POV-Ray : Newsgroups : povray.general : Double finish? Server Time
24 Feb 2026 18:46:52 EST (-0500)
  Double finish? (Message 1 to 9 of 9)
Subject: Double finish?
Date: 1 Jul 2019 01:07:31
Message: <5d199513$1@news.povray.org>
Is it okay to have two finishes in the same texture? For instance:
texture
     finish { ambient LDXAmb diffuse LDXDif }
     finish { phong LDXPhong phong_size LDXPhongS reflection LDXRefl }
Thanks.
Michael
Subject: Re: Double finish?
Date: 1 Jul 2019 01:53:27
Message: <5d199fd7$1@news.povray.org>
Same question for normals.
e.g.
texture
	pigment { InPigment }
	finish { InFinish }
	normal { InNormal }
	normal { bumps InAmount }
Is having two normal statements in the same texture block okay?
Date: 1 Jul 2019 02:46:20
Message: <5d19ac3c$1@news.povray.org>
> e.g.
> texture
>      finish { InFinish }
>      normal { InNormal }
Have you tried to render this? If the render doesn't crash, it is ok I
suppose, but I frankly do not understand the advantage of this.
Date: 1 Jul 2019 06:03:58
Message: <5d19da8e$1@news.povray.org>
>> e.g.
>> texture
>>      finish { InFinish }
>>      normal { InNormal }
I am working with someone else's code, and am not sure how to tell if a
test scene is working or not.
Michael
Date: 1 Jul 2019 06:44:18
Message: <5d19e402@news.povray.org>
> e.g.
> texture
>      finish { InFinish }
>      normal { InNormal }
well i'd think it would be allowed (not crash) however last statement
would be in affect... an option if you /really/ want more than one:
http://wiki.povray.org/content/Reference:Layered_Textures
Date: 1 Jul 2019 14:10:10
Message: <5d1a4c82@news.povray.org>
> e.g.
> texture
>      finish { InFinish }
>      normal { InNormal }
In the first case :
texture
The first finish block should set the ambient and diffuse parameters.
The second should set phong highlights and reflection, hopefully without
affecting the ambient and diffuse.
May not work as intended. it would be better to merge the two.
In the second case, with two normal blocks, both are evaluated and the
results averaged into a single combined normal.
This is why, when you use multiple normals to get blurred reflection,
you need to average multiple whole textures and not only the normals.
Date: 4 Jul 2019 05:42:06
Message: <5d1dc9ee$1@news.povray.org>
I did not realize that. Before a few days ago I assumed multiple normals
in one texture would just throw an error.
Michael
Date: 4 Jul 2019 05:44:10
Message: <5d1dca6a$1@news.povray.org>
On 7/1/2019 6:44 AM, Jim Holsenback wrote:
> however last statement would be in affect...
Yeah, I was afraid the second block would cause the first block to be
ignored.
Michael
Date: 13 Jul 2019 05:21:50
Message: <5d29a2ae$1@news.povray.org>
In the case of LEGO bricks, each brick has a default slightly wavy
normal. Some sloped (inclined) bricks have a rough texture, however, and
an additional normal is applied to simulate this.
Does this make sense? Do you think this is realistic? Thanks.
Michael
