POV-Ray : Newsgroups : povray.general : taking off a bathingsuit Server Time
16 Apr 2026 05:57:39 EDT (-0400)
  taking off a bathingsuit (Message 1 to 6 of 6)
Subject: taking off a bathingsuit
Date: 29 Jun 2005 20:35:01
Message: <web.42c33d424ea3ce38f76c6a30@news.povray.org>
Hello all. I am working on a modell of a character that can be either naked
or wear a bathingsuit. The coding for the suit is in three separate
sections ( Torso, LeftLeg, and RightLeg) do to the limbs being movable.
Now to remove the bathingsuit I have been remarking out the sections ( I.E.
/*   */ ) but this is becoming rather tedius. Is there a way to code a
switch that can have those sections bypassed, say, depending on the value
of a variable I #declare at the top of the INC file?
(like #declare removebathingsuit = 1;)
Subject: Re: taking off a bathingsuit
Date: 29 Jun 2005 21:03:32
Message: <42c344e4$1@news.povray.org>
Barehunter nous apporta ses lumieres en ce 2005-06-29 20:30:
You are on the right track. You can have #declare putbathingsuit = 1; in the main
scene where it's
usualy more accessible. Put the swimsuit in an #if(putbathingsuit )...#end block. One
such block per
places where the swuimsuit get used.
Date: 29 Jun 2005 21:20:00
Message: <web.42c34827dc145126f76c6a30@news.povray.org>
scene where it's
One such block per
> Alain
ok 2 questions so I understand this better.
1: In this case the only possible answers for the variable is 1 or 0?
2: and this would be typed as..
 #if(putbathingsuit)
 // my coding here//
#end block
is that right?
btw the reason I would keep it in the INc file as my current project is a
commision in which I am converting a certain webartist's webcomic into 3D
episode by episode. each character is in it's own INC to better control
them. all characters are fully movable and in some cases have separate
emotions visible on ther faces.
Date: 30 Jun 2005 00:25:00
Message: <web.42c37382dc145126f76c6a30@news.povray.org>
>  #if(putbathingsuit)
>  // my coding here//
> #end block
> is that right?
ok I tried it and figured out not to include the word "block" other then
that yes that's how it works. I love learning new things about this
software.
Date: 30 Jun 2005 06:45:20
Message: <42c3cd40$1@news.povray.org>
Barehunter nous apporta ses lumieres en ce 2005-06-30 00:22:
>> #if(putbathingsuit)
>> // my coding here//
>>#end block
>>is that right?
> software.
When usonf an #if, 0=don't use what follows. NOT 0 = execute the folloing.
If you want to be able to use several values, you should use the
#switch(variable)
	#case(value 1)[code]#breack
	#case(value 2)[code]#breack
	#case(value x)[code]#breack
  structure. In your case, you can have a veriety of suits changed by a single
variable.
Date: 21 Jul 2005 22:19:02
Message: <42e05796@news.povray.org>
news:42c3cd40$1@news.povray.org...
> #switch(variable)
> #end
> single variable.
> Alain
It is #break, not #breack. :)
My usual mistake is to write finnaly instead of finally (I never remember
which letter is doubled) and to write #declaer when I write it too fast.
