POV-Ray : Newsgroups : povray.general : povray generating "seg fixup" messages Server Time
28 Sep 2024 23:26:36 EDT (-0400)
  povray generating "seg fixup" messages (Message 1 to 10 of 12)
Subject: povray generating "seg fixup" messages
Date: 28 Jan 2009 18:20:01
Message: <web.4980e8139639d3d359eba08c0@news.povray.org>
I've been noticing message of this sort in my /var/log/messages:
kernel: 4gb seg fixup, process povray (pid 1501), cs:ip 73:00962939
I've no idea what that is and if I should be worried at all. Does anybody have
an idea?
I was a bit concerned since there was the "kernel" involved! Perhaps it is not
even a povray issue but I'm just falling back to "guilt by association"!
Rahul
Subject: Re: povray generating "seg fixup" messages
Date: 28 Jan 2009 21:21:53
Message: <498112c1$1@news.povray.org>
Rahul nous illumina en ce 2009-01-28 18:19 -->
> an idea?
> Rahul
Just a wild guess here.
I think that it may be related to some memory paging that may be happening while
POV-Ray is running. Memory paging causes a great many "page faults" when a bit
of instructions or data that need to be accessed have been pushed to the swap
file, and thus, need to get fetched back into RAM.
Sometimes my love of the arcane combines with my askew humor to make me
unintelligible!!
Date: 29 Jan 2009 00:05:01
Message: <web.498138a489001439d52c367a0@news.povray.org>
Another equally wild guess: 32 bit code on a 64 bit machine?
Date: 29 Jan 2009 19:20:00
Message: <web.498247a98900143959eba08c0@news.povray.org>
Very reasonable guess. Thank you. We've been switching our servers slowly from
32bit to 64bit.
How can I test though! Because I am getting this header. Any other way to test
if this is a 32 or 64 bit executable?
/usr/local/bin//povray -v
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 3.4.1 @
 i686-pc-linux-gnu)
This is an official version prepared by the POV-Ray Team. See the
 documentation on how to contact the authors or visit us on the
 internet at http://www.povray.org/.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd.
Primary POV-Ray 3.5/3.6 Developers: (Alphabetically)
  Chris Cason         Thorsten Froehlich  Nathan Kopp         Ron Parker
Contributing Authors: (Alphabetically)
  Steve Anger         Eric Barish         Dieter Bayer        Steve A. Bennett
  David K. Buck       Nicolas Calimet     Aaron A. Collins    Chris Dailey
  Steve Demlow        Andreas Dilger      Alexander Enzmann   Dan Farmer
  Mark Gordon         Christoph Hormann   Mike Hough          Chris Huff
  Kari Kivisalo       Lutz Kretzschmar    Jochen Lippert      Pascal Massimino
  Jim McElhiney       Douglas Muir        Juha Nieminen       Bill Pulver
  Eduard Schwan       Wlodzimierz Skiba   Robert Skinner      Yvo Smellenbergh
  Zsolt Szalavari     Scott Taylor        Massimo Valentini   Timothy Wegner
  Drew Wells          Chris Young
Other contributors are listed in the documentation.
Support libraries used by POV-Ray:
  ZLib 1.2.1, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
  LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
  LibJPEG 6b, Copyright 1998 Thomas G. Lane
  LibTIFF 3.6.1, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Date: 30 Jan 2009 07:40:16
Message: <4982f530$1@news.povray.org>
>  i686-pc-linux-gnu)
	That's very likely a 32-bit exe.  You might try "file /usr/local/bin/povray"
to know it for sure.
	- NC
Date: 30 Jan 2009 11:25:00
Message: <web.4983296f89001439bdc576310@news.povray.org>
>  i686-pc-linux-gnu)
The "i686" in the "i686-pc-linux-gnu" platform string is the key: It tells you
that the binary is compatible with "i686" processors - which is an unofficial
but common alias for the Intel Pentium II (following Intel's pre-Pentium era
designations for x86-compatible CPUs) - obviously a 32-bit processor.
In case of a 64-bit executable, the platform string would instead read something
like "ia64-pc-linux-gnu", or "amd64-pc-linux-gnu".
Date: 30 Jan 2009 12:55:00
Message: <web.49833e1d8900143959eba08c0@news.povray.org>
Hmm...so I do have a 32 bit executable on a 32 bit machine. I'm not sure why I
am getting those errors then. 32-vs-64 bit must have been a red herring for me.
ANy other ideas?
/usr/local/bin/povray: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV),
for GNU/Linux 2.2.0, statically linked, for GNU/Linux 2.2.0, stripped
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 15
model           : 2
model name      : Intel(R) Xeon(TM) CPU 2.80GHz
stepping        : 9
cpu MHz         : 2790.776
cache size      : 512 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 2
wp              : yes
flags           : fpu tsc msr pae mce cx8 apic mtrr mca cmov pat pse36 clflush
dts acpi mmx fxsr sse sse2 ss ht tm pbe cid xtpr
bogomips        : 6982.48
processor       : 1
cpu family      : 15
model           : 2
stepping        : 9
cpu MHz         : 2790.776
cache size      : 512 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : no
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 2
wp              : yes
dts acpi mmx fxsr sse sse2 ss ht tm pbe up cid xtpr
bogomips        : 6982.48
Rahul
Date: 30 Jan 2009 14:00:00
Message: <web.49834d1189001439bdc576310@news.povray.org>
> have an idea?
Do you happen to be running Xen?
I just did a quick google for "4gb seg fixup" and found zillions of entries, all
related to Xen as it seems - the quintessence of the articles being that the
severity of the messages probably ranges from cosmetic to a performance issue
(depending on how frequent they appear), that it affects various different
programs running under Xen, and that you need to replace a certain library with
a "Xen-friendly" version to get rid of this (details are mentioned in most all
the googled articles).
Date: 30 Jan 2009 14:55:01
Message: <web.49835a758900143959eba08c0@news.povray.org>
No. No Xen. Its a raw server. No virtualization at all.
Ah! I guess I always searched for povray+"4gb seg fixup"  and so never came
across those entries. I'll see if I can somehow relate them to my problems.
My errors seem pretty often too. Almost for every povray invocation.
Rahul
Date: 30 Jan 2009 15:55:00
Message: <web.4983690189001439bd1ceb910@news.povray.org>
Well, those poor Xen victims talk about up to, like, 40 messages a second, so
consider yourself lucky ;)
