POV-Ray : Newsgroups : povray.general : nasty issues rendering extremely large objects Server Time
17 Mar 2026 18:06:44 EDT (-0400)
  nasty issues rendering extremely large objects (Message 1 to 8 of 8)
Subject: nasty issues rendering extremely large objects
Date: 14 Oct 2010 14:05:00
Message: <web.4cb744c091bc326e7411a7fb0@news.povray.org>
I'm trying to render the Ringworld, from the perspective of someone standing on
it.
http://en.wikipedia.org/wiki/Ringworld#Ringworld_engineering
But I'm running into all sorts of trouble. Here's an initial attempt, using the
metric system for all distances:
http://pastebin.com/raw.php?i=4Cib1tiy
Command-line is:
povray torus.pov +P +W1200 +H675 -visual DirectColor
This is the result:
http://i.imgur.com/N3Hav.png
The distant end is cut off and the near portion is not rendered at all.
I changed from meters to kilometers (all the #declare numbers are 1000x
smaller), and this is the result:
http://i.imgur.com/fxZ7K.png
The far end is better but the near portion is still clipped. So I moved the
subject a lot higher: instead of 2 m, let's put the subject at 2 km:
http://i.imgur.com/WfyWz.png
Better, but there's still weird clipping. So I put the subject at 2000 km above
the Ringworld:
http://i.imgur.com/05s36.png
Okay, so this looks correct, but it's not what I want; it's not the Ringworld as
seen from someone standing on it (as opposed to flying a spaceship at 2000 km
above it).
It looks like I'm running into issues with math precision. Any suggestions?
Subject: Re: nasty issues rendering extremely large objects
Date: 14 Oct 2010 14:50:01
Message: <web.4cb74fde4bd3fcf47411a7fb0@news.povray.org>
Here's a perspective view from afar, all numbers are scaled down so I don't run
into issues again, but the proportions are correct:
http://i.imgur.com/mHknm.png
That tiny thing in the middle is the Sun. :)
http://pastebin.com/raw.php?i=Ht2J3p5E
povray scale.pov +P +W1200 +H675 -visual DirectColor +A0.1 +AM2
Now, if I could only zoom in and "land" the camera on the inside of the ring and
render it correctly, at scale, from the perspective of someone standing on the
ring, without clipping or math issues, that would be great.
Date: 14 Oct 2010 15:03:37
Message: <4cb75409$1@news.povray.org>
I think the problem is not the magnitude but the precision. POV-Ray uses
floats internally, so trying to model something 200 million kilometers apart
with a detail scale of 1 meter isn't going to work so well.  Plus, there are
bits in the code to clip sufficiently distant geometry that I'm sure someone
else can tell you about. I don't think you're going to be able to model this
in a simple and naive way. You'll need to do something less obvious, like
having different models at different points in the animation.
(Note that "naive" isn't a pejorative term here.)
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 14 Oct 2010 15:15:01
Message: <web.4cb7562e4bd3fcf47411a7fb0@news.povray.org>
I think my message was misleading - when I said "zoom in" I wasn't thinking of
doing an animation. I'm only interested in the final static view, standing on
the surface of the ring.
It does seem to be some sort of precision limit or error, indeed.
Date: 14 Oct 2010 15:50:00
Message: <web.4cb75e3e4bd3fcf49832b76e0@news.povray.org>
I'm afraid there's not much you can do about it... for what it's worth, the view
seen by an observer 2m above the ring floor isn't really any different from a
view from 1000m above the ring floor.
For more detailed discussion and much rambling on the subject, see also these
threads:
http://news.povray.org/povray.binaries.images/thread/%3C436404f3$1@news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C4c14c7d2%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C4c234991@news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3Cweb.4c1fd41611a7b4754f28787e0@news.povray.org%3E/
Bill
Date: 14 Oct 2010 15:58:01
Message: <4cb760c9$1@news.povray.org>
Le 14/10/2010 21:12, Florin Andrei nous fit lire :
I should try... but I noticed that you used a single cylinder in your
scene. Does it change anything if you use instead a CSG of 2 cylinders,
so that the actual ring is more than a foil ?
(in fact, you would need more to make the walls)
Given the usual range & precision, I wonder if one unit = 100km would
not be better ?
(that make the view point about 0.00002 away)
Also a caveat: if the <0,0,0> is the sun, you gonna have problem to
stand on the ring.
You might better enjoy having your feet as <0,0,0>, translating your
ring to match.
And I never get the "artificial gravity" by rotating: centrifugal force
does not exist (it's a pseudo force), and I believe the gravity
direction might not be fully centrifugal: the coriolis effect would
slant it a bit away from the center
Date: 14 Oct 2010 17:44:08
Message: <4cb779a8$1@news.povray.org>
> not be better ?
I think the problem is not so much the absolute size in units as it is the
difference between the smallest object and the biggest object.
If you only have six decimal digits of precision in your float, you're not
going to be able to represent the difference between
   1.23456789012345 and
   1.23456789012348
any more than you will if you make them
   1.23456789012345E+10 and
   1.23456789012348E+10
It certainly exists. It just only exists for an accelerated observer.
> the coriolis effect would slant it a bit away from the center
Yes, but that's true because the ringworld is rotating, not because of
centrifugal force. The earth has corilois effects too.
   Serving Suggestion:
Date: 14 Oct 2010 19:42:35
Message: <4cb7956b$1@news.povray.org>
It is a floating point precision limit. To render that corectly, you'd
need quad- or higher precision, but your FPU is limited to double.
Others have used a plane to replace the missing fore ground part.
> Given the usual range&  precision, I wonder if one unit = 100km would
> not be better ?
> Also a caveat: if the<0,0,0>  is the sun, you gonna have problem to
> stand on the ring.
> You might better enjoy having your feet as<0,0,0>, translating your
> ring to match.
The problem is not the absolute value given to an unit, it's de range
between the largest values and the smaller ones used.
The effective gravity of the Ring world on the surface is exactly zero,
but the sun's gravity is not and tend to pull everything UP. The
perceived gravity comes from it's rotation and the "centrifugal" force
must overcome the sun's gravity.
Now, centrifugal force in a perceived force relative to an object moving
on a circular path.
The coriolis effect is minuscule here on earth and only works at large
scale over periods of many hours and days, it is not effective under the
tropics, and is maximum at the poles.
On the ring world, given the dimentions and the relative thickness of
the athmosphere, it would be absolutely negligeable, and would only
cause cylindrical systems parallel to the ground. It would have
absolutely NO effect on gravity.
What CAN affect the direction of gravity is Relativity and the time
gravity take to come from the sun compared to the ring's rotation. That
exact same effect will also slightly shift the apparent sun's position
away from perfectly over you.
Given the scale and proportions, it's very acurate to represent the Ring
world as the surface of an open cylinder. At less than a Km thickness
compared to over 100 000 000Km radius, there is practicaly no diference.
