POV-Ray : Newsgroups : povray.general : Help with plastic texture Server Time
25 Aug 2025 03:35:49 EDT (-0400)
  Help with plastic texture (Message 1 to 8 of 8)
Subject: Help with plastic texture
Date: 12 May 2011 22:15:45
Message: <4dcc9451@news.povray.org>
Hi all, I have been struggling bigtime trying to get a realistic plastic
texture to work with a hdr background.
Whenever I get close it allways looks washed out or way too reflective (ie
like shiney metal), I'd really like a brilliant white shiney surface.  For
example the same as a brand new white painted car panel.
If someone could help me out I would much appreciate it!
An quick mock up of my scene is below:
// ----------- code start
#include "textures.inc"
  location <0, 0, 10>
  look_at <0, 0, 0>
  right x * image_width / image_height
sphere {
  0, 12000
  hollow
  pigment { image_map { hdr "Factory_Catwalk_2k.hdr" map_type 1 } }
  finish { diffuse 0 ambient 1 }
sphere {
  0, 3
  pigment { color rgb 1 }
  finish { specular 1 roughness 0.0001 reflection 0.13 }
// ----------- code end
Thanks!
Cheers Dre
Subject: Re: Help with plastic texture
Date: 13 May 2011 09:20:00
Message: <web.4dcd2f31d464176481c811d20@news.povray.org>
> camera {
>   location <0, 0, 10>
>   look_at <0, 0, 0>
> sphere {
>   0, 12000
>   hollow
> sphere {
>   0, 3
> Thanks!
> Cheers Dre
first you typically want to explicitly set your diffuse and ambient values
(ambient 0).  For diffuse, I find values from 0.4 to 0.6 usually adequate.
The next step is managing the reflectivity.  I find it is always best to revert
to fresnel reflection.  With this you need to set an ior value, for this I will
typically use from 1.15 to 1.3 depending on how shiny I would like it.
The specular part is optional, as you are using true reflections, but sometimes
it does help a little.  But keep it low and adjust the roughness value for the
'diffuseness' you would like.
sample plastic:
material{
  texture{
    pigment{rgb <1,0,0>}
    finish{
      conserve_energy
      diffuse 0.6
      ambient 0
      specular 0.5
      roughness 0.05
      reflection{0 1 fresnel on metallic 0}
  interior{ior 1.16}
With material such as this, especially when used with an HDR environment map,
the most important part is how they reflect the background.  For plastic, you
want to make sure that less bright areas of the background don't reflect much,
but that bright highlights do.
-tgq
Date: 13 May 2011 21:54:47
Message: <4dcde0e7$1@news.povray.org>
> camera {
>    location<0, 0, 10>
>    look_at<0, 0, 0>
> sphere {
>    0, 12000
>    hollow
> sphere {
>    0, 3
> Thanks!
> Cheers Dre
Constant reflection is good for metallic surfaces and mirrors.
Most surfaces that are not intended as mirrors but are reflective should
use variable reflection, normaly with the fresnel attribute. It must
also have an ior for this to work.
Trevor suggest an ior value from 1.15 to 1.5 and a reflection going from
0 to 1.
Mamy plastics have an ior larger than that, you can use an ior in the
1.2 to 1.5 range and reduce the maximum reflection falue, somthing like
0, 0.5 can give good results.
That way, the reflectivity gets capped and dark objects' reflection will
fade away more.
Your specular looks to large. It's usualy beter to keep is somewhat
lower. A roughness of 0.0001 is for a highly polished surface. It can
make your highlights to harsh and to strong or overwhelming.
If you want to realy do it right, use the new SSLT feature. Reserve it
for relatively small objects, as the effect importance dimishes as the
dimention gets larger and it's realy slow.
Take note that this feature is still under devlopment and it
implementation WILL change in the future (as soon as 3.7 RC4).
With the default mm_per_unit value, it means that your sphere is 3 cm in
radius. If your scene use units of 1 m, it should be set to mm_per_unit
1000.
Your sphere can looks like this (without SSLT):
sphere {
   0, 3
   finish { specular 0.5 roughness 0.001 reflection{0 0.63 fresnel}
ambient 0 diffuse 0.6 conserve_energy }
interior{ior 1.32}
conserve_energy is not needed here, but I have the habit of puting in in
case that later I want to change the pigment to a transparent one.
If you want to be thorough, you can also use blured reflection by using
one of the usual technics:
Micro normals, using a buzzy normals pattern scalled very small.
Possibly averaging a small number of randomly displaced patterns.
Averaged macro normals, using up to 255 (at least 20) smooth normals
scalled large and randomly displaced a large distance.
Date: 15 May 2011 20:15:52
Message: <4dd06cb8@news.povray.org>
"Dre" <and### [at] gmailcom> wrote in message
news:4dcc9451@news.povray.org...
> camera {
>  location <0, 0, 10>
>  look_at <0, 0, 0>
> sphere {
>  0, 12000
>  hollow
> sphere {
>  0, 3
> Thanks!
> Cheers Dre
Hi, replying here to both Trevor and Alain.
Thank you both for your help, those examples give me the finish I am looking
for, but no matter what I do, the sphere allways comes out black.  The metal
surfaces in my image look great, but anything coloured is black (or very
very dark).  I'm not using any lights as I thought the hdr took care of
that.  If I stick a light in there it all looks wrong and way to bright...
In the past I've only really used hdr backgrounds for metal things, but now
I'm trying to use other surfaces and am really struggling.
I've attached a pic of what I'm talking about.  That black thing needs to be
white :)
Cheers Dre
Download 'droid.png' (110 KB)
Preview of image 'droid.png'
Date: 15 May 2011 20:28:22
Message: <4dd06fa6@news.povray.org>
news:4dd06cb8@news.povray.org...
>> (ie
>> For
>> camera {
>>  location <0, 0, 10>
>>  look_at <0, 0, 0>
>> sphere {
>>  0, 12000
>>  hollow
>> sphere {
>>  0, 3
>> Thanks!
>> Cheers Dre
> looking
> metal
> now
> be
> white :)
> Cheers Dre
Hi again, well I have managed to use an area light to make it look white.
However that makes all the metal in the image washed out and too bright.
About the only way I think I can get around this is with a light_group but
surely there is a more elegant way of solving this?
Cheers Dre
Download 'droid.png' (99 KB)
Date: 15 May 2011 20:35:01
Message: <web.4dd07015d4641764b05ef170@news.povray.org>
> > camera {
> >  location <0, 0, 10>
> >  look_at <0, 0, 0>
> > sphere {
> >  0, 12000
> >  hollow
> > sphere {
> >  0, 3
> > Thanks!
> > Cheers Dre
> white :)
> Cheers Dre
if you are using just reflection with no light and no radiosity, it will come
out black.  Plastic reflection ('metallic off') does not colour the reflection.
The surface colour of the base object will come from diffuse interaction with
light sources, so if you don't have any, you can expect the object colour to
show up black (no light = no diffuse interaction), reflection of the background
alone won't colour it.
-tgq
Date: 15 May 2011 22:22:27
Message: <4dd08a63@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.4dd07015d4641764b05ef170@news.povray.org...
>> > plastic
>> > (ie
>> > For
>> > camera {
>> >  location <0, 0, 10>
>> >  look_at <0, 0, 0>
>> > sphere {
>> >  0, 12000
>> >  hollow
>> > sphere {
>> >  0, 3
>> > Thanks!
>> > Cheers Dre
>> looking
>> metal
>> bright...
>> now
>> be
>> white :)
>> Cheers Dre
> come
> reflection.
> with
> to
> background
> -tgq
Thanks again for the info.  I've since used a light group to get around
this, the lights just for the coloured items, that way the metal items dont
look too washed out.
Texturing has allways been a severe weak point in my poving over the years,
hopefully one day I'll get the hang of it!
Cheers Dre
Date: 15 May 2011 22:55:00
Message: <web.4dd09129d4641764b05ef170@news.povray.org>
> Cheers Dre
If you are texturing and lighting properly, you shouldn't get washout.  I would
think that means that either your light or your textures are too bright.  The
object colour comes from a combination of the light falling on it and how it is
textured.
For textures, keep diffuse reasonable, I rarely use higher than 0.6.  Make sure
you aren't using 'ambient' (unless absolutely necessary).
You also want to keep your light intensities reasonable as well, I would say
averages are from 1 to 3 with a maximum of maybe 6 to 10.  Of course you can
have brighter as the scene or texture dictates, but you have to take care of
washout.
I find it best to try to think in terms of how the interaction is in real-life
and adjust values that try to reflect that.
Perhaps post a simplified version of your scene, especially what your light and
material settings are.
-tgq
