![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello everyone,
I am currently learning the wonderful world of Pov-Ray and I currently
have a few questions.
For a project I am currently working on, I'd like to create a computer
simulation (rendering) of an optical system. I think it could be done
in Pov-Ray but I'm not 100% sure, hence that's why I post :)
At least, I need to create a tiny light beam (like a laser, white light
ray, etc.). I found this page on Google and contacted the author to get
more information on this :
http://www.mbork.de/bsp/bsp_2.htm
He said that this was rendered in Pov3.0, and it cannot be done the same
way with newer Pov. Anyone got an idea to make a such light ray ?
Also, I'd like to get my renderings a little bit "dirtier" : is it
possible to add a subtle grainy effect (like the grain of a film in the
photography world) to the entiere rendering ?
Thanks !
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3e600b54@news.povray.org>,
It is not impossible to do the same way, it's just that there's a better
way. Instead of multiple light sources or cylinders of glowing media,
pov can simulate the paths photons actually travel through the scene.
Look in the documentation for the photon mapping feature, and the
optics.pov demo scene.
The best way is to do things like use normals and grainy patterns, and
otherwise try to get dirty textures. There are ways to add a flat noise
to the image, but it does not make the scene itself look more real, it
is more of a film effect.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks for the fast answer !
I think I'll look again at that example, I already saw it before and I
think that's what I need but I didn't understood it at first.
I think the flat noise effect is what I am looking for. A picture worth
thousands of words, so :
http://www.elysiun.com/forum/viewtopic.php?t=9743
The pics are not from me and are not done in PovRay, but that's the
effect I am looking for.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3e602316$1@news.povray.org>,
Ok...well, look in the manual for "crand". Or look here:
http://povray.org/documentation/view/187/#s06_07_03_02_03
I still do not recommend it, though. The crand feature only works on
textures, so it might be difficult to apply to your situation. It just
isn't a very good solution, and is considered obsolete. If you want a
camera film effect, it would be better to do it in an image processing
program.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Hello everyone,
Pierre
I started a similar project a while ago. I don't know exactly what you
want to do, whether you want it just to look correct, or to have a
system where an optical physicist can code in the data for optical
equipment and see the result in povray.
I have written a few routines for optical components like lenses of a
specific focal length, mirrors, etc. I am happy to put these at your
disposal for eventual release into the public domain. If you are
interested, please mail me.
Kaveh
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> is it possible to add a subtle grainy effect (like the
> grain of a film in the photography world) to the entiere
> rendering ?
Make a sphere or disc with a semi-transparent noisy texture. Scale it
very tiny and translate it to be just in front of the camera (if it is a
disc) or centered around the camera location (if it is a sphere). Make
sure the finish of the noise texture has an ambient of 1 and a diffuse
of 0 so that it is not affected by lighting in the scene. I don't have
any ready-to-use code but try out some things and see what works for
you.
Rune
rune|vision: http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Rune wrote:
> I don't have any ready-to-use code but try
> out some things and see what works for you.
Oh well, I made some code anyway...
This one should make dark areas in the image noisy, while keeping bright
areas relatively noise-free. Isn't that the way it is in real
photographs?
// AddNoise macro by Rune S. Johansen
// Example of use:
// AddNoise(camera_location,1.0,0.002,0.5)
#macro AddNoise(camera_location,noise_level,noise_scale,noise_colors)
sphere {
0, 1 hollow no_shadow no_reflection
average scale noise_scale
texture_map {
#local I = 0;
#while (I<3)
#local C = vaxis_rotate(x,1,120*I);
#local D = 0.5+(2*C-1)*noise_colors;
spotted translate 10*C
color_map {
[0,rgb 2-D transmit 1-noise_level ]
[1,rgb D transmit 1+noise_level*1.2]
finish {ambient 1 diffuse 0}
#local I = I+1;
scale 0.001 translate camera_location
Rune
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>ray, etc.).
A laser? Easy. Just make a cylindrical light and use the 'paralell' keyword
in it. And use Photon mapping to make it reflect off mirrors, and be bent
by lenses. Making the light paralell makes the light behave like a real
laser. There does, however, seem to be a bit of a problem involving a
mysterious black disc which can appear in certain circumstances. Exactly
which, I'm still not sure of. I think it might be a bug in the cylindrical
lights, but I could be wrong.
Rohan _e_ii
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
