POV-Ray : Newsgroups : povray.general : Very slow texture: any ideas on speeding it up? Server Time
10 Jan 2025 04:15:25 EST (-0500)
  Very slow texture: any ideas on speeding it up? (Message 1 to 8 of 8)
Subject: Very slow texture: any ideas on speeding it up?
Date: 16 Dec 2010 13:50:36
Message: <op.vntlajmn0819q0@gdsentropy.nc.rr.com>
Currently I have a render going for over 1 day, only 30% done and it looks
like this might take a very long time.
Is there anything I have done just plain incorrectly to cause this texture
to be so slow, or is it simply the very nature of this texture? Any
thoughts would be appreciated.
I am applying it to that snownut test object as a whole.
This is the slope texture I use for the high quality snow/ice. Here is the
full usage:
slopeSnowTex(-1,0.9)
  SnowTex0
interior {
  fade_distance 2
  fade_power 3
  ior 1.45
  caustics 1.0
// slopeSnowTex.inc
//      Snow texture by [GDS|Entropy]    |
//                       Ian McDonald    |
#macro slopeSnowTex(_C_,filterVal)
#declare Snow =
   color rgb <0.96,0.97,0.99>*1.1
  normal {
   wrinkles 0.4
   ramp_wave
   turbulence 0.3
   scale 0.039
  finish {
   ambient 0.35
   diffuse 0.425
   specular 0.125
   roughness 0.1
#declare Snow2 =
   color rgb <0.98,0.97,0.96>
  normal {
   wrinkles 0.3
   ramp_wave
   turbulence 0.25
   scale 0.036
  finish {
   ambient 0.325
   diffuse 0.4
   specular 0.15
   roughness 0.075
#declare Ice =
   bozo
   octaves 1
   frequency 4
   triangle_wave
   color_map {
    [0.00 rgbf <0.98,0.97,0.96,filterVal>]
    [0.03 rgbf <0.91,0.97,0.93,filterVal>]
    [0.40 rgbf <0.91,0.97,0.93,filterVal>]
    [0.40 rgbf <0.91,0.94,0.94,filterVal>]
    [0.42 rgbf <0.91,0.97,0.93,filterVal>]
    [1.00 rgbf <0.91,0.97,0.93,filterVal>]
  finish {
   ambient 0
   diffuse 1
   brilliance 0.005
   specular 0.5
   roughness 0.001
   reflection 0.125
  normal {
   wrinkles 0.1
   scale 0.00001
#declare Ice2 =
   bozo
   octaves 1
   frequency 4
   triangle_wave
   color_map {
    [0.00 rgbt <0.98,0.97,0.96,filterVal+0.1>]
    [0.03 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [0.40 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [0.40 rgbt <0.91,0.94,0.94,filterVal+0.1>]
    [0.42 rgbt <0.91,0.97,0.93,filterVal+0.1>]
    [1.00 rgbt <0.91,0.97,0.93,filterVal+0.1>]
  finish {
   ambient 0
   diffuse 1
   brilliance 0.05
   specular 0.5
   roughness 0.001
   reflection 0.125
  normal {
   wrinkles 0.1
   scale 0.00001
#declare SnowTex0 =
   slope -y
   texture_map {
     [0.1 Snow]
     [0.2-(0.05*_C_) Snow2]
     [0.3-(0.01*_C_) Ice]
     [0.4-(0.133*_C_) Ice2]
     [0.5-(0.133*_C_) Ice2]
   rotate -5*z
Ian McDonald
Using Opera's revolutionary email client: http://www.opera.com/mail/
Subject: Re: Very slow texture: any ideas on speeding it up?
Date: 16 Dec 2010 15:25:01
Message: <web.4d0a74f658dd15d1b04292d0@news.povray.org>
I heard latest beta has texture baking or something like that.
Date: 16 Dec 2010 15:42:26
Message: <4d0a79b2$1@news.povray.org>
[GDS|Entropy] wrote:
> Any thoughts would be appreciated.
Well it certainly is a complex texture, but I'd
tend to blame it on the blurred reflection
>  normal {
>   wrinkles 0.1
>   scale 0.00001
Date: 16 Dec 2010 16:06:54
Message: <op.vntrlpj90819q0@gdsentropy.nc.rr.com>
Ok, I'll give that a shot.
Thank you,
Ian
On Thu, 16 Dec 2010 15:42:24 -0500, Christian Froeschlin <chr### [at] chrfrde>
>>  normal {
>>   wrinkles 0.1
>>   scale 0.00001
Date: 16 Dec 2010 22:15:20
Message: <4d0ad5c8$1@news.povray.org>
 >> normal {
 >> wrinkles 0.1
 >> scale 0.00001
What are your anti-aliasing settings? With a texture like this, you'll
get a lot of oversampling, especially if you're using AA method 2. I
would increase the scale of that normal as much as possible. (Also, at a
scale that small, you probably don't need as much detail as the wrinkles
pattern provides.)
  - Slime
Date: 17 Dec 2010 19:04:36
Message: <op.vnvuhueh0819q0@gdsentropy.nc.rr.com>
Well, I have tried disabling all of the normals, as well as turning off
radiosity and anti-aliasing...but to no avail, unfortunately. :(
I guess it is just perhaps all of the transmits and then the shadows cast
by the non transmitting texture portions. I can't think of anything else.
Though it still seems that this texture should not take so god-awfully
long to render. If I can ever get povray to compile with vs2010 ultimate I
will be sure to step through the code and run all kinds of metrics and
performance evaluations as well. Though that is, honestly, a low priority.
I need to finish the other things that I have started first.
I think that my situation and options are as outlined below:
1) I cannot fix the texture render time directly without ruining the
texture or patching pov
2) I can either
	2a)	tessellate the surface and render the mesh
	2b)	implement a mesh based version of metaballs (I have some c# code
which creates mesh metaballs [though..again without patching pov to get
some useful collection types..])
That seems to be it. It is unknown which option would result in lower
total render time, though I would expect parse time to be lower for option
2b.
You know..it might actually be worth coming up with a patch to pov which
would give the user something close to standard collection types such as
follows:
1)	List<T>
2)	Dictionary<T,T>
3)	ArrayList<T>
4)	Tree<T>
5)	Ability to eval and run the same language pov-ray was written in, so
you could mix c++ and SDL (such as overriding or overloading methods used
in the renderer)
6)	MathML eval
But those are tasks for a different day...(perhaps even epoch)
Ian
>  >> normal {
>  >> wrinkles 0.1
>  >> scale 0.00001
> pattern provides.)
>   - Slime
Date: 17 Dec 2010 22:59:22
Message: <4d0c319a$1@news.povray.org>
> looks like this might take a very long time.
> texture to be so slow, or is it simply the very nature of this texture?
> the full usage:
> texture {
> SnowTex0
> interior {
> fade_distance 2
> fade_power 3
> ior 1.45
> caustics 1.0
Maybe not related, but an interior with fade_power 3?
fade_power 2 is realistic for light fading from a light_source through a
volume.
Through some material, you should use fade_power 1 or fade_power 1001 to
use exponential fading.
fade_power is unrealistic in any situation, unless you appen to live in
a 4D+time world.
Date: 19 Dec 2010 15:05:24
Message: <op.vny8q6u80819q0@gdsentropy.nc.rr.com>
Hmm....interesting. Related or not, I will be adjusting that value. I do
want realistic ice, as much as possible. Thanks for the tip!
Ian
e?
s
>> the full usage:
>> texture {
>> SnowTex0
>> interior {
>> fade_distance 2
>> fade_power 3
>> ior 1.45
>> caustics 1.0
 a
> volume.
to
n
> a 4D+time world.
> Alain
