POV-Ray : Newsgroups : povray.general : Displacement mapping in Povray Server Time
30 Mar 2026 02:09:23 EDT (-0400)
  Displacement mapping in Povray (Message 1 to 10 of 27)
Subject: Displacement mapping in Povray
Date: 28 Oct 2004 06:05:00
Message: <web.4180c34b61880e1728b80a700@news.povray.org>
Is there someone working on "Displacement Mapping" in Povray (as a Patch)?
Best regards.
Delle.
Subject: Re: Displacement mapping in Povray
Date: 28 Oct 2004 06:50:53
Message: <Xns959082B28CEBFjgrimbertmeandmyself@203.29.75.35>
> Patch)?
First, it is available really from Isosurface, already.
Second, Displacement mapping is a concept which often apply with mesh (or
meshed nurbs...) which is a very small subset of Povray capabilities.
Third, have a look at
http://jgrimbert.free.fr/pov/patch/tessel/displace.html
(and related pages)
Fourth and last, I'm not working on it anymore for the time being.
l'habillement, les chaussures que le maquillage et les accessoires.
Date: 28 Oct 2004 09:22:07
Message: <4180f27f@news.povray.org>
  No, it's not.
  You can get a displacement effect by modifying the function from which
the isosurface is calculated. However, that's not "displacement mapping",
which is a completely different technique.
Date: 28 Oct 2004 10:05:01
Message: <clqu1u$678$1@chho.imagico.de>
>   No, it's not.
That depends on how you define displacement mapping.  If you say it is
"displacing the surface of a shape by an amount defined by an image or
function" this is well possible with isosurfaces.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 28 Oct 2004 11:34:45
Message: <41811194@news.povray.org>
  But saying "POV-Ray supports displacement mapping" is not completely
correct.
  It's exactly the same thing as saying "POV-Ray supports non-linear
transformations", which of course is not true.
  What POV-Ray supports are user-defined functions (and functions modified
by other functions) and rendering isosurfaces from them. There's no
explicit support for an algorithm called "displacement mapping" or
"non-linear transformation".
  To put it in another way: The "displacement" and "non-linear
transformation" are part of the modelling process performed by the
user, not something done by the POV-Ray rendering engine.
  You can't say "this renderer supports bending" simply because you
can create a mesh which looks bent and render it with that renderer
(ie. the question is: Who created the bent shape, the user or the
rendering engine?).
Date: 28 Oct 2004 12:05:02
Message: <clr551$7kl$1@chho.imagico.de>
> correct.
With the definition of displacement mapping i gave it is.
But of course the question 'does POV-Ray support displacement mapping'
does not make much sense for various reasons (in fact nearly all 'does
POV-Ray support xxx' questions do not make sense).  And to be fair the
posting that started this thread also did not ask this.  An internal
limited value.  What would be interesting is support for adaptive render
time subdivision of meshes with displacement.
Date: 28 Oct 2004 12:20:00
Message: <web.41811bcd7530c78028b80a700@news.povray.org>
What I've in mind is something like this :
"http://www.paralelo.com.br/arquivos/ReliefMapping.pdf" that generates
displace mapping (with shadows) without the necessity of adding triangles
(to mesh2 objects).
Delle
Date: 28 Oct 2004 13:18:29
Message: <418129e5$1@news.povray.org>
AFAIK POV-Ray doesn't support NURBS.
Displacement mapping is usually done during tesselating shapes into
triangles - but POV-Ray has no need to tesselate objects (except for
bezier-patches).
If patched versions of POV-Ray add support for NURBS and SDS, it would
be a nice feature to add displacement mapping for those objects :-)
Date: 28 Oct 2004 14:00:02
Message: <clrbun$8qb$1@chho.imagico.de>
No, POV-Ray supports NURBS as much as most other renderers support them
- by rendering meshes generated from them.  It is possible to directly
raytrace NURBS of course but that is rarely done.  See also my general
remark concerning 'does POV-Ray support xxx' questions.
No.  No algorithm commonly used to directly raytrace NURBS would allow
displacement mapping.  So the above statement does not make sense.
Date: 28 Oct 2004 14:45:28
Message: <41813e48$1@news.povray.org>
Sure, POV-Ray supports triangle meshes - but you'd need an external
application to generate a triangle mesh from a NURBS mesh (of course SDL
could do this, but it's quite slow when you need to tesselate thousands
of NURBS patches).
The scene file containing triangle meshes is much larger than the file
describing just the NURBS, this can be a problem for distributing the
scenes via the internet (e.g. for the Internet Movie Project).
Another problem when tesselating "outside" of POV-Ray are the trim curves...
> It is possible to directly raytrace NURBS of course but that is rarely done.
I've read some papers about directly ray-tracing bezier-patches (I think
NURBS would work quite similar) - The conclusion was that it's also just
an approximation, and a tesselated triangle mesh of the same quality
would render faster, so there would be no real advantage in raytracing
"directly".
I meant the tesselation approach (as used in POV-Ray for
bezier-patches).  Theoretically it should be possible to add
displacement mapping to the bezier-patch tesselation code.
The big advantage of doing displacement mapping within POV-Ray would be
that all the patterns that can be used for bump-mapping could be re-used.
Don't get me wrong. Iso-Surfaces are a really cool feature of POV-Ray
and offer a lot of possibilities. Its just a bit of an overkill to use
this feature for displacement mapping...
