POV-Ray : Newsgroups : povray.general : Object pattern and meshes: no go? Server Time
25 Feb 2026 01:16:59 EST (-0500)
  Object pattern and meshes: no go? (Message 1 to 8 of 8)
Subject: Object pattern and meshes: no go?
Date: 10 Oct 2017 03:31:47
Message: <59dc7763$1@news.povray.org>
Struggling with object patterns (using meshes) I came across the
following comment by Sam Benge in 2007 for his edge_pigment02.inc macro.
[quote]
And of course you can never use this with meshes. That is, not until
somebody figures out how to convince POV into turning a mesh into a
bona-fide object pattern...
[/quote]
Getting strange results myself, I wonder if this is still true for the
current versions of POV-Ray? Are meshes (still) unsuited for use with
object patterns?
Subject: Re: Object pattern and meshes: no go?
Date: 10 Oct 2017 07:45:00
Message: <web.59dcb225970ac703c437ac910@news.povray.org>
> object patterns?
Can you do a good CSG with the mesh?
If not, then maybe the mesh has problems.
If so, maybe use the CSG result for the object pattern...
Either way, C.Lipka et al will want to see visual or code example[s] to be able
to understand and assess the problem, and investigate further.
I mean, it's not like they sit around all day homonculusing...
I mean, at least I think they don't...
Date: 10 Oct 2017 08:59:02
Message: <59dcc416$1@news.povray.org>
Am 10.10.2017 um 09:31 schrieb Thomas de Groot:
> [quote]
> [/quote]
> object patterns?
Meshes should be fine _if_ they are properly closed _and_ have a
(non-zero) `inside_vector`.
Date: 10 Oct 2017 09:00:47
Message: <59dcc47f$1@news.povray.org>
Am 10.10.2017 um 13:42 schrieb Bald Eagle:
Not all day, no.
Date: 11 Oct 2017 02:42:42
Message: <59ddbd62$1@news.povray.org>
>> [quote]
>> [/quote]
>> object patterns?
Hmmm... All that has been provided for in my case (including what Bald
Eagle suggested). Still, this does not answer that cryptic note by Sam
back in 2007. As far as I know, we already did use proper mesh2, so what
does he mean?
Date: 11 Oct 2017 02:46:40
Message: <59ddbe50$1@news.povray.org>
>> object patterns?
It is a bit difficult to re-build the first floor of the Gutenbach house
in CSG... :-)  I was mainly interested in Sam's note and from
Christoph's answer I get even more puzzled. I shall investigate further
and report back.
Now that you mention it, I wonder...
Date: 11 Oct 2017 05:12:57
Message: <59dde099$1@news.povray.org>
Am 11.10.2017 um 08:42 schrieb Thomas de Groot:
>>> [quote]
>>> [/quote]
>>> object patterns?
> does he mean?
The use of `mesh2` vs. `mesh` has little to do with the use of
`inside_vector` (except that `mesh2` appears to have been the first to
support the keyword, but it has been added to `mesh` as well).
My guess would be that Sam didn't know about (or didn't remember) the
`inside_vector` keyword when he did his experiments.
Date: 11 Oct 2017 07:56:35
Message: <59de06f3$1@news.povray.org>
>>>> [quote]
>>>> [/quote]
>>>> object patterns?
>> does he mean?
Yes, that sounds plausible indeed.
As far as my experiments have gone presently, I see indeed no difference
between CSG and mesh objects where object patterns are concerned. So, I
have to go back to my own mesh to see what happens.
