POV-Ray : Newsgroups : povray.general : filling a bottle with fluid Server Time
29 Jul 2024 08:12:34 EDT (-0400)
  filling a bottle with fluid (Message 1 to 10 of 14)
Subject: filling a bottle with fluid
Date: 19 Aug 2012 22:55:00
Message: <web.5031a6586f2d14c8ad797add0@news.povray.org>
I've built a soda bottle with a bezier_spline lathe object.  It's clear glass,
hollow and has a wall thickness.  To fill the bottle with soda I am creating
another lathe object inside the bottle.  To prevent a coincident surface problem
should I scale the soda larger to push the soda into the bottle wall?  Any
better ways to fill a bottle with fluid?
Subject: Re: filling a bottle with fluid
Date: 19 Aug 2012 23:45:01
Message: <web.5031b29cda492adad19b0ec40@news.povray.org>
Here's what I usually do with such things. Make a lathe, subtract a slightly
smaller lathe to create a hollow object, then place a slightly smaller lathe
(just smaller than the difference) inside with appropriate media definitions. In
all, you should have 3 of the same lathes, just different sizes.
Date: 20 Aug 2012 02:37:45
Message: <5031db39$1@news.povray.org>
Vicious: no wall thickness, not hollow (per english, hollow keyword is
allowed, even recommended, and setting interior also ) :
 # plain block of glass in which you put a block of liquid and finally
you use a difference with a third block to force some air and free
surface (difference on the union of the two previous block).
Shenanigan: the shape of air must not have more than one line in common
with the liquid. (i.e. 1D intersection in 3D is ok, but if it get some
area, you're doom again with coincident surface)
E.g: if the liquid is a cylinder, the air must NOT be a cylinder of same
diameter & axis. It can be a superellipsoid. (Bonus: the superellipsoid
allow to also have a meniscus, for concave meniscus (i.e. not for mercury))
Using lathe & sor is of course a fine solution too. (but no common part!)
A good Manager will take you
through the forest, no mater what?
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 20 Aug 2012 05:52:20
Message: <503208d4$1@news.povray.org>
Am 20.08.2012 08:37, schrieb Le_Forgeron:
Now that's some ingenious solution! I never thought of that.
Date: 20 Aug 2012 10:40:00
Message: <web.50324b2fda492ada9949baae0@news.povray.org>
With the liquid being slightly smaller than the cavity won't the air space
between the liquid and the wall be visible in some slight way?
Date: 20 Aug 2012 12:40:00
Message: <web.503267e5da492adad19b0ec40@news.povray.org>
Short answer: no
Long answer: no, if the camera is sufficiently far away and the "liquid" is
scaled very closely to the container. However if the camera is very close to the
container, then maybe.
Let's say your camera is 1 unit away from your bottle. You place a bottle at
<0,0,0>, then put the liquid in by scaling your bottle model by .9. You will see
a gap. However, if you scale the bottle model by .999999999 you probably won't
see the gap.
Date: 20 Aug 2012 22:30:01
Message: <web.5032f1c2da492adaad797add0@news.povray.org>
<snip>
> Short answer: no
> see the gap.
Ok but why not just scale 1.00001 and push the liquid into the bottle wall?
Doesn't that eliminate both problems?
Date: 21 Aug 2012 12:45:00
Message: <web.5033ba63da492adad19b0ec40@news.povray.org>
> <snip>
> > see the gap.
I don't think I've ever tried that. Try them both out, and see which one works
better.
Date: 21 Aug 2012 19:05:02
Message: <5034141e$1@news.povray.org>
You won't see the gap itself if it's small enough.
BUT there will be extra reflections and highlights.
There will be broader total internal reflection from the glass object.
There will be total internal reflection from the liquid that should be
totaly absent.
Those two effects are caused by the very small gap. There is no way to
prevent those.
Making the liquid slightly larger also don't help as it just change the
places where those problem will manifest themselves.
There will be reflection from the surfaces. Those can be reduced by
tweaking the finishes of the glass and the liquid. It involve having a
different finish only in the areas where the glass and liquid are in
contact. Tricky but possible.
Date: 22 Aug 2012 04:12:49
Message: <50349481$1@news.povray.org>
No. See image in p.b.i.
