POV-Ray : Newsgroups : povray.general : Wouldn't it be nice: patterns and finish items Server Time
30 Sep 2024 15:21:51 EDT (-0400)
  Wouldn't it be nice: patterns and finish items (Message 1 to 5 of 5)
Subject: Wouldn't it be nice: patterns and finish items
Date: 28 Feb 2006 10:35:00
Message: <web.44046cb3d1350a4f9bdecb60@news.povray.org>
Hello altogether!
I was wondering if it could be possible in any future version to use
functions and patterns in the finish block. If so there would be much more
flexibility in creating stunning material appearances. Other than that
already supported image- and bump maps one could then in particular make
use of ambient-, specular- and diffuse maps that come along with many
texture packs and add a lot to the quality of the appearance of an surface.
There is already the possibility to work around that by layering two
textures with appropriate (e.g.) reflection values on top of each other
where the upper one uses the appropriate map as an alpha channel. But this
gets ugly when several maps are being used and slows down the render and
parsing time.
What do you think?
Regards Roman
Subject: Re: Wouldn't it be nice: patterns and finish items
Date: 28 Feb 2006 17:26:13
Message: <4404ce05$1@news.povray.org>
Roman Reiner wrote:
> Hello altogether!
> parsing time.
> What do you think?
While normals and pigments can be represented with a short vector
(pigments have 5 values, normals have three), finish statements involve
a larger number of data (ambient, diffuse, phong (and its associated
specs), specular (with roughness), brightness, metallic, etc).  That
shouldn't be a show-stopper from a programming viewpoint.
Maybe this is planned for V4,maybe not.
Of course, if you download the latest sources and code up a working
version, I'm sure the development team will at least read it.
John
Date: 28 Feb 2006 18:20:01
Message: <web.4404d936783b11fa9bdecb60@news.povray.org>
> Regards,
> John
Sure. I thought of a pattern definition for those finish items not for the
whole finish block. apart from reflection and irid all those items are
defined by only one single float or vector. i thought for example of
something like
finish {
  reflection {
    wrinkles
    reflection_map {
instead of just a float value.
i'm not very well versed in povray programming but i guess this should not
be very difficult or even impossible. do you think it would be worth the
effort?
Regards Roman
Date: 28 Feb 2006 21:18:48
Message: <pan.2006.03.01.02.18.37.617936@speakeasy.net>
On Tue, 28 Feb 2006 10:31:11 -0500, Roman Reiner wrote:
> Hello altogether!
> parsing time.
> What do you think?
> Regards Roman
Not sure if this could be extended to your purpose, but maybe. It's based
on something Giles Tran posted to a message from Mael about Finish Maps.
I'll post the resulting image in povray.binary.images just for reference.
I'm also going to play with this more to see if it's actually useful in a
general sense.
-ross
// just some pigment to be used in a function
#declare p0 = pigment {
  granite
  scale 5
  color_map {
    [0.0 rgb 1]
    [0.45 rgb 1]
    [0.5 rgb .1]
    [0.8 rgb 0]
    [1.0 rgb 0]
  #declare w1 = 5;
  #declare t1 = <0.3, 0.3, 1*clock>;
  #while (w1 > 0)
    warp {repeat x flip y}
    warp {turbulence t1}
    scale 0.99
    #declare w1 = w1 - 1;
#declare f0 = function {pigment {p0}};
sphere {
  0.0, 1
    function {f0(x,y,z).x}
    texture_map {
      [0 pigment {rgb 1} finish {ambient 0 diffuse 0.4 specular 0 roughness 0.00
reflection 0}]
      [1 pigment {rgb 1} finish {ambient 0 diffuse 0.4 specular 1 roughness 0.03
reflection 1}]
    scale 0.2
Date: 1 Mar 2006 06:25:00
Message: <web.44058323783b11faf37ab23e0@news.povray.org>
> general sense.
> -ross
Thanks for your reply. In deed this could be extended for my purposes but
as i mentionen above this gets very ugly when you have more than two
different finish items you'd like to change. I'll post an extended version
with source in the thread with your image. As you may see there you need 15
definitions to create a texture with three finish items following different
patterns (specular map, reflection map and ambient map in that case). With
four items you should need 31 definitions, with five items you'll need 63
and so on. obviously this renders quite slow especially when pigment
functions from image maps are being used as patterns.
Regards Roman
