POV-Ray : Newsgroups : povray.general : light_group and photons Server Time
17 May 2026 16:53:02 EDT (-0400)
  light_group and photons (Message 1 to 6 of 6)
Subject: light_group and photons
Date: 16 Sep 2012 08:55:15
Message: <5055cc33$1@news.povray.org>
Struggling a bit to light my amethyst ring (posted in p.b.images) and
decided to try a light_group. I have:
union {
   light_group {
     object { Stone material { StoneMaterial } hollow on }
     light_source { Stone_Light }
     #if (UsePhotons)
       photons {target reflection on refraction on collect off }
     global_lights off
   object { Band material { BandMaterial }
The stone light has reflection/refraction set to on and the scene light
has them turned off, but I get: Photon Warning: Could not save photon
map - no photons!
Is this even possible, or am I on a fools errand?
Subject: Re: light_group and photons
Date: 16 Sep 2012 13:20:44
Message: <50560a6c$1@news.povray.org>
> union {
>    light_group {
>      #if (UsePhotons)
>      #end
>      global_lights off
> map - no photons!
How can you shoot protons to the light_source?
I think that you should put the photons block with the Stone object and
have none for the actual light_source. The light will use the default
photons setting where both reflection and refraction are enabled.
By the way, unless your stone contains some media, the hollow attribute
is useless.
Date: 17 Sep 2012 07:28:17
Message: <50570951$1@news.povray.org>
>> union {
>>    light_group {
>>      #if (UsePhotons)
>>      #end
>>      global_lights off
>> map - no photons!
LOL ... frustrated and snagged wrong example.
Already tried that incantation. Still think photons and light_group is a
no go. I'll prepare a better example when I get a chance.
> is useless.
poseray did that just didn't bother removing it
> Alain
Date: 17 Sep 2012 12:04:52
Message: <50574a24@news.povray.org>
OK ... below is a simplified scene used to show the problem I'm having.
The scene is initially setup with the Key_Light as the photon source and
/without/ the light_group ... it shows that indeed it does shoot photons
properly.
Now remove comments from around the light_group code in the Ring
definition, and in the Key_Light change reflection/refraction from /on/
to /off/ (now I want the Stone_Light to be the photon source) and see
what I mean.
Maybe not related but why does the stone shadow /still/ appear to be
coming from the Key_Light and /not/ the Stone_Light ... I have
global_lights set to off in the light_group!
Here's the scene file:
// render using: povray +p +w1120 +h630 Work.pov
#version 3.7;
#default {finish {ambient 0 emission 0 diffuse 0.6}}
#declare PQ = 1;
#if (PQ > 0)
   #declare UsePhotons = yes;
   #declare PhotonRun = yes; // change to "no" to reuse a map
#switch (PQ)
   #case (0)
     #declare UsePhotons = no;
   #break
   #case (1)
     #declare S_val = 0.1;
     #declare T_val = 5;
		#declare C_val = 15000;
   #break
   #case (2)
     #declare S_val = 0.025;
      #declare T_val = 10;
		#declare C_val = 30000;
   #break
   #case (3)
     #declare S_val = 0.00625;
     #declare T_val = 50;
		#declare C_val = 60000;
   #break
global_settings {
	max_trace_level 64
	adc_bailout 0.00001
	noise_generator 3
	assumed_gamma 1.0
	#if(UsePhotons)
		photons {
			spacing S_val
			autostop 1
			max_trace_level T_val
			count C_val
			#if (PhotonRun)
				save_file "Work.ph"
			#else
				load_file "Work.ph"
	perspective
	location <0,0,-10>
	rotate x*35
	rotate y*10
	look_at <0,1,0>
	right  x*4/3
	direction 1*z
#declare Key_Light =
light_source {
	#declare LightColor = srgb 1;
	0, LightColor
	translate <0,0,-15>
	#if (UsePhotons)
		photons { reflection on refraction on }
// -- The Stone Light ( in a light_group )
#declare Stone_Light =
light_source {
	0, LightColor
	translate <0,2,5>
	looks_like {sphere {0,0.125 pigment { srgb <1,1,0>}} }
	#if (UsePhotons)
#declare Stone =
sphere { 0,1
	material{
	texture{
		pigment{
			srgbf <0.4980, 0.2902, 0.4235,1>
		normal { facets coords 1 size 0.25}
		finish{
			specular 1
       			roughness 0.01
			diffuse 0.6
			reflection{
				srgb <0.4980, 0.2902, 0.4235>*0.1, srgb <0.4980, 0.2902,
0.4235>*0.125 fresnel on
	interior {
		ior 1.75
		fade_distance 2
		fade_power 1001
		fade_color <0.4980, 0.2902, 0.4235>
		#if (UsePhotons)
			caustics 1.0
			dispersion 1.05
			dispersion_samples 10
	#if (UsePhotons)
		photons { target reflection on refraction on collect off }
#declare Band =
torus { 3,0.25
	material{
		texture{
			pigment{
				srgb <0.8100,0.7100,0.2300>
			finish{
				specular 0.8
				roughness 0.1
				diffuse 0.6
				metallic
				brilliance 5
				reflection{srgb <0.8100,0.7100,0.2300>*0.75, srgb
<0.8100,0.7100,0.2300>}
#declare Ring =
union {
	//light_group {
		object{
			Stone
			#if (UsePhotons)
		//light_source { Stone_Light }
		//global_lights off
	object{
		Band
		translate x*3.95
	translate <-3.95/2,2,0>
object { Key_Light rotate x*45 rotate y*30 }
background { srgb 1 }
plane { y,0 pigment { srgb 1 } }
object { Ring }
Date: 20 Sep 2012 01:34:40
Message: <505aaaf0@news.povray.org>
> properly.
> what I mean.
It looks like photons from a light_group are indeed broken. They don't
even show on an added object added in the light_group placed to receive
them.
Any object can intercept light from any light and cause shadows. The
appartenance to a light_group don't change that.
Also, any object outside the light_group can cause shadow on an object
of a light_group if it's situated between the light and it's associated
object(s).
The only objects that don't cause shadows are those having an explicite
no_shadow attribute.
The only light that don't cause any shadow are shadowless ones. They
also never cause any highlight and, by default, never cast any photons.
I don't know if you can force a shadowless light to cast photons by
adding photons{refraction on reflection on}.
Remove caustics 1.0. It's only good at simulating caustics under a body
of water on a relatively flat and level surface.
There is no reason to remove the photons block in a non-photons scene or
in a test render without photons. In this case, the photons block will
simply be ignored.
In the global_settings, you must NOT use both spacing and count in the
photons block. Use only one OR the other.
autostop 1 is the same as not using autostop.
Date: 20 Sep 2012 08:28:00
Message: <505b0bd0$1@news.povray.org>
>> properly.
>> what I mean.
> them.
> object(s).
> simply be ignored.
thanks for the sanity check (i'll file a bug report) and the additional
information is also useful as photons use is one of my weak areas.
