POV-Ray : Newsgroups : povray.general : Transforming an image_pattern{} Server Time
27 Dec 2025 16:41:43 EST (-0500)
  Transforming an image_pattern{} (Message 1 to 10 of 11)
Subject: Transforming an image_pattern{}
Date: 29 May 2018 07:50:28
Message: <5b0d3e84$1@news.povray.org>
I keep bumping into a conundrum concerning image_patterns.
I have the following texture block:
   #declare MyTex =
     image_pattern {png "MyPattern.png" gamma 1.0 use_alpha
       map_type 0
       interpolate 2
       once
     texture_map {
       [0.0 pigment {rgbft <0,0,0,1,1>}]
       [1.0 pigment {
              bozo turbulence 1 lambda 3
              color_map {
                [0.0 rgbft <1,1,1,0,0>]
                [1.0 rgbft <1,1,1,1,1>]
            normal {crackle 0.15}
            finish {
              emission 1.0
              conserve_energy
              diffuse albedo 0.2
              specular albedo 0.2
              roughness 0.001
              reflection {
                0.0, 0.2
                fresnel on
                metallic off
To get the image_map used in the image_pattern in the right place and in
the correct orientation, I need to submit it/the texture to the
following transformation:
     translate <-0.5, 0, -0.5>
     rotate 90*x
     scale My_scale
     translate -My_scale.z/2*z
This is not a problem /per se/ if I apply the transformation to the
whole texture. However, for reasons I do not want to go into here
presently and to simplify the question, I would like to apply the
transformation /only/ to the image_pattern{} part of the texture. This
seems not to be possible, or am I wrong?
Thanks indeed for any thought on the matter.
Subject: Re: Transforming an image_pattern{}
Date: 29 May 2018 10:01:04
Message: <5b0d5d20$1@news.povray.org>
Am 29.05.2018 um 13:50 schrieb Thomas de Groot:
I would naively expect the following to work:
      image_pattern { ... }
      translate <...>
      texture_map {
but I suspect you tried that already.
The source code isn't immediately obvious about whether this would have
the desired effect or not, so my naive expectation might be out of touch
with reality.
If that doesn't work, I'm pretty sure no other construct will - except
of course for individually un-doing the transformation for each
component in the texture map:
    #local Trans = transform {
      translate <...>
      texture_map {
        [0.0 pigment { ... transform { Trans inverse } ]
        [1.0 pigment { ... transform { Trans inverse } ]
      transform { Trans }
Date: 29 May 2018 19:40:00
Message: <web.5b0de3eb14fd3a80a47873e10@news.povray.org>
>       translate <...>
>     texture {
>       texture_map {
>       transform { Trans }
Yes, it seems that something very similar (identical?) to that construction is
required.
Thomas, try this example; it *looks* like it works-- the image_map or
image_pattern IS transformed, whereas the colors/pattern in the texture map are
NOT (or rather, they are inverse-transformed to bring them back to the original
look. I think!)  I made some simplifications to your code, so I could understand
what I was seeing. And the 'use-alpha' feature is something I haven't played
around with, until now.
Aside: In your code example, you have emission at 1.0. Are you actually seeing
any effects of the NORMAL that way? I thought such an emission value would
eliminate the normal's appearance (due to it being a 'lighting-based' effect.)
#declare My_scale = 1*<.7,.5,.7>;
#declare TRA =
transform{
     scale My_scale
#declare MyTex =
     image_pattern {
       png "My_Pattern.png" gamma 1.0 use_alpha
       map_type 0
       interpolate 2
      // once
                   } // end of image_pattern
     transform{TRA}
     texture_map {
       [1.0 pigment {
              bozo // turbulence 1 lambda 3
              color_map {
                [0.4 rgb <1,0,0>]
                [0.6 rgb <0,1,0>]
                    } // end of pigment
            finish {
              emission 1.0
              conserve_energy
              diffuse albedo 0.2
              specular albedo 0.2
              roughness 0.001
              reflection {
                0.0, 0.2
                fresnel on
                metallic off
                         } // end of reflection
                    } // end of finish
             transform{TRA inverse}
                 } // end of texture_map
box{0,<3,3,.01>
texture{MyTex}
Date: 30 May 2018 02:54:48
Message: <5b0e4ab8$1@news.povray.org>
>      texture {
>        translate <...>
>        texture_map {
You will laugh, but no. I did not try that :-/ The heat must have addled
my braincells...
That works of course but...
> with reality.
the resulting effect is not entirely what I expected but that probably
is another hurdle I need to take next. Nothing to worry about. New
testing session in operation now.
>        translate <...>
>      texture {
>        texture_map {
>        transform { Trans }
Yes, that was something I tested, especially for the normal where the
result was crucial.
Thanks for putting me back on track! :-)
Date: 30 May 2018 03:01:37
Message: <5b0e4c51$1@news.povray.org>
>>        translate <...>
>>      texture {
>>        texture_map {
>>        transform { Trans }
> required.
The first suggestion by Christoph was correct and I somehow was blinded.
;-) I still need to get to what I want precisely though, which needs
more blood, sweat & tears from my part.
When satisfied, I shall post the image.
That emission is still an on/off addition from my part about which I
have not yet made up my mind. Not important for now.
Thanks for the thoughts!
[snip]
Date: 30 May 2018 19:40:01
Message: <web.5b0f358e14fd3a80a47873e10@news.povray.org>
> >>        translate <...>
> >>      texture {
> >>        texture_map {
> >>        transform { Trans }
> The first suggestion by Christoph was correct...
Yes, you're right (although with a slight change.) I had to do some more
experimenting, to see what I did wrong.
EACH index-entry in the texture_map needs the inverse transform, as Clipka
suggested. (I included only one, after your 2nd index-entry.) My way of coding
the entire construct is *slightly* different, though:
#declare MyTex =
     image_pattern {
       png "My_pattern.png" gamma 1.0 use_alpha
     transform{TRA} // THE MAIN TRANSFORM HERE
   texture_map {
       [0.0  texture{...} or pigment{...} etc
       [1.0 texture{...} or pigment...} etc
Thanks for giving me a 'push' to test this stuff (and to play around with the
use_alpha feature-- it may have some important implications for my 'city
buildings' scene.)
Date: 31 May 2018 02:48:49
Message: <5b0f9ad1$1@news.povray.org>
>>>>         translate <...>
>>>>       texture {
>>>>         texture_map {
>>>>         transform { Trans }
> #declare MyTex =
>     texture {
>       image_pattern {
>     texture_map {
This is a bit different! What you do here is (1) transform the
image_pattern, then, (2) and separately, inverse transform the
texture_map. That will give something very different I believe. The
transform should be moved down to the complete texture level, e.g.:
   image_map {}
   texture_map {
     [0.0 texture {} transform {TRA inverse}]
     [1.0 texture {} transform {TRA inverse}]
   transform {TRA}
Be sure too that all the transformations do the right thing when
'inverse' is used. In this case, unexpected results might occur I believe.
My original intention was to be able to transform the image_pattern I
needed, without touching the texture_map I had already defined for the
scene. Tunnel vision prevented me from seeing the obvious way to do that
(elementary truly). ;-)
In the mean time, I have ironed out most of the remaining problems and,
as the dust is slowly settling, I will soon be able to show the results.
> buildings' scene.)
Always happy to stimulate people. Thoughts, try-outs, conundrums from
the community are always most stimulating experiences for me, even when
I do not understand one iota from them :-)
Date: 31 May 2018 03:33:49
Message: <5b0fa55d$1@news.povray.org>
Am 31.05.2018 um 08:48 schrieb Thomas de Groot:
>> #declare MyTex =
>>     texture {
>>       image_pattern {
>>     texture_map {
> texture {
>   image_map {}
>   texture_map {
>   transform {TRA}
To the best of my knowledge, there is effectively no difference between
the two constructs. I would consider the latter more intuitive though,
for the very same reason you'd expect them to differ in effect.
Date: 31 May 2018 04:55:01
Message: <web.5b0fb7b514fd3a80a47873e10@news.povray.org>
> the two constructs. I would consider the latter more intuitive though...
Yeah, I eventually came to the same conclusion (and the two rendered results do
look identical; I don't see any difference at all.) The thing that seemed wierd
to me was placing *inverse* transforms before the 'regular' transform, in the
overall code. That looked... backwards (only from a 'linear-programming'
perspective-- or maybe just aesthetically!) But I was thinking in too 'linear' a
way ;-)
To answer Thomas's comment: The image_pattern construct seems to be a special
kind of 'thing' in POV-Ray-- composed of two *almost*-distinct parts (the
image_pattern part, and the texture_map part.) That's how I see it, anyway. Yet,
the fact that the main transform{} CAN go in either place-- and with the same
result-- is rather strange and interesting.
Date: 31 May 2018 06:57:44
Message: <5b0fd528$1@news.povray.org>
> way ;-)
I have learned something new then. I thought putting the transforms
/before/ the texture would /not/ affect the latter. Seems I am wrong in
this.
Hmm.... I have to reconsider some of my code then....
