POV-Ray : Newsgroups : povray.general : to litle precision ? Server Time
22 Apr 2026 17:07:31 EDT (-0400)
  to litle precision ? (Message 1 to 10 of 35)
Subject: to litle precision ?
Date: 7 Aug 2002 21:34:50
Message: <Xns926423CF66ED8raf256com@204.213.191.226>
I have a simple scene that shows some artefacts, this error is easy to
reproduce, so I will just describe it :
- I have height field, scaled by <20,5,20>
- I have box sized about 0.03
- I have a point light source, that is outside box, in distance of 0.001
from box
1. when I'm using 2048x2048 hf, then all shadows have very heacy random
black pixels instead of shadow. 512x512 HF is ok.
2. when distance from box is 0.01 - it's ok when it's 0.001 - I have random
spots
both errors are caused from problems with numbers like 0.001 and smaller
used togeather with another small shapes (hf triangles - 20/2048)
when I changed scale of HF to <2000,500,2000> - everything is ok
So :
1. I will see is this error only connected with HF or with all shapes
2. how about generate 2 binary distributions of POV - second executable
file will have extra accuarity (by cost of speed) ?
I have Win98, PovRAY 3.5,  Athlon 1,7
Subject: Re: to litle precision ?
Date: 7 Aug 2002 21:48:02
Message: <3d51cdd2$1@news.povray.org>
What you've described sounds to me like a floating point accuracy issue.
This is likely not a cause of speedups, but rather the fact that at some
point a number becomes too small to be held in whatever data type they're
holding numbers in, so it gets rounded to zero, which causes problems. Since
it's a floating point accuracy problem, and there are no *approximations*
occuring here, there's no way to sacrifice speed for accuracy.
As you've discovered, uniformly scaling the scene to be larger (thereby
bringing the numbers farther from zero) can sometimes help. (Of course, if
you scale *too* large, the same thing happens the other way around - numbers
too big to be held accurately.)
 - Slime
[ http://www.slimeland.com/ ]
Date: 8 Aug 2002 05:16:04
Message: <Xns926472032A5E1raf256com@204.213.191.226>
"Slime" <slm### [at] slimelandcom> wrote in news:3d51cdd2$1@news.povray.org
>> executable file will have extra accuarity (by cost of speed) ?
> issue. This is likely not a cause of speedups, but rather the fact
> that at some point a number becomes too small to be held in whatever
> data type they're holding numbers in, so it gets rounded to zero,
yes,
> Since it's a floating point accuracy problem,
> and there are no *approximations* occuring here, there's no way to
I was thinking abut changing float to double in sources.
In fact, this is tryvial to modify sources that way, best - change all
"float" into "tMath" and then add some precision.h to each file :
#if version_precision=0
  typedef tMath float;
#if version_precision=1
  typedef tMath double;
#if version_precision=2
  typedef tMath long double;
1 - standart using
2 - using with small objects (when user is to lazy to scale up scene), or
with final render of realy complex images
3 - for very special usage, like huge scene - i.e. Earth, with model of
human, and animation of i.e. Spaceship - it starts on earth looking at
human 0.1 units, and ends on orbit looking on 1e6 sphere
so... can someone just re-compile pov with this little change ?
Date: 8 Aug 2002 05:28:10
Message: <msd4lugammihk3s5itt11ou6h7a86kq7k6@4ax.com>
On 8 Aug 2002 05:16:04 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
POV already use double for calculations.
Float is used for color values only iirc.
> "float" into "tMath" and then add some precision.h to each file.
Can someone force you to do it yourself? You have linux and windows, right ?
You have compilers installed, right ? You have C skills, right ? You have time
to make ideas, right ? Then I really don't understand your stiff resistance to
not compile yourself. And please don't write "I don't like to modify source
from other authors" becouse we can simple answer "We don't like to implement
ideas from other authors". Is it laziness in your case ?
ABX
Date: 8 Aug 2002 05:33:44
Message: <3D523AF7.52E6D391@gmx.de>
Very funny.  If you had a quick look into the source you would have seen
POV-Ray uses double for all geometry data.  Instead of jumping to quick
conclusions it sometimes helps to look into the matter more deeply.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 8 Aug 2002 05:47:40
Message: <c0f4lugf5td0u587r8ksrfeucslu9sc4ms@4ax.com>
On Thu, 08 Aug 2002 11:33:43 +0200, Christoph Hormann <chr### [at] gmxde>
Anyway seems there can be some mistakes made by writers. I imagined there
should be only one instance of keyword 'double' in the whole package:
  #define DBL double
but seems authors left some 'double' in a few more places. Perhaps some of
them should be probably replaced with DBL. The same appear for float.
ABX
Date: 8 Aug 2002 07:39:15
Message: <3d525862@news.povray.org>
  POV-Ray uses floats for meshes (which gives me cold shivers... but on the
other hand it saves a huge amount of memory). I haven't checked, but it is
very possible that it also uses floats for heightfields.
Date: 8 Aug 2002 07:40:02
Message: <3d525891@news.povray.org>
  Look closer to how mesh vertices are stored...
Date: 8 Aug 2002 07:47:36
Message: <Xns92648BB15FDBEraf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3D523AF7.52E6D391@gmx.de
after looking deep into sources :
1. mesh use float's
2. my conclusion - low tollerance/epsilon/data precision product error was
in fact correct - from lighting.cpp :
 * "Small_Tolerance" is just too tight for higher order polynomial
equations.
 * this value should probably be a variable of some sort, but for now just
 * use a reasonably small value.  If people render real small objects real
 * close to each other then there may be some shading problems.  Otherwise
 * having SHADOW_TOLERANCE as large as this won't affect images.
#define SHADOW_TOLERANCE 1.0e-3
3. so I'm preparing a small unoficial version, with just litte boost-up of
some variables (lower tolerances, higher max max_trace_levels,
intersections, etc)
Date: 8 Aug 2002 07:56:45
Message: <7jm4lu4jg6nar7m8iud8osf1d7bgjdk9it@4ax.com>
On 8 Aug 2002 07:47:36 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> 1. mesh use float's
I can be wrong but I think they are only stored as floats. They are used in
intersection tests as doubles probably. So it is rather that vertices are
"aligned" to grid but still should be accurate the same way.
> intersections, etc)
I'm really interested in results.
ABX
