POV-Ray : Newsgroups : povray.general : Re: Shaders in Pov-RAY - was - Calling external Math functions from .dll or .so Server Time
18 Feb 2025 18:10:31 EST (-0500)
  Re: Shaders in Pov-RAY - was - Calling external Math functions from .dll or .so (Message 1 to 10 of 11)
Subject: Re: Shaders in Pov-RAY - was - Calling external Math functions from .dll or .so
Date: 14 Feb 2005 18:40:11
Message: <Xns95FE6B991349raf256com@203.29.75.35>
abx### [at] abxartpl news:pag1115prp4beqv17lf3e4kpi931ei1opm@4ax.com
[I started a new thread because its quite different subject then innitialy]
> Could you name all those modern raytracers which are written in C++,
> support lodable plugins compiled to machine code, exists in builds for
> Mac, Windows nad *nixes and support all the possible CPU architectures
> where mentioned OS-es are working? Best with similar set of features
> as in POV-Ray. There must be many of them which draw the standard you
> refer here.
Most (all "big" ?) rayteracers allow plugins, in example LightWave on with
I had worked for a short while AFAIR allowed own shaders and it worked on
Win32 and Linux (and probably also on other architectures, simmilar to
Pov-RAY).
Why not take example from in example OpenGL and implement own C-based
shading language?
And yes, this *will* be *portable*. 100% portable - such shader would be
just ordinarly interpreted (simmilary as #macro's are now), and
in *addition* it *might* be also pre-compiled while parsing scene to
speedup rendering.
That way Pov-RAY could expand rapidly, probably better then with just
macros - such "shaders" could be much much more flexible, would work
faster, will be portable etc.
Collections of them could be a part of MegaPOV, and perhaps after some
testing and standarization they could be precompiled and placed in official
PovRAY as new pigment functions, better radiosity algoritms and so on.
In general - I fell that current core Pov-RAY code discouraged users to
donate code more advanced then pigments or macros. "Shaders" could be
natural way to add much more.
In example, to write AOI pigment, one dont have to dig into "raw", quite
poor documented C code with now HOWTOs (for beginners, or developers that
just dont have so much time to study entire code for days).
He just write simple function that returns a float based on normal of
surface in that point etc.
Or to write blurring shader, example source might look somewhat like this:
#shader MyBlur type "pigment-shader"
PovColor Function(texture tex)
  PovColor c;
  c += tex.pigment.getColor(tex + x);
  c += tex.pigment.getColor(tex - x);
  c += tex.pigment.getColor(tex + y);
  c += tex.pigment.getColor(tex - y);
  c += tex.pigment.getColor(tex + z);
  c += tex.pigment.getColor(tex - z);
  return c / 9;
sphere {
  0 10
  pigment { bozo shader{MyBlur} }
So this is a shader that works on top of pigment. There could be several
shaders, we can write additional two:
#shader Invert type "pigment-shader"
  PovColor Function(texture tex) {
    return PovColor(1,1,1) - tex.pigment.getColor(tex);
and then use
object { MyObject pigment { crackle shader{Blur} shader{Invert} } }
Then crackle pigment would be blurred, and then inverted.
Ofcourse the shader can create pigment, not just modify it:
  PovCol Function(texture tex) {
    PovColOne r = // ... here goes Apache's / Slime's formula
      // for neat 4D noise function, or some improved noise generator
    return PovCol(r,g,b);
Also shaders could be used for normals. Next step would be to allowe them
in more places, like to define rays from camera, to use them in shadow
calculations, and so on and so on.
So - plugins do not have to be unportable precompilled platform dependent
.dll's that Thorsten is so "afraid of".
That way it would gave greate flexibility, without need to hard-code every
such idea into source code of POV-Ray, with will be faster to
test/develope, and... more portable (that is - peoples could share such
code same as code of #macro currently)
http://www.raf256.com/3d/
Computer Graphics
Date: 14 Feb 2005 19:14:16
Message: <42113ed8@news.povray.org>
And one - as you know - that has also been discussed to death numerous times
before.  It also been said numerous times before that something along these
lines is in consideration for some future version of POV-Ray.
	Thorsten
Date: 14 Feb 2005 19:23:29
Message: <Xns95FEE1088A74raf256com@203.29.75.35>
tho### [at] trfde news:42113ed8@news.povray.org
> times before.  It also been said numerous times before that something
> along these lines is in consideration for some future version of
> POV-Ray.
OK, so that was some random ideas, sugestions, etc - or other group is
better for such discussions?
Computer Graphics
Date: 14 Feb 2005 23:15:37
Message: <42117769$1@news.povray.org>
Having looked up what shaders are, the question springs to mind:  why do
you need a plugin to work with the texture{} or material{} code, which
afaik can do what these other applications' shaders do?
Tim Cook
Version: 3.12
Date: 15 Feb 2005 01:03:54
Message: <421190ca$1@news.povray.org>
"Tim Cook" <z99### [at] bellsouthnet> wrote in message
news:42117769$1@news.povray.org...
Well, shaders allow greater control over what can be done... they allow you to
implement new patterns and surface interactions that aren't currently supported
as inbuilt patterns and finishes, etc.
For example, you might want to create a special "matte" shader that "punches
through" other objects to the background.
Lance.
thezone - thezone.firewave.com.au
thehandle - www.thehandle.com
Date: 15 Feb 2005 03:16:42
Message: <gib3111s1mbru0og4puuhsc69t6298ssbc@4ax.com>
On 14 Feb 2005 18:40:11 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> Pov-RAY).
Really? Let's order page for lightwave shaders:
http://www.shaders.org/ifw2_textures/order.htm
Why there are separated orders for different architectures? Must be because
Lightwave has very portable shaders.
ABX
Date: 15 Feb 2005 05:20:19
Message: <Xns95FE73400DBDraf256com@203.29.75.35>
abx### [at] abxartpl news:gib3111s1mbru0og4puuhsc69t6298ssbc@4ax.com
Heh, typo, I ment light _Works_,
http://download.graphisoft.com/ftp/techsupport/documentation/developer_docs
/BasicLibraryDoc/LightWorksIntegration/LW_Parameters.html
http://www.lightwork.com/lw_home.htm
Computer Graphics
Date: 15 Feb 2005 06:05:38
Message: <gbl311hje9p6emti3g870jeesagim6k9qk@4ax.com>
On 15 Feb 2005 05:20:19 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
"Cross-platform plug-in shaders are supplied as platform-independent bytecode
that is executed by the LightWorks bytecode interpreter and will therefore
work on all the platforms supported by LightWorks. Native plug-in shaders are
provided in ‘object code' form compiled for a particular platform, for example
DLLs for Windows or Bundles for Macintosh."
Well, this is behind POV-Ray standard which distributes shaders in one unified
and portable form of source of functions and translates it to bytecode or
machinecode at runtime. And we don't have to buy any SDK to write own shader.
Is this that opensource advantage you refered earlier?
ABX
Date: 15 Feb 2005 10:32:11
Message: <Xns95FEA822E86DDraf256com@203.29.75.35>
abx### [at] abxartpl news:gbl311hje9p6emti3g870jeesagim6k9qk@4ax.com
> unified and portable form of source of functions and translates it to
> bytecode or machinecode at runtime. And we don't have to buy any SDK
> to write own shader. Is this that opensource advantage you refered
> earlier?
LightWorks is not OpenSource.
Computer Graphics
Date: 23 Feb 2005 11:19:21
Message: <421cad09$1@news.povray.org>
>> why do you need a plugin to work with the texture{} or material{}
>> code, which afaik can do what these other applications' shaders do?
> allow you to implement new patterns and surface interactions that
> aren't currently supported as inbuilt patterns and finishes, etc.
> "punches through" other objects to the background.
Or a pigment that changes colour depending on the angle between the surface
normal and the viewer.
