POV-Ray : Newsgroups : povray.general : Problem with photon mapping Server Time
16 Aug 2025 11:54:09 EDT (-0400)
  Problem with photon mapping (Message 1 to 9 of 9)
Subject: Problem with photon mapping
Date: 21 Nov 2004 07:35:00
Message: <web.41a08aa1ee452319510445a30@news.povray.org>
Hi!!
I'm a new user of POV. I looked your FAQ but I didn't find answers to my
problem.
I need to model a cornell box with photon mapping. I used different scenes
gave with pov to do it.
However, my photons in the scene are not always shot and when they are shot,
they don't give good results of global illumination. I don't see any
difference between basic ray tracing and photon mapping?
Following my pov file.
Thank you for your help
Arnaud Lapeyrade
// Persistence Of Vision Ray Tracer Scene Description File
// File: cornell.pov
// Vers: 3.5
// Desc: Radiosity demo scene. See also
http://www.Graphics.Cornell.EDU/online/box/
// Date: August 2001
// Auth: Kari Kivisalo
// +w300 +h300
#include "glass.inc"
#include "textures.inc"
global_settings {
  assumed_gamma 1
  max_trace_level 25
  photons {
    spacing 0.1 // study the photon spacing impact
    count 1000000
    autostop off
    //save_file "D:BOULOT3D_Computer_GraphicsAssignment2map.ph"
#declare Finish=finish{diffuse 0.75 ambient 0}
#declare White=texture{pigment{rgb<1,1,1>} finish{Finish}}
#declare Red=texture{pigment{rgb<0.5,0.3,0.01>} finish{Finish}}
#declare Green=texture{pigment{rgb<0.025,0.236,0.1>} finish{Finish}}
#declare Radius = 10;
#declare LightColor=<1,0.67,0.21>;
//#declare N=3;       // Divisions per side
//#declare DX=13/N;   // Dimensions of sub patches
//#declare DZ=10.5/N;
light_source {
  <27.8, 54.88, 27.95>
  color rgb <1.0, 1.0, 1.0>
  shadowless
  photons {
    reflection on
    refraction on
light_source{
    <27.8,54.88,27.95>
    color LightColor
 // area_light <5, 0, 0>, <0, 0, 5>, 5, 5
    adaptive 2
    photons {
    reflection on
    refraction on
    area_light
camera{
  location  <27.8, 27.3,-56.0>
  direction <0, 0, 1>
  look_at <27.8, 27.3, 1>
// ------------------------ OBJECTS ----------------------------
// Light Patch
sphere {
    <16,10.0,35.0>,Radius
    material {
        pigment { color Col_Glass_Clear }
        finish { F_Glass9 }
      interior {
        I_Glass_Exp(4)
      //  fade_color Col_Red_03
    photons {
    reflection on
    refraction on
    collect off
union{
  sphere {
    <40.0,10.0,10.0>,Radius
    material {
        finish { F_Glass6 }
    photons {
    reflection on
    refraction on
    collect off
  hollow off
union{
  box{
    <21.3,54.87,33.2><34.3,54.88,22.7> no_shadow
    pigment{rgb<1,1,1>} finish{ambient 0.78 diffuse 0}
union{
  // Floor
  triangle{<55.28, 0.0, 0.0>,<0.0, 0.0, 0.0>,<0.0, 0.0, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  triangle{<55.28, 0.0, 0.0>,<0.0, 0.0, 55.92>,<54.96, 0.0, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  // Ceiling
  triangle{<55.60, 54.88, 0.0>,<55.60, 54.88, 55.92>,<0.0, 54.88, 55.92>
            photons {
            target
            reflection off
            refraction off
            collect on
  triangle{<55.60, 54.88, 0.0>,<0.0, 54.88, 55.92>,<0.0, 54.88, 0.0>
          photons {
            target
            reflection off
            refraction off
            collect on
  // Back wall
  triangle{<0.0, 54.88, 55.92>,<55.60, 54.88, 55.92>,<54.96, 0.0, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  triangle{<0.0, 54.88, 55.92>,<54.96, 0.0, 55.92>,<0.0, 0.0, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  texture {White}
union {
  // Right wall
  triangle{<0.0, 54.88, 0.0>,<0.0, 54.88, 55.92>,<0.0, 0.0, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  triangle{<0.0, 54.88, 0.0>,<0.0, 0.0, 55.92>,<0.0, 0.0, 0.0>
          photons {
            target
            reflection off
            refraction off
            collect on
  texture {Green}
union {
  // Left wall
  triangle{<55.28, 0.0, 0.0>,<54.96, 0.0, 55.92>,<55.60, 54.88, 55.92>
          photons {
            target
            reflection off
            refraction off
            collect on
  triangle{<55.28, 0.0, 0.0>,<55.60, 54.88, 55.92>,<55.60, 54.88, 0.0>
          photons {
            target
            reflection off
            refraction off
            collect on
  texture {Red}
Subject: Re: Problem with photon mapping
Date: 21 Nov 2004 08:00:01
Message: <cnq37o$afq$1@chho.imagico.de>
Yeager wrote:
> Hi!!
> problem.
POV-Ray uses photon mapping for calculating caustics but not for global
illumination.  In other words - photons in POV-Ray only take into
account the specular but not the diffuse light transport.  This is
explained in detail in Wann Jensen's work and Nathan's paper on the
POV-Ray photon patch (you can find it at
http://nathan.kopp.com/photons.htm).  In fact photons can't be used
efficiently for global illumination directly, you can just use them for
speeding up other global illumination techniques.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 21 Nov 2004 09:13:29
Message: <41a0a289@news.povray.org>
"Yeager" <non### [at] club-internetfr> wrote in message
news:web.41a08aa1ee452319510445a30@news.povray.org...
> Hi!!
> problem.
In addition to what Christoph has said, basically what you're looking for is
POV-Ray's radiosity functions.
For examples of using Radiosity and Photons in POV-Ray, check out Tim
Nikias' excellent Cornell Box example page and radiosity and photons
settings tutorial at the following address:
http://www.nolights.de/past_pros/radiosity/radiosity.html
Lance.
thezone - thezone.firewave.com.au
thehandle - www.thehandle.com
Date: 21 Nov 2004 09:38:23
Message: <41a0a85f@news.povray.org>
Yeager nous apporta ses lumieres ainsi en ce 2004-11-21 07:31... :
>light_source{
>    <27.8,54.88,27.95>
>    color LightColor
>    adaptive 2
>    photons {
>    reflection on
>    refraction on
>    area_light
I look at your light_source. If you enable the area_light, at 5*5,
adaptive 2 is like not using adaptive at all. adaptive 0 use a minimum
2*2 aray, adaptive 1 a minimum 3*3 aray, adaptive 2 a minimum 5*5 aray,
adaptive 3 a minimum 9*9 aray... up to the size of the aray effectively
used.
Date: 21 Nov 2004 12:56:52
Message: <41a0d6e4@news.povray.org>
Btw, all objects collect photons by default, so specifying
"photons { collect on }" for each one of them is just a waste of space
and resources. (And *specially* specifying it for each single object
in a union, when you could just specify it once for the entire union.)
  (Btw: How did you expect walls to reflect light when you have
specified "photons { reflection off }" for them? Not that it works
for non-reflecting surfaces anyways, but just curious.)
Date: 22 Nov 2004 08:50:01
Message: <web.41a1eded5b211d0b1642bea10@news.povray.org>
I don't expect that wall reflet light...Object do it but not walls. Walls
collect the photons and by this way we have photon map.
Date: 22 Nov 2004 09:10:01
Message: <web.41a1f2755b211d0b1642bea10@news.povray.org>
> > Hi!!
> > problem.
> Lance.
Ok I think I understood my mistake. I thought that radiosity algorithm was
with pathes in the scene but it's not.
Thank you for your help from all of you
Date: 22 Nov 2004 09:41:40
Message: <41a1faa4@news.povray.org>
  You told in your post that you are not getting the global illumination
effect you are trying to achieve, so I assumed you wanted photons to
reflect from walls in order to achieve global illumination.
  (Photon mapping in POV-Ray cannot be used for this purpose, but I was
just curious about what it was that you were trying to do. Global
illumination without light reflecting from walls is just not possible.)
Date: 22 Nov 2004 11:15:00
Message: <web.41a2101d5b211d0b1642bea10@news.povray.org>
You right, but I think it is a misunderstanding from my about POV. I thought
I could use different methods with it like radiosity (I mean radiosity with
patches), and path raytracing + photon mapping. But more and more I learn
about about these methods more I understand that I was wrong, and that POV
doesn't realise exacly what I tought.
