POV-Ray : Newsgroups : povray.general : Global handedness setting? Server Time
28 Sep 2024 22:20:22 EDT (-0400)
  Global handedness setting? (Message 1 to 10 of 12)
Subject: Global handedness setting?
Date: 22 Sep 2018 01:41:13
Message: <5ba5d5f9$1@news.povray.org>
Is there a way to change the handedness of a scene? I am doing a lot of
astronomy calculations, and they are all right handed.
If not, could such a setting be added to POV-Ray? Thanks.
Mike
Subject: Re: Global handedness setting?
Date: 22 Sep 2018 02:41:21
Message: <5ba5e411$1@news.povray.org>
There are different types of 'handedness' depending on which way the
different axis point. For Moray, which had z up and x right, the
following transform was used:
transform {
   scale <1, 1, -1>
   rotate x*90
Could be used from POV->Moray or from Moray->POV.
You may have to experiment because in some cases/applications the x or
the z axis can point the other way round. For instance, in Silo (which
is left-handed) the z axis points out of the screen. The same kind of
things may apply to right-handed applications I guess.
Date: 22 Sep 2018 04:01:48
Message: <5ba5f6ec$1@news.povray.org>
Am 22.09.2018 um 07:41 schrieb Mike Horvath:
In POV-Ray, handedness is defined by the camera. The defaults
    right     x*1.33
    up        y
    direction z
or, in v3.8.0
    up        y
    direction z
result in a left-handed coordinate system. For a right-handed coordinate
system, you have to set one (or all three) of these vectors to the
opposite direction, e.g.:
    direction -z
Note that this works even if you override the actual directions by using
`look_at`.
Note that this also has an effect on textures; you may need to mirror
planet image maps (e.g. using `scale <-1,1,1>` in the image map) to get
correct results.
I intend to add an explicit "handedness" parameter to the global
settings, for more intuitive switching, including a change in the
behaviour of UV mapping and image map projection types. But it'll be a
while until I get around to that.
Date: 22 Sep 2018 04:27:04
Message: <5ba5fcd8$1@news.povray.org>
You could put all that Matrix maths in the Bezier-patch torus thread to use.
http://www.techart3d.com/2016/02/convert-left-handed-to-right-handed-coordinates/
It was good to read clipka's reply. :)
Regards
Date: 22 Sep 2018 06:30:17
Message: <5ba619b9$1@news.povray.org>
>> of astronomy calculations, and they are all right handed.
> transform {
>    scale <1, 1, -1>
>    rotate x*90
The problem is that I'd have to do this *each time* I define an object
or perform a transform. Whereas a single keyword at the start of a scene
or in an INI file would be without worry.
Mike
Date: 22 Sep 2018 06:30:59
Message: <5ba619e3$1@news.povray.org>
Okay thanks.
Mike
Date: 22 Sep 2018 06:35:43
Message: <5ba61aff@news.povray.org>
> use.
What would I need to do for astronomy maths? In the equations I am using
the Z and Y axes are switched.
Also, how do I multiply matrix transforms in POV-Ray?
Mike
Date: 22 Sep 2018 11:21:59
Message: <5ba65e17$1@news.povray.org>
>> to use.
> Mike
The directions of rotations also seem reversed.
Mike
Date: 22 Sep 2018 11:55:24
Message: <5ba665ec$1@news.povray.org>
>> to use.
I might be able to help from a practical view. Blender uses the Y-up
coord system.
Here is the output of a uv mapped mesh2 sphere, declared as DATASphere
object {
     DATASphere
     matrix <1.000000, 0.000000, 0.000000,  0.000000, -0.000000,
-1.000000,  0.000000, 1.000000, -0.000000,  0.000000, 0.000000, 0.000000>
But you would either have to transform them individually or put them in
a union and transform that.
Regards
Date: 22 Sep 2018 13:45:34
Message: <5ba67fbe$1@news.povray.org>
>>> to use.
>> using the Z and Y axes are switched.
>> Mike
Not unexpected. That sounds like handiness. Try scale -1 * x
Regards
