POV-Ray : Newsgroups : povray.general : Help with light! Server Time
14 Jan 2026 03:51:36 EST (-0500)
  Help with light! (Message 1 to 6 of 6)
Subject: Help with light!
Date: 17 Apr 2006 11:15:01
Message: <web.4443afe8538e3be258dbbb6b0@news.povray.org>
HI!
I'm trying to create a little omnidirectional light only for closer objects
and I try with:
light_source {< 0, 0,  0> color White
   fade_distance 0 fade_power 0
   area_light <0.1, 0, 0>, <0, 0, 0.1>, 3, 3
but this light up all the objects in the scene!!
Subject: Re: Help with light!
Date: 17 Apr 2006 12:00:00
Message: <web.4443ba6eb5d5925e6c4803960@news.povray.org>
"danyolgiax" <d.o### [at] gmailcom> wrote:
> HI!
> and I try with:
You want either spotlights or cylindrical lights (most likely sptolights,
see: 3.4.7.2  Spotlights in the docs). Area lights are essentially just an
array of point lights so are not omni directional (unless you build a shade
around them, which is another option, depending on your needs)
-tgq
Date: 17 Apr 2006 12:03:39
Message: <4443bc5b$1@news.povray.org>
news:web.4443afe8538e3be258dbbb6b0@news.povray.org...
> HI!
objects
> and I try with:
The more realistic setting (for a close light) for fade_power is 2 (i.e.
fading with the square of distance)
fade_distance depends on the scale of your scene but I still let it at
default value
Marc
Date: 17 Apr 2006 12:40:17
Message: <4443c4f1@news.povray.org>
  Well, fade_power 0 means that the light doesn't fade. Logical.
Date: 17 Apr 2006 15:33:25
Message: <4443ed85$1@news.povray.org>
danyolgiax nous apporta ses lumieres en ce 17/04/2006 11:10:
> HI!
> and I try with:
fade_power 0 means NO fading. It's the default value.
fade_distance 0 don't make any sense. Try a small to very small,but non-zero, value.
Best bet: fade_power 2 fade_distance 0.1 (or less) and increase the brightness of the
light as much
as needed, like 100 to 10000.
You can use a fade_power larger than 2, like 3 or 4 or even more.
You can also use a light_group where you link the closer objects with your light. Add
"global_lights
on" if you want it to also be lighted by other light.
Christian Science: Shit happening is all in your mind.
Date: 17 Apr 2006 16:40:01
Message: <web.4443fbdbb5d5925e6c4803960@news.povray.org>
> > HI!
> > and I try with:
> -tgq
oops, I think I misread everything here (and mixed up my omni/uni
directionals) ignore my comments!
As the others said play with fade_distance/fade_power and/or light groups.
See "3.4.7.9  Light Fading" and have a look at the function and how the the
variables affect the fading response.
-tgq
