POV-Ray : Newsgroups : povray.general : Need a way to make a semi random "landscape". Server Time
17 Mar 2026 18:07:00 EDT (-0400)
  Need a way to make a semi random "landscape". (Message 1 to 10 of 12)
Subject: Need a way to make a semi random "landscape".
Date: 3 Oct 2010 22:17:44
Message: <4ca93948@news.povray.org>
I am fining myself in a position where I think I have some code that can
be used, but I need to "see" it, but the place I plan to use it has
restrictions, where I can't test it "in world". So, I figured I might be
able to test it in POVRay, but to see if its working as espected, I need
to test it against conditions like those its going to be running.
Conditions:
1. I don't control what the "land" looks like.
2. Land is 255x255 units in size, with its corner at 0,0.
3. Water may exist, which could be below, or above the land. This
effectively works like a simple plane, where everything below it is
water, and above isn't.
4. The land may be hundreds of units above the water, or below it.
Code:
1. Picks a random main_radius between 20->40, non-integer.
2. Picks an X,Y point that are rand(seed) * (255 - (radius * 2)) + Radius.
3. Determines where the land height and water height is.
4. Sets the "ground" at which ever is higher (i.e., if the land dips
below water here, then the water becomes the land).
5. Defines a range in which to set the Z coordinate, based on the
"normal" ground level, and the "current" level:
posz = Z position considered the "average" land height.
if ground <= posz
   base = (posz - gnd) + 150
else
   base = 20
6. Now that we have a center point, set a "default type", 'main_type =
int(rand(seed) * 6)'. For use in POVRay, this would mean setting this
"group" to one of six colors.
7. POVRay - Draw a sphere here, over the land, showing the location and
limits of where this thing is going to end up.
8. Generate 7 new points, with radii of 1 + rand(seed) * (main_radius /
5), within this sphere, whose distances are 'sqrt((x1-x2)^2 + (y1-y2)^2
+ (z1-z2)^2) > radius1 + radius2 + 1', first adjusting any "below" the
"ground" level to = ground level, and throwing out any that overlap, and
retesting a new one, if they do overlap. Set each ones type (color) as
'int(rand(seed) * 6) * (rand(seed) < 0.012) + main_type * (rand(seed) >=
0.012)'. This means a 1.2% change of the type being different for the
specific items in a group, and about an 0.1% change that something
"different" will come up, or a .02% change of it still picking the same
type, I think..
9. POVRay - Draw spheres of the correct color, for each of these points
and radii.
10. Generate 1->3 other random points, like above, but with a 7th
color/type, and a fixed radium of 0.5. These shouldn't overlap either.
11. Make up to 2 more "groups", using rules 1 through 11, checking that
each main sphere is at least 5 units away from the prior one, so groups
do not overlap either.
The result of this, assuming my code is right, should be several
bubbles, containing clusters of other spheres, resting on, or over, the
land mass, and water.
The virtual world I plan to use the raw data from this code in has
limits of the number of things I can "make", the distance I can have an
object "appear" from the script holder, *and* limitations on even if I
could find a place to test it, assuming the other limitations where not
in place. The final result will generate just the raw data, and send
that to a device the character holds, when they enter the area, which
can then detect when they are near on of these sphere, and produce an
appropriate display in the item, based on how close, and what the type is.
So, I figure if I could use like "trace" on a randomly made landscape,
and on a plane placed on it, I could run tests runs, using the code, to
make sure that actually does what its supposed to. Problem is, I only
fiddle now and then with POVRay, so I have **no** clue how to make a
randomly created landscape, or use trace, or use trace from "two"
different objects (assuming that is even plausible), to get my "this is
where the ground is) value, and thus compute the rest of it...
I have working code to make the coordinates (though in writing this, I
think I already see a bug), and its trivial to generate spheres at those
location, so its just the landscape + trace stuff I have no damn clue
about... :p
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: Need a way to make a semi random "landscape".
Date: 4 Oct 2010 15:30:30
Message: <4caa2b56$1@news.povray.org>
whoa. I think you need to take this one step at at time, your
post contained a lot of detail without without quite pinpointing
what you're trying to accomplish and your exact problem.
I gathered you want to try some algorithm that traces some
positions over random landscapes. You should probably forget
about the details of your algorithm until you've set up a
test environment.
The easiest way to get a landscape is using a height_field.
A height field can be based on a function instead of an image
file, e.g.
   height_field
     function 512, 512 {0.5+0.5*sin(10*x*y)}
     pigment {color White}
To get a random landscape, you will then need to get
a random function. One way to do this is to use a noisy
function such as f_bozo and vary the position where you
evaluate it by some random parameters. Note this will
not give a particularily pretty landscape. Look up "seed"
and "rand" for getting some random numbers, but it will
not be truly random and depend on your seed.
Regarding trace: If your only intent is to get the height
of the ground below some x,y coordinates, you can in this
case of course simply stuff the coordinates into the function
defining the height field as this already gives the height.
More generally, the trace function takes one object (landscape),
one point (position) and one vector (line direction) and will return
the first point on the object which intersects the line (optionally,
you can also get the normal vector of the surface).
I hope this helps you get started.
Date: 6 Oct 2010 00:42:35
Message: <4cabfe3b$1@news.povray.org>
>> to make sure that actually does what its supposed to. Problem is, I
>> only fiddle now and then with POVRay, so I have **no** clue how to
>> make a randomly created landscape, or use trace, or use trace from
>> "two" different objects (assuming that is even plausible), to get my
>> "this is where the ground is) value, and thus compute the rest of it...
> test environment.
> file, e.g.
> height_field
Hmm. Ok. So.. lol
Well, I suppose I could constrain the area to test to a space within Y =
0 -> 255, Y = 0 -> 255, for sake of getting results. The problem with
trying to store the coordinates, instead of using something like trace,
is the object I am placing "may" land some place better the grid points.
Storing 65356 points is bad enough, without having to subdivide that by
some fraction as well.
Like I said, I already have code I wrote to generate my points, I just
can't "visualize" the result, or really test it visually in the
environment I want to use it in.
The attached has an example, side view. Black is the landmass, blue the
water level. The Yellowish box is an object that contains the script.
The green circle is where the sphere is that defines the constraint for
the appearance of objects. The pink ones are objects that are generated
"inside" this region. In some cases I may need to generate a number of
them all at "ground", but in most cases, the types can be floating over
the ground as well. The salmon one is, more or less, an example of one
that actually does physically appear in world. If you get within its
radius, an object is created, and drops to the ground, which can be
picked up.
The code I have already is written in Basic. Its going to be a bit
more.. annoying, since the language I have to then parse this into
doesn't support types. I.e., I have to use 4 "lists" (sort of an array),
to handle each set of data for the objects, instead of just creating a
type, which lets you split up the critical data. Mind, this may not be a
big problem, since they do have a type that has <x,y,z,u> as attributes,
so I could store the x,y,z, and a type, in that, as long as I remember
its not a rotation, but rather coordinates and type data. lol
Basically though, the code is complete. Its just hard to visualize what
the actual result is, without actual objects to look at. All I have,
from the code, is a lot of numbers, which "look" like they are doing
what I want. But I can't tune the design without being able to really
see what I am ending up with.
void main () {
   else
Download 'example.png' (3 KB)
Preview of image 'example.png'
Date: 6 Oct 2010 16:12:14
Message: <4cacd81e$1@news.povray.org>
Of course, you can also use the trace function with a height_field
to take care of the correct interpolation between grid points. Just
use #declare POS = trace(TERRAIN,<px,100,pz>,-y)
If you already have coordinates, you can use them directly to
generate 3d objects in POV Ray, e.g., by writing an SDL include
file from your Basic program containing an array of coordinates
or a union of spheres.
What kind of sample data do you already have to test your
algorithm in Basic? Do you already have a 3d "terrain"? Or
do you wish to generate test data in POV-Ray?
Date: 6 Oct 2010 22:37:28
Message: <4cad3268@news.povray.org>
Any idea why Thunderbird sometimes completely screws up some messages? I
had to go to the web view to see this at all, since the copy in
Thunderbird was completely empty...
Worse.. Somehow, the "reply to" for this went to you, rather than the
group... Resending it so it ends up there.. Very odd.. Wonder if it is
some glitch with trying to read an email "while" its still downloading,
or something.
Hmm. Yeah, wasn't real sure how that worked, so was unclear how to
manage it. I kind of hoped it would be the equivalent of what the
world's own functions do, which is seems it would be. Those are llWater
and llGround. Since I am going to be effectively substituting llWater
for llGround, in cases where the later is lower than the former, one
solution I thought about was to have a height field, then "clip" that,
using a plane. For the purposes of visualizing the result, I don't need
to know where one or the other is. That part is easy enough to work out,
without testing. If the "base" comes up the same as the higher of the
two, the code for it works. If not, then its not working. lol
Planned to generate the test data in POV-Ray. And, no I don't really
have the coordinates *until runtime* either. The following is the test
code I used to get the general concept working, mind, its messy, and I
am adding some commentary to clear up what is happening, which the
original doesn't have. But, initially, I just wanted to see if I could
get "one" group to generate, within the parameters set for it. In the
real situation I am actually going to be producing at least 3, perhaps 4
such groups, with slightly different rules, for each one, depending on
which type is involved.
// This declaration and the function are replaced with the inbuilt,
// llVecDist(<vector1>,<vector2>) function for the environment.
DECLARE FUNCTION vecdist! (x1!, x2!, y1!, y2!, z1!, z2!)
// Wish I could do this.. The language supported in the environment
// won't allow it, so I am going to have to either serialize the data,
// or use several arrays.
TYPE vects
   x AS SINGLE
   y AS SINGLE
   z AS SINGLE
   r AS SINGLE
   t as integer
END TYPE
DIM plist(6) AS vects
//For ease of identification. In POVRay this would be a color,
//while in the environment its intended for, it would be just
//a number, representing what effect getting too close has.
atyp$ = "FPRETO"
CLS
RANDOMIZE TIMER
//For simplisity sake, I use names that match the functions I will
//use here. For POVRay, these might be replaced with a plane + height
//field, and a call to the trace function, to get the height.
llground = 40
llwater = 37
//This is an arbitrary "height" for the scripts source object.
//All it does is define the max height something "can" be, based
//on the presumed "average" height of the landscape. I might decide
//to replace this with a set range of possible values, based on the
//radius of the "container" sphere.
posz = 120
//Determine where the "container" sphere is going to be, and how big.
//In world, this is the equivalent of 20-40 meters, within an area
//that *must not* allow a contained object to fall outside the 0-255
//coordinate limit in either direction.
rad = (RND(1) * 20) + 20
posx = RND(1) * (255 - ((rad + 1) * 2)) + rad
posy = RND(1) * (255 - ((rad + 1) * 2)) + rad
//This is all just to figure out where the "ground" actually is, i.e.,
//is it the ground level, or the water level?
gnd = llground
water = llwater
IF gnd < water THEN
   gnd = water
END IF
//Knowing which we will be using, we now determine what the
//range if heights this this is likely to occupy.
//For the test code, I assumed that "all" groups could be
//as much as 50 meters "over" the average land height.
//In cases where the ground was "below" this, the range becomes
//the difference between the real ground and the average + 50
//meters. It may be better, thinking on it, to either not use
//this, or only use it in cases it makes sense to (some types
//may reasonably do this, while others wouldn't).
IF gnd <= posz THEN
   bas = (posz - gnd) + 50
ELSE
   bas = 50
END IF
top = gnd + bas - rad
bottom = gnd + rad
PRINT
PRINT bas, rad
PRINT bottom, top
DO
   // Work out where our group actually is vertically, now that we have
   // the range it can show up in.
   // Note: Types include >
   // 1. Fire - Probably ground only.
   // 2. Psi - Any range.
   // 3. Radiation - Probably ground only.
   // 4. Electrical - Any range.
   // 5. Poison - Any range.
   // 6. Tomoe (Hard to explain) - Probably ground only.
   // The "ground only" ones would replace "both" centerz, and the
   // z for each object as centerz = gnd, and posz = gnd,
   // respectively.
   centerz = gnd + rad + RND(1) * (bas - (rad * 2))
   PRINT
   PRINT "center "; posx, posy, centerz
   count = 0
   tests = 0
   // Pick a type. Likely needs to be done "prior" to the centerz,
   // in the final version.
   mt = cint(rnd(1) * 6)
   // Now for the fun part.. We pick, at least, 7 points, possibly more,
   // if we end up overlapping any of the radii, and add them to our
   // list of coordinates.
   DO
     ncr = 1 + RND(1) * (rad / 5)
     DO
       ncx = posx + (RND(1) * (rad * 2)) - rad
       ncy = posy + (RND(1) * (rad * 2)) - rad
       ncz = centerz + (RND(1) * (rad * 2)) - rad
       // Assumes a flat plane. Since gnd is the same "everyplace"
       // in the test. In the POVRay version, and the real use for
       // the code, we need to check where the ground/water is here
       // too, since it may not be the same as for the container.
       if ncz < gnd then
         ncz = gnd
       end if
     // This is an example of the sloppy stuff here. I could do a lot
     // of complex math, using a rotation of A,B,C, and a radius
     // equal of lower than that of the container, but "may" waste
     // script time, it also may not work right in the final code.
     // Why? Well, the final environment uses quarternions. So, I
     // either need some valid way to make a random one of those,
     // and I suspect that doing "<llFrand(1), llFrand(1), llFrand(1),
     // llFrand(1)> * (llFrand(1) * Radius)" won't cut it..
     // I am fairly certain that something like <1, .54435, .235, 1> is
     // **not** a valid quarternion, nor what the system would do with
     // such a number. OR I have to do "llEuler2Rot(<llFrand(TWOPI),
     // llFrand(TWOPI), llFrand(TWOPI)>) * llFrand(1) * Radius", and
     // hope that gimble lock doesn't frack up the whole process...
     // I have yet to run tests to see if *either* will work. So,
     // checking to see if the position is "inside" based on distance
     // seemed the simplest option for testing.
     LOOP UNTIL vecdist(posx, ncx, posy, ncy, centerz, ncz) <= rad
     tests = tests + 1
     LOCATE 5, 1
     // Just to make things more interesting, its possible for "some"
     // of the types to end up different than the main one for the
     // whole set. Obviously, as per the prior list, the z coordinate
     // will need to be set to ground, or the selection ignored if that
     // is too far below, for some of them.
     if (rnd(1) < 0.012 then
       nt = cint(rnd(1) * 6)
     else
       nt = mt
     end if
     PRINT "newpos "; ncx, ncy, ncz, ncr
     PRINT "tests "; tests; " count "; count; "      "
     IF count = 0 THEN
       plist(count).x = ncx
       plist(count).y = ncy
       plist(count).z = ncz
       plist(count).r = ncr
       plist(count).t = nt
       count = count + 1
     ELSE
       FOR t = 0 TO count - 1
         IF vecdist(plist(count).x, ncx, plist(count).y, ncy,
plist(count).z, ncz) > plist(count).r + ncr THEN
       plist(count).t = nt
           count = count + 1
           EXIT FOR
         END IF
       NEXT
     END IF
   LOOP UNTIL count = 7
   REM PRINT
   REM PRINT "dist "; vecdist(posx, ncx, posy, ncy, centerz, ncz)
   // Print my new list of positions.
   PRINT
   FOR t = 0 TO 6
     PRINT plist(t).x, plist(t).y, plist(t).z, plist(t).r, mid$(atyp$,
plist(t).t, 1)
   NEXT
   DO
     ak$ = INKEY$
   LOOP UNTIL ak$ <> ""
LOOP UNTIL LCASE$(ak$) = "q"
FUNCTION vecdist (x1, x2, y1, y2, z1, z2)
   vecdist = SQR((x1 - x2) ^ 2 + (y1 - y2) ^ 2 + (z1 - z2) ^ 2)
END FUNCTION
Now, obviously, this only produces "one" set, not 3 or more. And, in the
end, its all just a data generator, which needs to be tuned. Ultimately,
once I know it is producing usable data, every time the system resets,
it would produce a random number of these data sets, and someone
entering the sim, while wearing a device that can talk to the script,
will get a copy of the list. There will be three forms of this device:
1. Can spawn items, if you get close to one, and tracks things happening
to you, if you wander through an area with one of these oddities in it.
2. Spawns items, and can warn you that you are getting close to something.
3. The final version uses "all" of the data, showing you what, where,
etc. something is, based on how close you are, and which direction you
are facing.
But, to finish that part of the project, I need something that can
produce data, to feed it. And that is the point of trying it in POVRay
first. ;)
Yeah. A real landscape would almost be nicer to work with, though I
tried playing with a few things for making them, and.. they are damned
annoying to get anything useful out of. But, they might be usable, as
long as I can get a +- range of say.. 300 meters/units out of them,
enough interesting variation to test this well. The "pit" in the example
I attached, for example, is an interesting case, since it could
constrain where in the sphere an object can even appear. The code I have
above doesn't account for that at all, since it assumes a flat plane,
and never checks if the height under an object is the same as under the
center of its container. In the real implementation, this "has to" happen.
void main () {
   else
Date: 7 Oct 2010 15:27:33
Message: <4cae1f25$1@news.povray.org>
I see it fine in Thunderbird.
considering you already use vb as a test environment you
might try the following route to avoid reproducing everything
in SDL
1. Use POV-Ray to generate a grey scale heigth image
    (not rendering a height_field, just using texture
    to define terrain elevation). For testing purposes,
    you can skip this step and use handpainted data or
    terrain generated, e.g., from World machine.
2. Create a Bitmap object in your VB App. When determining
    the height of the ground over a position, use Bitmap.GetPixel
    to get the heigth information (rounding to the nearest pixel
    value may ok, otherwise, evaluate the four surrounding pixels
    and calculate the weighted average).
3. At the end of your algorithm, write an include file containing
    a union of spheres for the generated objects.
4. Render a POV-Ray scene containing a height_field based on
    the image and your exported spheres.
Date: 7 Oct 2010 15:38:28
Message: <4cae21b4@news.povray.org>
I see this all the time, it's a highly annoying bug in Thunderbird that
they don't seem to worry about fixing (I suspect because NNTP is fading out
of popularity). If Thunderbird is still downloading messages (even for
groups other than the one you are wanting to view), and you click on a new
message, it will show up blank. The only way to force it to load at that
point is to exit Thunderbird and re-start it.
Yes, that's TB's default for newsgroups. Doesn't seem to make sense to me
either. I sometimes forget to do a followup to the NG and just hit reply -
my fix to prevent such emails from being sent (thus ensuring I notice) is
to set a custom (and invalid) SMTP server for the newsgroup account, rather
than allowing it to use the global default SMTP server. Thus when it
attempts to send the mail, it will fail.
-- Chris
Date: 7 Oct 2010 16:13:00
Message: <4cae29cc@news.povray.org>
There is no interference with e-mail.
I don't see that problem, maybe because I only get the heathers from the
news groups, and only download the messages as I read them.
> -- Chris
I always use TB and I never had any problem of replying to the sender
instead of the group. Without any special configuration, my replys
always goes to the group.
Date: 7 Oct 2010 19:38:50
Message: <4cae5a0a$1@news.povray.org>
>> I had to go to the web view to see this at all, since the copy in
> in SDL
Hmm. Interesting idea. Mind, I was using QBasic, but not hard to
convert, and definitely easier to edit. lol Need to think about that
possibility.
void main () {
   else
Date: 7 Oct 2010 19:42:31
Message: <4cae5ae7$1@news.povray.org>
Its a symptom of the prior issue. I.e., if the message doesn't load
correctly, it seems to have grabbed the name of the original sender,
instead of the group. First time its happened to me. Usually I just skip
messages which seem to have glitched, but this one was in my own thread,
so.. lol
void main () {
   else
