POV-Ray : Newsgroups : povray.general : [stupid q.] isosurface bounding Server Time
25 Nov 2025 06:48:29 EST (-0500)
  [stupid q.] isosurface bounding (Message 1 to 10 of 12)
Subject: [stupid q.] isosurface bounding
Date: 27 Oct 2002 12:32:05
Message: <Xns92B4BC433A291raf256com@204.213.191.226>
Hello,
i'm a little bit confused, probably I just did soem very stuid bug, and I'm
to tired to find it...
My isosurface objects... disapare, where I set unnesesarly too big bounding
box, like :
isosurface {
  function { x*x + y*y - 1 }
  contained_by { box { -s, +s } }
  accuracy 0.001
  max_gradient 4
for s=2.0 everything is o.k.
for s=3.5 cylinder have holes
for s=6.0cynlinder dissapeare totally
why ?
also : .b.images .animation .source*
Subject: Re: [stupid q.] isosurface bounding
Date: 27 Oct 2002 12:57:50
Message: <Xns92B4C0A0D1B5Craf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
> isosurface {
>   accuracy 0.001
>   max_gradient 4
After rendering s=5.04
  Warning: The maximum gradient found was 10.996, but max_gradient of the
  isosurface was set to 4.000. The isosurface may contain holes!
  Adjust max_gradient to get a proper rendering of the isosurface.
But... for s=42 :
  Warning: The maximum gradient found was 87.374, but max_gradient of the
  isosurface was set to 15.000. The isosurface may contain holes!
so... shat is the real max_gradient for this (tryvial) function ?
Shouldn't real max_gradient be same for all bounding boxes ?
Date: 27 Oct 2002 13:13:00
Message: <Xns92B4C332DBF10raf256com@204.213.191.226>
isosurface {
  function { min(1,max(-1,x*x + y*y - 1))  }
  accuracy 0.001
  max_gradient 4
  pigment { rgb <1,.2,.2> }
  finish { specular 1 roughness 0.03 reflection .5 }
Adding min / max (clip) makes this object works for any 's' value.
Maybe clipping function value into range -1 .. +1 (or threshold-e ..
threshold+e where e is i.e. 1e-3) is a good idea ? Or not ?
AFAIK when using min(+e,max(-e, f(x,y,z) ))
  bigger 'e' values lead to faster rendering, but on the other hand - need
bigger max_gradient.
  smaller 'e' - vice-versa
Maybe it is worth better researching ? I will try to do it in spare time.
Does anyone have some somplex isosurfaces formulas that he may shere with
me (for testing purposes) ? TIA :)
Date: 27 Oct 2002 13:13:16
Message: <3dbc2cbc@news.povray.org>
In article <Xns### [at] 204213191226>, "Rafal 'Raf256' Maj"
<raf### [at] raf256com> wrote:
> so... shat is the real max_gradient for this (trivial) function ?
Well, it is.  Of course POV-Ray only determines the gradient inside the
finite bounding box.  As you can easily see from the function, increasing
the bounding box size will also increase the gradient...
No.
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Oct 2002 13:18:56
Message: <3dbc2e10@news.povray.org>
The function's gradient increases farther away from the origin. That's
because it's a function related to the distance from the origin *squared*,
which gets bigger faster as you look at it farther from the origin. (Just
like y=x^2.)
If you want to use this function far away from the origin, it may actually
be faster to make it
function { sqrt(x*x + y*y) - 1 }
Since then the function will have a max_gradient of 1 *everywhere*.
In addition, since the cylinder never goes out more than 1 unit in the X or
Y directions, you may want to switch your contained_by box to
contained_by { box { <-1,-1,-s>, <1,1,s> } }
 - Slime
[ http://www.slimeland.com/ ]
Date: 27 Oct 2002 13:27:54
Message: <chrishuff-EC5BB2.13211627102002@netplex.aussie.org>
No. You obviously don't know what a gradient is...it is the slope, or
"rate of change" of the function. The gradient of your function
increases in the x and y directions, so bigger bounding boxes require
higher max_gradient values. If you don't increase that value, the solver
fails to find a surface.
http://tag.povray.org/
Date: 27 Oct 2002 13:34:25
Message: <Xns92B4C6D516567raf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in news:chrishuff-
EC5### [at] netplexaussieorg
I do, ony I thought that only "vissible" (f(x,y,z) > threshold) part do
matter.
Where can I find detailed explenation of how solver works, best - with some
step-by-stem examples how he do it ?
Date: 27 Oct 2002 13:55:06
Message: <chrishuff-327FD4.13482827102002@netplex.aussie.org>
> matter.
If it knew the intersection, it wouldn't need the max_gradient to
compute it. The whole area inside the bounds shape matters.
The source code.
Date: 27 Oct 2002 14:07:21
Message: <3dbc3969@news.povray.org>
That won't help you finding the gradient of a function in advance.  To
determine the gradient of a function in advance you will need a good math
book, not a detailed description how to find isosurface intersections in
POV-Ray.  In particular a step-by-step example won't possibly help you if
you don't understand the math behind it -- which I assume you don't because
you don't seem to know what a gradient is.  Math books explaining how to
find the gradient of a function should be available in ever library.  A good
selection should be available in your local university library.  However, if
you don't know what a derivative is, you either did not learn it in school
or you have not yet learned it in school.  Either way you will have to
(re)learn it to understand the topic...
    Thorsten
Date: 27 Oct 2002 14:30:57
Message: <3dbc3ef1@news.povray.org>
It's mostly a bad idea, especially for small e it will take very long. You
better try to fit the bounding box as tight as possible around the surface.
With such a clipping you remove information of the function and introduce
unsteadiness. So it shows a weakness in the algorithm when doing this
speeds the rendering up.
- Micha
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
