POV-Ray : Newsgroups : povray.general : Cloud Surface Server Time
25 Feb 2026 01:16:27 EST (-0500)
  Cloud Surface (Message 1 to 10 of 22)
Subject: Cloud Surface
Date: 24 Nov 2017 02:43:37
Message: <5a17cda9$1@news.povray.org>
a question: is there any public source code that allows us to create
cloudy surfaces like that one in the attached photo? I want to do
something that I never did before: building cloud cities!
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Download 'cloud city.jpg' (50 KB)
Preview of image 'cloud city.jpg'
Subject: Re: Cloud Surface
Date: 24 Nov 2017 08:40:00
Message: <web.5a181ff99a2a53c1a6394f050@news.povray.org>
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> Hi,
> http://www.avg.com
Maybe it can be drawn by media(povray) to some extent. Cycles renderer of
blender should renders better because its volume rendering contains multiple
scattering calculations.
For a thin media like atmosphere, single scattering is in the majority, so
the media of Povray can simulate well. But cloud is heavy media, light
passing through it can scatter many times, most of the luminance from a cloud
is from the multiple scattering.
If you want to draw a cloud in PovRay, maybe scattering media + emission media
can do it, Or ... ?
Or subsurface scattering material, this feature of Povray calculate both single
scattering and multiple scattering in the substance, but scattering density of
the material is limited to constant.
Date: 24 Nov 2017 10:38:03
Message: <5a183cdb$1@news.povray.org>
Am 24.11.2017 um 14:37 schrieb And:
>> Hi,
>> http://www.avg.com
> can do it, Or ... ?
I doubt whether subsurface scattering can be employed to do the trick;
you probably won't get the same "fluffyness".
Date: 24 Nov 2017 14:10:00
Message: <web.5a186dbd9a2a53c19ae32810@news.povray.org>
> Hi,
> http://www.avg.com
Here is a little example scene for a cloud surface. Not the level like in your
picture but it's something you can start with.
http://news.povray.org/povray.text.scene-files/message/%3Cweb.5a186b419a2a53c19ae32810%40
image:
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a186c9e9a2a53c19ae32810%40
Date: 24 Nov 2017 14:57:43
Message: <5a1879b7$1@news.povray.org>
>> Hi,
>> http://www.avg.com
> image:
Yes, I think I can use those clouds. But I need to get that surface
following the round surface shape of a planet, is that possible?
http://www.avg.com
Date: 24 Nov 2017 21:21:06
Message: <5a18d392$1@news.povray.org>
>>> Hi,
>>> http://www.avg.com
>> image:
> http://www.avg.com
Yes. The onion and spherical patterns come to mind.
In your case, I think that onion with a colour_map going from high to
low would be better as you don't need to scale it as much : You can only
take the 10000th repetition
  of the pattern if you want.
Next, add some turbulence, possibly adding some other pattern(s).
Don't forget to make your media sufficiently dense.
Date: 24 Nov 2017 23:30:00
Message: <web.5a18f1a39a2a53c1a6394f050@news.povray.org>
> >> Hi,
> >> http://www.avg.com
> > can do it, Or ... ?
Maybe that is partially due to uniform scattering density in a object. However,
I do a test on this, post image here:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a186c9e9a2a53c19ae32810%40news.povray.org%3E/?mtop=418940&
moff=10
Date: 25 Nov 2017 03:00:00
Message: <web.5a19217d9a2a53c1a6394f050@news.povray.org>
> > Hi,
> > http://www.avg.com
> can do it, Or ... ?
I uploaded two images:
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a1917549a2a53c1a6394f050%40news.povray.org%3E/#%3Cweb.5a1
and
http://news.povray.org/povray.binaries.images/message/%3Cweb.5a191dbf9a2a53c1a6394f050%40news.povray.org%3E/#%3Cweb.5a1
Date: 25 Nov 2017 14:28:51
Message: <5a19c473$1@news.povray.org>
> and
Yes, I saw them. I actually responded to the IMAGES group thread. :-)
http://www.avg.com
Date: 25 Nov 2017 22:27:42
Message: <5a1a34ae$1@news.povray.org>
Is there a German offline HELP file for POV-Ray? The English version is,
due to its many English special terms, not so easy for me to understand.
http://www.avg.com
