
many of them overlap in the focus, the error occurs.
My work-around is to lower the number of "photons" (the emitting spheres) in my
animation for the frames when they come close together, which pretty works.
I observed this overlap-effect in several different scenes, so are you sure this
error has nothing to do with it?
> > Hi,
> > Render failed
> > if
> Neither.
> corrected... later.
> * MEDIA_VECTOR_SIZE
Date: 3 Apr 2014 18:25:00
Message: <web.533ddf25c1f5941ac2d977c20@news.povray.org>
> Render failed
I don't know if this will help, but have you tried upping the
'max_intersections' value in your global_settings{} block? By default, it is 64.
(Admittedly, I don't know the technical aspects of what it does; but changing it
might be worth a try.)
Date: 4 Apr 2014 02:44:09
Message: <533e54b9$1@news.povray.org>
> Render failed
> if
Try to minimise your scene as much as possible whilst it still produces
the error, then post the code here.
Date: 4 Apr 2014 07:15:00
Message: <web.533e932dc1f5941a1dc1864b0@news.povray.org>
here we go:
global_settings {assumed_gamma 1.5  max_trace_level 5}
#declare rnd1=seed(1);
#declare n=900;
#declare r1=1;
#declare r2=5;
#declare k=1; #while(k<=n)
    #declare P=<rand(rnd1)-0.5,rand(rnd1)-0.5,0>*r2;
    sphere{<0,0,0>,r1 pigment{rgbt 1} hollow no_shadow interior{media{emission
1/r1}} translate P}
#declare k=k+1; #end
camera{location<0,0,-5*r2> look_at<0,0,0>}
As you see, n is the number of spheres, r1 their radius, and r2 the edge length
of the box which contains all spheres.
If I set r2 = 2 the error occurs, but for r2 = 5 (and otherwise same values)
rendering works.
Maybe this helps?
Date: 4 Apr 2014 08:35:58
Message: <533ea72e$1@news.povray.org>
> #declare n=900;
> #declare r1=1;
> #declare r2=5;
> 1/r1}} translate P}
> rendering works.
I have tried your code, without the media statement no error occurs,
even if r2=2. Maybe the stuff is here.
Lionel.
Do not judge my words, judge my actions.
http://www.avast.com
Date: 4 Apr 2014 09:30:00
Message: <web.533eb38ac1f5941a1dc1864b0@news.povray.org>
o.K. ... I have version 3.7 - you too?
> Lionel.
Date: 4 Apr 2014 10:01:23
Message: <533ebb33$1@news.povray.org>
> Hi,
Woouhh...
I have tested your code (with media and r2=2) with v3.6, all works.
But the problem occurs with v3.7. Maybe some changes between the versions...
Date: 4 Apr 2014 15:44:21
Message: <533f0b95@news.povray.org>
>> Render failed
I don't think that it'll work in this case.
If the value is to low, you get an "I-Stack Overflows" message in the
statistics after the scene is rendered.
It's normaly a non-fatal error, and may be more similar to a
max_gradiant error. The scene renders, but not correctly.
