POV-Ray : Newsgroups : povray.general : Combining meshes and isosurfaces Server Time
30 Jun 2026 21:01:00 EDT (-0400)
  Combining meshes and isosurfaces (Message 1 to 8 of 8)
Subject: Combining meshes and isosurfaces
Date: 3 Apr 2010 06:00:54
Message: <4bb711d6@news.povray.org>
Hi there,
Isosurfaces and meshes are the two objects that currently offer the most
advanced modelling techniques in POV-Ray. Meshes are easily modified
using free and commercial modelling programs and great to model organic
structures. However they require lots of triangles and excellent
materials to look good in close-ups. Otherwise they often look too smooth
(especially because POV doesn't support deplacement maps). With
isosurfaces it is easy to create small semirandom detail using POV's
inbuilt functions like noise but keeping control of the overall shape is
difficult. Wouldn't it be nice to be able to combine the strengths of
isosurfaces and meshes into one kind of object?
The object type I imagine would do the following:
In meshes there's "zero"-dimensional vertices, one-dimensional edges and
zwo-dimensional faces. Let's add three-dimensional structures as well,
I'll call them strata. They are just 3D-cells whose boundaries are faces.
Of course we can assign texture-coordinates (called uv-coordinates in
POV, but that term is a bit misleading) to vertices and interpolate them
not just on faces but also inside strata. I called the term uv-
coordinates misleading because we can have any number of texture
coordinates, not just two (u and v) but any number.
Now let's put an isosurface into each stratum. Each may - but needn't -
have the same function and threshold. We feed texture coordinates (which
may now be three-dimensional and named for example u, v and w) instead of
x, y and z to the function, which makes the isosurfaces "stick" to the
mesh even if the vertices are moved around.
With this object type we could control the overall shape using the mesh
but the small details using isosurface functions. We could model rust on
surfaces, that's really three-dimensional. Create landscapes with certain
features at a large scale but let noise-like functions handle the rocky
ground.
Of course there are certain problems to overcome. At the moment I'm
trying to find these problems before I start messing with the POV-Ray
source.
- Memory consumption could be a problem. A mesh that's not just a thin
shell but has depth needs about 7 times as many triangles. Solution: Buy
more RAM ;)
- Speed will never be better than that of meshes or isosurfaces. In fact
the times needed to calculate an intersection will add up! Fortunately
isosurface functions may become simpler because they needn't model the
object's shape but only the details of the surface. Solution: Buy a new
CPU ;)
- Perhaps we'll need to look into more complex interpolation schemes for
texture coordinates than just linear interpolation. There may be non-
linear transformations involved!?
- There are be no graphical editors for this kind of object so we're
still stuck with trial and error.
I'd be glad to hear what problems and chances you see with this idea!
Subject: Re: Combining meshes and isosurfaces
Date: 3 Apr 2010 06:46:58
Message: <4bb71ca2$1@news.povray.org>
why a mesh at all, excepted for the modeling software ?
Just a collection (union ?) of isosurface
What about the fractal object instead ?
Date: 3 Apr 2010 06:55:15
Message: <4bb71e93$1@news.povray.org>
Am Sat, 03 Apr 2010 12:46:56 +0200 schrieb Le_Forgeron:
Yeah, that would be possible for a mock-up. The memory consumption would
be even higher but I guess the needed non-linear transformations could be
done by modifying the isosurfaces' functions and the strata boundaries
using clipped_by. Rendering would be insanely slow but yes, definitely
doable.
The fractal object is entirely different from my proposal.
Date: 5 Apr 2010 06:26:20
Message: <4bb9bacc@news.povray.org>
Am 03.04.2010 12:00, schrieb Lukas Winter:
> source.
> more RAM ;)
You'd probably end up with less memory consumption for same level of
detail though, so I'd not consider that a real issue.
> CPU ;)
I guess that it will rather speed up rendering, at least as compared to
isosurfaces, as there containing "3D-mesh" would serve as a bounding
structure for the isosurface.
I guess that'll be the main obstacle, and I honestly don't think it can
be overcome within reasonable time.
I'd rather prefer work to be invested into some "fake displacement
mapping" (I'm thinking of a certain kind of "deluxe bump mapping", which
wouldn't improve the outline of a mesh object, but aside from that would
give pretty much the same results as displacement mapping for the
surface structure otherwise), or maybe a feature to generate a much
higher-resolution mesh from a basic mesh and a displacement map. I think
implementation of such features would be within reasonable reach, and
easy enough to use without the need for unconventional external tools.
Date: 11 Apr 2010 05:25:01
Message: <web.4bc194b1597a7efd1408b2c10@news.povray.org>
From user point of view all the ideas mentioned are great!
Maybe for displacement the faces could be turned into heightfields instead?
The PTex software developped by Disney and released as open source works on a
per face basis for texturing without the need for UV type unwrapping
http://www.disneyanimation.com/library/ptex/
Date: 11 Apr 2010 05:45:01
Message: <web.4bc1991f597a7efd1408b2c10@news.povray.org>
 Actually, this address is the one where you can download the source:
http://ptex.us/download.html
Date: 11 Apr 2010 07:23:28
Message: <4bc1b130$1@news.povray.org>
Am 11.04.2010 11:23, schrieb Mr:
While that looks like a powerful approach, there seem to be major
drawbacks that virtually forbid inclusion in POV-Ray in the near future:
- The approach is specifically targeted at Catmull-Clark subdivision
surfaces, so there's probably not much benefit for classic meshes.
- To benefit from the approach, both textures and meshes would need
special software to create, in order to provide the extra information;
until such software is available at prices affordable by the average
hobbyist, the feature would benefit only a small minority of users.
In other words, presently it is pretty unlikely to be worth the
programming effort.
Date: 11 Apr 2010 09:35:58
Message: <4bc1d03e$1@news.povray.org>
interpreting normal patterns a displacement map would certainly be
nice and it could be applied to objects other than meshes. The delta
already defined for normals could be used to build a local mesh at the
intersection point where an object was hit, to be used for local shadow
calculations and displacement of the intersection point.
