![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm trying to come up with a landscape for a scene I'm working on, but I can't
seem to come up with anything suitable. I've tried Terragen, World Machine,
and several other programs.
I have rather specific needs for my landscape, so, obviously, the best solution
would be to draw it myself, but I have no Idea how.
I would appreciate it if someone could point me in the direction of a tutorial
of some sort.
ADB
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Anthony
you may give TerrainMaker a try,
it's a quite old program (DOS-Vesa) but don't be scared off that
i used it to 'draw' landscapes in the old days...
http://www.ericjorgensen.com/html/tm.htm
Regards
Joerg
> of some sort.
> Regards,
> ADB
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You can use a rough manually drawn height field as an input to
World Machine and then smooth it and layer some random stuff on
to make it look more real as in
http://news.povray.org/povray.binaries.images/thread/%3C463bbad2%40news.povray.org%3E/?mtop=3
The input file was a simple low resolution b/w image, don't remember
what program I used to create it, might even have been Paint although
I'm not sure if it can write a grayscale format directly readable by
World Machine. Gimp will be fine, though.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> of some sort.
I know what you mean. I downloaded a lot of programs to make height
feilds and never did get one I liked.
So... I made my own.
If you have windows 98 or better I have programs that make and modify
height feilds. They are at:
http://leroywhetstone.s5.com/Win_Programs.html
The height feild maker uses contour lines as a map. It gives you great
control of the lay of the land.
I also have a program that modify height feild tgas.
Hope this helps!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I haven't used it, but Geomorph looks very interesting:
http://geomorph.sourceforge.net/
It's specifically designed for "painting" your own heightfields.
However, it seems to be pretty much Linux-only (with a FreeBSD port). As
a Linux nut, that makes me a little happier than it really should. :-)
William Tracy
afi### [at] gmail com -- wtr### [at] calpoly edu
You know you've been raytracing too long when every computer upgrade you
have made in the past three years has been to accommodate more complex
images.
-- Aaron Gage a.k.a Slartibartfast
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> can't
>> Machine, and several other programs.
Very nice, been thinking about writing something like that but I guess I
don't need to now.
Don't feel too bad about it. Linux-only here too :)
Ger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > As a Linux nut, that makes me a little happier than it really should. :-)
hey! we're mates! and I know Jaime Vives Piqueres is onboard too! :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
