POV-Ray : Newsgroups : povray.general : A simple request... Server Time
17 Nov 2025 08:44:43 EST (-0500)
  A simple request... (Message 1 to 10 of 20)
Subject: A simple request...
Date: 17 Dec 2013 03:00:28
Message: <52b0049c$1@news.povray.org>
with possibly large implications.
A commandline (I run linux) option to disable the pov-state file.
Why?
I render multiple test runs for an animation and all frames get stored on a
network, so the pov-state file gets stored on that same network.
I understand the value of the pov-state file because it allows one to
continue a render from whatever point in case of a mishap.
In my case, I'll simply restart the render at 1 frame before the mishap.
ps, I'm not a programmer so I don't know how involved a change like that
could turn out to be.
Ger
Subject: Re: A simple request...
Date: 17 Dec 2013 03:35:41
Message: <52b00cdd$1@news.povray.org>
Am 17.12.2013 09:00, schrieb Ger:
> Why?
Sounds like a reasonable request to me.
A quick glance at the code indicates that someone had already thought of
this, and all the necessary stuff seems to be there already, except that
it hasn't been hooked up to a command line option or ini file setting
yet. Two lines of code should get us going.
Suggestions for how to call the thing, anyone? Internally it is called
"BackupTrace", and it complements the existing "Continue_Trace" option
("+C", internally "ContinueTrace), so a suitable ini setting name might
be "Backup_Trace" (defaulting to true); the "+B" switch is already in
use though; "-BC" ("[disable] backup for +C") or "-CB" ("[disable] +C
backup") would still be open.
Date: 17 Dec 2013 03:42:36
Message: <52b00e7c$1@news.povray.org>
>> Why?
>> a network, so the pov-state file gets stored on that same network.
Maybe
+PS (default) turns it on, -PS turns it off.
Just a suggestion.
Ger
Date: 17 Dec 2013 03:56:20
Message: <52b011b4$1@news.povray.org>
Ger wrote:
> Maybe
ini file:
pov_state=[on/true/yes][off/false/no]
> Just a suggestion.
Ger
Date: 17 Dec 2013 04:57:57
Message: <52b02025@news.povray.org>
>> Why?
>> on a
The purpose of the pov-state is to allow for "+C"/continue. So what
about: "Disable_Continue" , "NoContinue" ("+NC" to have no saved data),
+SH (Sledge Hammer: "Trust me I know what I'm doing") ?
Or extending +C, such as:
 +C continue
 -C no continue
 +C0 no backup for ulterior continue
 +C1 backup for ulterior continue
I did not check about the availability of the names.
Just because nobody complains does not mean all parachutes are perfect.
Date: 17 Dec 2013 06:48:28
Message: <52b03a0c$1@news.povray.org>
Am 17.12.2013 10:57, schrieb Le_Forgeron:
Rather not; the general convention is that a feature is enabled with
"+FOO" and disabled with "-FOO", rather than enabled with "-NFOO" and
disabled with "+NFOO". Note that the feature in question here is the
ability to pick up an aborted render later with the "+C" switch - the
inverse logic can only be formulated as the suppression of that feature
to avoid the costs it imposes, so it isn't a feature in itself.
>   +C continue
>   -C no continue
Magic numbers and mixing with the other switch? Uh, no please.
Again, note the generic convention for enabling and disabling features,
which use leading "+" and "-" to insicate whether a certain feature is
to be enabled or disabled; let's not mess this up by giving similar
semantics to trailing numbers.
Also, let's not try to force two distinct choices, to be made in two
entirely distinct situations, into one and the same command switch.
There is one choice to be made by the user whether he wants to be able
to abort the render, so that he /may/ continue it later. This choice
must be made /before/ a render is aborted.
There is another choice to be made by the user whether he wants to
continue a previously aborted render, or restart from scratch. This
choice must be made /after/ a render is aborted.
Although the features interact, the choices are clearly distinct, and
made in different situations, so there should be distinct ways of
communicating these choices to POV-Ray.
Date: 17 Dec 2013 07:36:09
Message: <52b04539@news.povray.org>
Is there a way to specify the location? There's value in having the
pov-state file written to a different directory to the output file ---
for example, a local drive rather than a network drive in the OP's case.
It would then be trivial to extend to 'write nowhere'.
┌─── dg@cowlark.com ─────
http://www.cowlark.com ─────
│ "There does not now, nor will there ever, exist a programming
│ language in which it is the least bit hard to write bad programs." ---
│ Flon's Axiom
Date: 17 Dec 2013 09:36:09
Message: <52b06159$1@news.povray.org>
Am 17.12.2013 13:36, schrieb David Given:
As I said, the "write nowhere" feature is already there behind the
curtains, it's just not exposed via a command line switch yet.
Implementing a way to write to a different directory would need more effort.
Date: 19 Dec 2013 09:56:38
Message: <52b30926$1@news.povray.org>
> effort.
about the entry: what about
+AC / -AC : Allow_Continue = true/false ?
(because I prefer to see it as a functionality rather than a technical
details: should the pov.state file mechanism be changed for something
else, the +C would still be the command to use to continue an aborted
render)
Looking at available options, B is parameterless, BM & BS exist.
C is parameterless and alone, so BT , CT and other are possible.
From the option name: BT (BackupTrace) seems natural.
Yet, I would prefer AC (and it is possible too).
Date: 30 Dec 2013 05:24:22
Message: <52c149d6$1@news.povray.org>
Using the chainsaw approach I cut out all code that had to do with
BackupTrace, ContinueTrace and Pov_state and all that fun, I have a
working pov version (dunno how working yet) that doesn't bs around with
pov-state files and produces the results I do like.
And if anyone would like for me to post the resulting code, rest
assured, I won't post it. The chances for it to eat your children and/or
your in-laws is just too great.
