POV-Ray : Newsgroups : povray.general : 64 or 32.. what to do, what to do? Server Time
25 Feb 2025 10:43:23 EST (-0500)
  64 or 32.. what to do, what to do? (Message 1 to 10 of 31)
Subject: 64 or 32.. what to do, what to do?
Date: 27 Mar 2008 12:20:00
Message: <web.47ebd5e5326bcb2f5a8888d90@news.povray.org>
First, a moment of silence...
My ancient AMD K6 machine, which lived as a Win95, Win98 and Win2k machine has
finally expired.  It has run down the curtain and joined the Choir Invisible.
It is an ex-workstation.
Well.. I'd better replace it then.
As I type, a replacement is being built for me. It's a pretty decent mid-level
machine: AMD Athlon Dual 64 +6000, 2GB ram, 160GB HD, GeForce 8600 video (not
the best, but budget restrictions applied).  Having heard that problems exist
with Windows XP Pro 64 bit in regard to various programs not working properly
and drivers for various devices not being available... AND needing my
replacement machine today, I'm having Win XP Pro 32 bit installed.  I can
later, if I choose, have the system converted to a dual boot system with the
option of starting in 32 or 64 for approximately an additional $200.00 USD.
The question: Is it worth it?
The MAIN reason for doing this would be to run 64 bit POV-Ray. How much does one
really gain by running the 64 bit version.  Are there any other graphics or
modeling applications that would benefit in any serious way?  How bad ARE the
software and driver problems with XP Pro 64?
(This probably goes without saying, but I have NO intention of going with
Vista.)
Thanks in advance for all replies.
Best Regards,
Mike C.
P.S. All my POV-Ray code files are safely stored on removable media. :-)
Subject: Re: 64 or 32.. what to do, what to do?
Date: 27 Mar 2008 13:21:46
Message: <47ebe5ba@news.povray.org>
Mike the Elder wrote:
> I can
Let me throw out another idea for you to consider: Make the 64-bit OS Linux.
You've already stated that Povray is the only real reason for the 64-bit
OS, and Povray is quite happy on Linux. 64-bit Linux has also been
around a bit longer than 64-bit Windows, and has had a chance to mature
a bit. ;-)
That said, I'm a Linux fanboy (I'm pounding this out under 32-bit Linux)
and I haven't had the money to shell out for a 64-bit processor, so I
can't tell you whether or not the performance difference is worthwhile.
William Tracy
Stacey's dad!
Took it pretty bad.
I'm afraid of Stacey's dad.
Stacey can't you see?
I really need to flee.
Date: 27 Mar 2008 13:45:00
Message: <web.47ebea1fba444f305a8888d90@news.povray.org>
> > I can
Actually, I like the idea. I've wanted to learn more about Linux for a while
now.
Can the Linux 64 and XP-Pro 32 live happily on the same machine? (I can't afford
a second machine right now.) ... a second partition? ... a second hard drive?
(As much as I would be "proud to be Micro$oft free", I'm in the middle of too
many Windows based projects to do a cold turkey switch.)
Thanks,
Mike C.
Date: 27 Mar 2008 13:56:18
Message: <47ebedd1@news.povray.org>
>> > I can
>> > with the option of starting in 32 or 64 for approximately an additional
>> > $200.00 USD.
>> Linux.
> while now.
> afford a second machine right now.) ... a second partition? ... a second
> hard drive?
You can do either, Linux is happy living on a second partition or second
hardrive. And once you install Linux it will create the boot menu for you
so at boot you can select which way you want to go.
I'm running 64bit Suse Linux for quite some time now on an AMD DX2 and
haven't had any trouble with it other then me messing it up with test
stuff.
Povray on 64bit gives some speed increase but don't expect wonders. What it
does do however is give you limitless memory. I have run renders upto 20GB
memory use.
> too many Windows based projects to do a cold turkey switch.)
> Thanks,
> Mike C.
For the "MS free" bit you could check out Wine, which is a Windows emulator
on Linux. Works pretty well but does not replace Windows completely.
Ger
Date: 27 Mar 2008 13:57:14
Message: <47ebee0a$1@news.povray.org>
> Linux.
I'd second that. Use 64-bit Linux for rendering, and if you have to have
Windows, then install 32-bit Windows.
Jim
Date: 27 Mar 2008 13:57:49
Message: <47ebee2d$1@news.povray.org>
> can't afford a second machine right now.) ... a second partition? ... a
> second hard drive?
You bet, any of these options.
I have 32-bit Vista (barf) and 64-bit OpenSUSE installed on the same
machine.  They coexist just fine.
Jim
Date: 27 Mar 2008 14:16:52
Message: <47ebf2a3@news.povray.org>
> memory use.
  Also file sizes become unlimited.
Date: 27 Mar 2008 14:18:53
Message: <47ebf31d@news.povray.org>
> now.
   I can recommend that: learning is always a Good Thing.
  AFAIK, there is no reason to think that they will interfere with each
other. Indeed a second hard drive could be easier to manage at install time
than partitions. The only problem I could think about is sharing files
between XP and Linux: I didn't check recently, but I remember the NTFS
support on Linux was read-only when I tried some years ago.
   That's understandable... back on the early 90's I had dual boot for some
years until I decided to format the W98 partition.
   Good luck with it in any case... and my condolences for the deceased
machine.
Jaime
Date: 27 Mar 2008 14:21:27
Message: <47ebf3b7$1@news.povray.org>
> on Linux.
WINE acronym stands for Wine Is Not an Emulator.
Date: 27 Mar 2008 15:05:00
Message: <web.47ebfd93ba444f305a8888d90@news.povray.org>
Many thanks to all.
My next investment is going to be a second hard drive from which to boot 64 bit
Linux.
Best Regards,
Mike C.
