POV-Ray : Newsgroups : povray.general : Alpha channel affecting highlighting Server Time
24 Aug 2025 17:31:39 EDT (-0400)
  Alpha channel affecting highlighting (Message 1 to 9 of 9)
Subject: Alpha channel affecting highlighting
Date: 18 May 2012 17:59:26
Message: <4fb6c63e$1@news.povray.org>
I've just tried out the +UA option to turn on alpha channel in the output
based on the background.  I'm using a very simple image of an object
that is not transparent, and everything else is background.  The background
part is coming out transparent, however the object's highlighting is much
dimmer with the alpha channel on.
I've tried turning up the specular crazy high, and I just end up with a large
grey spot where a large highlight should be (but it isn't getting alpha channel
stuck in there, i.e.  nothing is showing through where the highlight is).
I can't imagine why this would be happening.  I also looked for known
bugs (I'm using version 3.6 at the moment) but couldn't find anything.
It does seem there's a bug related to highlighting on objects that DO
have some transparency, but as I said, my test object is totally
opaque.
Any help is appreciated.
    tom
Subject: Re: Alpha channel affecting highlighting
Date: 18 May 2012 18:38:28
Message: <4fb6cf64$1@news.povray.org>
Am 18.05.2012 23:59, schrieb Thomas A. Fine:
> Hi,
> opaque.
I've never heard of anything like that happening in 3.6, although it's
been out quite a while now, and the thing you're doing sounds like a
standard use case, so I'm a bit puzzled about this one.
Does this affect both the render preview and the generated image file?
Can you post the complete scene? What output file format are you using?
What's your exact version of POV-Ray?
Date: 18 May 2012 23:04:22
Message: <4fb70db6$1@news.povray.org>
In article <4fb6cf64$1@news.povray.org>,
Yes, both the preview and the generated file - PNG format.  My exact version
is:
Persistence of Vision(tm) Ray Tracer Version 3.6.1 (/usr/bin/g++-4.0 4.0.1 @
 i386-apple-darwin9)
This is an unofficial version compiled by:
 MacPorts
 The POV-Ray Team(tm) is not responsible for supporting this version.
(and yes, I can see it's unsupported.  I'm not asking for a fix, just
looking to see if I missed some obvious known issue or something that's
solved with a simple setting)
I've reduced the scene to the simplest possible case where it has the
problem.  A sphere and a light source.  I had a more complex isosurface
originally, and I tried it with and without an explicitly defined black
background, and I tried putting in a bunch of off-camera black boxes fully
surrounding my scene to see if the change in how the background is
interpreted was affecting the highlighting.
Anyway, the simple case is included below.  Build it with and without
+UA, and see if the specular highlight looks the same.
     tom
camera
  up <0, 1, 0>
  right <1, 0, 0>
  location <30,0,-3>
  look_at <0,0,0>
  angle 10
#declare redgloss = texture { pigment { color rgb <1,0,0> } finish { ambient 0.1
specular 0.5 diffuse 0.5 reflection 0.1 } }
light_source { <200,180,-300> color rgb <2,2,2> }
sphere { <0,0,0> 1 texture { redgloss } }
Date: 19 May 2012 09:11:11
Message: <4fb79bef$1@news.povray.org>
I can reproduce the problem with an official 3.6 on Windows 7.
With 3.7 everything seems to work fine.
>  i386-apple-darwin9)
>  MacPorts
You might try the unofficial 3.7 RC4 for Mac, see
http://news.povray.org/povray.general/thread/%3C1kfs3ae.23o5vw13v5gloN%25yvo.s@cancel_This_gmx.net%3E/
Date: 19 May 2012 10:04:56
Message: <4fb7a888@news.povray.org>
Am 19.05.2012 05:04, schrieb Thomas A. Fine:
> #declare redgloss = texture { pigment { color rgb<1,0,0>  } finish { ambient 0.1
Did you try without the reflection?
If that helps, try adding
   sphere { <0,0,0> 100000
       pigment { color rgb 0 }
     finish { ambient 0 specular 0 diffuse 0 }
     no_image
It might be that reflections of a transparent background produce weird
results; by enveloping the scene in a huge black sphere we provide
something opaque to reflect, and the "no_image" statement makes sure the
image itself still shows the background.
Date: 19 May 2012 11:26:10
Message: <4fb7bb92$1@news.povray.org>
I tried removing it but the effect was still there in 3.6
Date: 21 May 2012 11:48:16
Message: <4fba63c0$1@news.povray.org>
Thanks everybody.  I've given the unofficial Mac 3.7 from MegaPOV a try
(really, no command line?).  It doesn't suffer from this issue.
On the other hand it doesn't render the same as 3.6 in terms of the tone
of color and size of the specular highlight.  (Maybe there's some
setting I missed?)  But it's close enough to work with it.
     tom
Date: 21 May 2012 16:05:01
Message: <web.4fba9f4690e3954585de7b680@news.povray.org>
Have you taken the changes in gamma correction into account?  Do you have a
#version setting at the top of the file?
Date: 22 May 2012 16:36:44
Message: <4fbbf8dc$1@news.povray.org>
>       tom
Probably a gamma handling thing.
Version 3.7 "prefers" to work using assumed_gamma of 1, linear colour
space, while 3.6 pushed you to use an assumed_gamma of 2.2.
