POV-Ray : Newsgroups : povray.general : is it possible to warp a primitive or a height-field? Server Time
28 Feb 2026 22:43:13 EST (-0500)
  is it possible to warp a primitive or a height-field? (Message 1 to 10 of 10)
Subject: is it possible to warp a primitive or a height-field?
Date: 25 Jul 2005 13:20:01
Message: <web.42e51e8d3d315b497d21e22c0@news.povray.org>
Is it possible to warp or modify using noise or turbulence a primitive
object in POV? I have seen scenes that use objects like a torus or a
height-field that are greatly distorted to create fantastic objects that
bear little resemblance to the original object. Or is this something that
would have to be generated outside POV and then imported as triangles?
Subject: Re: is it possible to warp a primitive or a height-field?
Date: 25 Jul 2005 14:23:02
Message: <42e52e06@news.povray.org>
This is done using isosurface's
Primitive shapes can be expressed as functions.  Then can then be
combined with a noise function in various ways either to produce a
primitive with its surface displaced to give a textured look or to
actually "warp" the primitive.  Christoph Hormann produced an include
file that predefines functions to produce and combine isosurface
primitives.  It is call isocsg.inc.  Mr. Hormann also produced an
include file called isowood.inc which specializes in producing various
primitives displaced with vary convincing wood textures.  If you obtain
this file you can study how he conbines primitive and noise functions to
do things like bend a plank of wood to look like it has been warped by
the weather.  These files are available from his website
Date: 25 Jul 2005 14:57:47
Message: <42e5362b$1@news.povray.org>
> file [...] These files are available from his website
... which can be found at
http://www-public.tu-bs.de:8080/~y0013390/index.html
HTH,
Florian
Date: 26 Jul 2005 01:00:48
Message: <42e5c380@news.povray.org>
  Somehow I have always had a problem with this answer (to the question
"can I bend an object" or similar). There are several reasons for this.
  Firstly, and most importantly, the answer is, strictly speaking,
incorrect. You cannot take any given existing POV-Ray object and somehow
magically bend it "using isosurfaces". Isosurfaces cannot modify existing
objects in any way.
  What you would have to do in order to simulate this is to remodel your
entire object using isosurface functions. This is not always even
possible, and in many cases even when possible it's prohibively
laborious. With some object it doesn't even make any sense, such as
with meshes.
  Secondly, it's not the best solution in all cases nor the most efficient.
For example, if you want to bend a mesh or a heightfield it's usually
much easier and a lot more efficient to just move the vertex points
(assuming you have the vertex points and you can change them with
either POV-SDL or an external program; with heightfields you usually
can use the heightfield macros in the POV-Ray include library).
  Sometimes, when bending simple primitives, it's much more efficient
to model the bent result instead of trying to bend the original
(typical example: bending a cylinder is better done with a torus
segment).
  Thirdly, although this is completely irrelevant and only a question
of semantics, you are not truely "bending" an isosurface: You are
creating a new isosurface function which looks like a bent version
of the original
  In any case, I think it would be much better to answer like:
  "One possible solution is to model your object using isosurface
functions. Isosurfaces can be bent easily."
Date: 26 Jul 2005 05:21:43
Message: <250ce154k6red4c8um60vmje3ss3qagrap@4ax.com>
>of the original
LOL
"The trials of an artist, in a maths based community" :-)
Regards
Date: 26 Jul 2005 06:58:02
Message: <42e6173a$1@news.povray.org>
> laborious.
Remodelling simple objects is not too difficult using IsoCSG. For
complex models, the best way is IMHO to remodel them as a mesh.
I think that's clear once you understand the difference between
triangle-represented objects and POV's primitives.
> segment).
Bent round boxes and cylinders can easily be made using the following
include file:
http://povray.tirnalong.com/ow.asp?MoreShapes
100% ACK
Greetings,
Florian
Date: 26 Jul 2005 10:50:17
Message: <42e64da9$1@news.povray.org>
> objects in any way.
> with meshes.
> segment).
> of the original
I think you are being a little extreme.  True, it comes down to the
semantics of what is meant by "a primitive object in POV", but he seemed
to indicate that he mostly meant "not triangles".  But I take your point
that I may think of an isosurface, which happens to define a cube let's
say, as being more similar to a POV "box" than it actually is.  Also if
you want to get picky, he never said "bend", he said "warp" or "modify"
and even specified "using noise or turbulence".  And that is precisely
what some of Christoff's code does.  So I think it was a reasonable
answer to the question as asked.  I had also considered mentioning that
macros have been written which dice and recombine primitives to similate
a skewed effect, but I didn't want to attempt and exhaustive treatment,
just answer what he seemed to be asking.
Date: 27 Jul 2005 17:30:00
Message: <web.42e7fcb2fe0b49e7d21e22c0@news.povray.org>
Thank you all for your informative responses. I am indeed looking for more
than simple bending of a primitive. I wish to distort it beyond recognition
if possible which is why I thought that using noise or turbulence might be
the way to go. I will check out Horman's include files for hints.
Date: 28 Jul 2005 01:16:58
Message: <42e86a4a@news.povray.org>
  Well, the correct answer is that you can't. You cannot take a POV-Ray
primitive and distort it.
  What you can do is to design an isosurface which looks like the primitive
or object and then you can distort its function. Another possibility is
to create a mesh which looks like the primitive/object and then move
its vertices around.
Date: 28 Jul 2005 04:29:14
Message: <42e8975a@news.povray.org>
To see the specific technique I was refering to, look at example file:
iw_ex_02.pov
look at the very first object in it labelled "distorted plank", it calls:
IW_Plank_Round_CutN
You can see the entire shape is distorted by use of a noise function.
