POV-Ray : Newsgroups : povray.general : Image_map color adjustment? Server Time
19 Mar 2026 22:30:08 EDT (-0400)
  Image_map color adjustment? (Message 1 to 10 of 13)
Subject: Image_map color adjustment?
Date: 13 Jul 2005 19:59:53
Message: <vp9bd1p330mntk3k9dhlfch4csv2215j12@4ax.com>
Hi all.
I hope this hasn't been asked before, or is answered somewhere in the
manual that I have overlooked, but here goes...
I am using an image_map as a pigment for an object.  Once rendered,
the color of the object looks quite faded, compared to the image that
is used for the image_map.  I found that adjusting the assumed_gamma
in global_settings from 1 to 2.2 enhances the color of the object.  Is
there a method to enhance the image_map pigment without affecting the
entire image?
Thanks,
Kyle
Subject: Re: Image_map color adjustment?
Date: 13 Jul 2005 20:06:36
Message: <42d5ac8c$1@news.povray.org>
Kyle nous apporta ses lumieres en ce 2005-07-13 19:59:
> Hi all.
> entire image?
> Thanks,
> Kyle
You may have to much ambient or lights that is or are to bright. Try assigning an
ambient value of 0
in the finish to see if it help. Try lowering the intensity of any light_source
shining on your object.
Date: 13 Jul 2005 20:34:42
Message: <vsbbd1dtllv2mb049bvsgtv1egu161sp9g@4ax.com>
On Wed, 13 Jul 2005 20:06:37 -0400, Alain <ele### [at] netscapenet>
ambient value of 0
Thanks for your suggestions!
I have ambient set to 0.  I have tried adjusting the light intensity
quite a bit, but lowering or raising the intensity only makes the
object either too dark or the color is really washed out.
Kyle
Date: 14 Jul 2005 10:05:02
Message: <web.42d66fb4c1c7b128a175d1920@news.povray.org>
If using a display with a gamma larger than 1.0 and running with an assumed
gamma of 1.0 as recommended, you will need to adjust the gamma of the image
being used as an image_map to have a gamma of 1.0 prior to use (*).
In other words the image_map image prior to use should look darker on a
display with a gamma of > 1.0 when you view it with for example photoshop
or similar tool.
There is also a display gamma setting, but unless you have changed it
yourself the default is set up as 2.2 and that is good for most display
systems.
(*) If your image looks 'right' on a display with a gamma of for example
2.2, it is not itself a linear image. Linear image = image with a gamma of
1.0.
Bill
Date: 14 Jul 2005 18:42:48
Message: <0rpdd1lm0vnpga5r1islmjk1pqcp5qqpjr@4ax.com>
Bill,
I was hoping to find a way to do this in the scene file to avoid
having to edit the image(s), but it may not be possible.
Your suggestion does work very well, though.  I opened the image in
Gimp and adjusted the gamma by 0.45 (the inverse of 2.2).  The
rendered colors look very nice now.
Thanks for your suggestion.
Kyle
Date: 15 Jul 2005 06:45:00
Message: <web.42d79299c1c7b128950b81cf0@news.povray.org>
> Bill,
Jaime Vives Piqueres Lightsys package lets you easily adjust the brightness,
contrast and gamma adjustment of any pigment, including image_maps.
Lightsys comes with easy-to-follow demos of the image processing
capabilities. You could probably still utilize these macros, even if you
don't want to use the full power of Lightsys.
Date: 15 Jul 2005 14:28:24
Message: <42d80048$1@news.povray.org>
news:vp9bd1p330mntk3k9dhlfch4csv2215j12@4ax.com...
> Hi all.
> entire image?
> Thanks,
> Kyle
When I use an image_map as a pigment, I always set finish{diffuse  1}
Marc
Date: 15 Jul 2005 18:15:45
Message: <b3dgd1deqcp87ib7s3dd98o62pki9ousie@4ax.com>
I downloaded Lightsys some time ago, but haven't had a chance to check
it out.  I've noticed quite a few scenes that use it.  I guess its
time to go learn something new...
Thanks!
Kyle
Date: 15 Jul 2005 18:20:21
Message: <tddgd19vfgamdld0dqvcp82lrce1djbhu3@4ax.com>
On Fri, 15 Jul 2005 20:28:55 +0200, "Marc Jacquier"
No help in this case.  It's too washed out, similar to increasing the
light intensity.  Thanks for the suggestion, though.
Kyle
Subject: Re: Image_map color adjustment? - Update
Date: 15 Jul 2005 18:56:20
Message: <j7egd1df2d6f6llm4ed5clb8e3t991bv6q@4ax.com>
Here are the results of a few tests...
The problem:  When using a jpg image in an image mapped pigment, the
rendered colors are very washed out as compared to the original image.
After a reply from William Pokorny on this issue, I opened the
original image in Gimp, adjusted the gamma by 0.45, which is 1/2.2,
then saved it.  The colors of the rendered image were correct.
This got me to thinking about saving the original image in a format
that stores gamma data and if POVRay would account for this...
I first saved the original image in png format without gamma.  The
colors of the rendered image were washed out, just like with the
original jpg image.
I then saved the original image in png format with gamma.  The colors
of the rendered image are correct!
Apparently, POVRay does adjust for the gamma value that is saved with
an image if it is used in an image mapped pigment.
I hope this info helps someone else out...
Kyle
On Wed, 13 Jul 2005 19:59:55 -0400, Kyle <hob### [at] gatenet> wrote:
>Hi all.
>entire image?
>Thanks,
>Kyle
