POV-Ray : Newsgroups : povray.general : Mathematically derived bicubic patches Server Time
11 Apr 2026 10:55:20 EDT (-0400)
  Mathematically derived bicubic patches (Message 1 to 7 of 7)
Subject: Mathematically derived bicubic patches
Date: 12 Jan 2010 17:19:35
Message: <4b4cf577@news.povray.org>
Hola,
Since I can barely draw a straght line with a ruler, I've not had much luck
making bicubic patches that look like leaves and petals (Clay Pots post in
p.b.i) I was wondering if anyone had done anything along those lines but
using formula's instead on pushing and pulling on a shape in a modeller.
I've done some homework and have some links bookmarked, but will save them
for late night insomnia (some pretty heady reading btw) ... Not looking for
a short cut, but if anyone has anything they might like to offer up for
study, that would be nice!
Hasta Bye
Subject: Re: Mathematically derived bicubic patches
Date: 13 Jan 2010 23:56:00
Message: <4b4ea3e0$1@news.povray.org>
Jim Holsenback wrote:
> Hola,
> Hasta Bye
It's not clear to me either:
how you made those leaves in "Clay Pots",
or
how you would rather make them.
Are you saying the leaves in "Clay Pots" were created in a modeler that
outputs bi-cubic patches such as Hamapatch?
But that you would rather shape their profiles with mathematical curves,
then fill in the surfaces using bicubic patches?
Or that you have already done that but would like to do it better?
It would seem that by the time you come up with a method for
interrogating some curve(s), or even just some spline(s) to get corner
and control points for some patch(es), you might just as well use the
points to generate triangles?
Date: 14 Jan 2010 06:01:25
Message: <4b4ef985@news.povray.org>
news:4b4ea3e0$1@news.povray.org...
Yes ... Bishop3D
Although the pots turned out rather well, the leaves/petals not so much ...
I'm just looking for a better way. Maybe I just need to spend more time with
a modeller to get the desired results.
> It would seem that by the time you come up with a method for interrogating
> some curve(s), or even just some spline(s) to get corner and control
> points for some patch(es), you might just as well use the points to
> generate triangles?
Well now that you mention it triangles DOES sound like a better approach.
Some of the stuff I have read (unless I misunderstood) seemed to indicate
multiple patches "glued" togeather to create the final shape ... I'm into
new territory with this so I'm not standing by any of my assumptions at this
point. If you think another method would yield better results, I'm open to
exploring them ...
Jim
Date: 14 Jan 2010 07:18:26
Message: <4b4f0b92$1@news.povray.org>
> "Jim Charter" <jrc### [at] msncom> wrote in message
> Yes ... Bishop3D
>> generate triangles?
> exploring them ...
The advantage to generating the leaves with SDL lies in the possibility
of randomizing each individual leaf to subtly change its shape. Or, a
set of variations could be instanced to save memory.
Splines could be defined for the leaf's basic silhouette in all three
planes.  Those basic definitions, which would differ for each species of
leaf, could then be varied slightly from leaf to leaf.  The surface can
be filled in with either patches or triangles.  I expect there are
already some grass macros around that would show how to do the basics of
much of this.  Still, it's an interesting proposal to develop say, a set
of splines for other species of leaf besides grass blades.
See the SDL I posted in p.b.scene-files to show what I am talking about.
The leaf is profiled in the x-z plane for its basic silhouette
and in the z-y plane to give the curve along it's spine.  The
cross-section in the x-y plane is omitted.  One side of the leaf is done
using patches the other using triangles.  The smoothing on the triangles
is crude, I admit.
Date: 14 Jan 2010 09:25:31
Message: <4b4f295b$1@news.povray.org>
> Yes ... Bishop3D
You would probably get some help at the Bishop3D forums, if you ask.
Miri is quite good at making these forms free hand. She created some
grass leaves as I remember. There is also a method of uploading control
points from a file if you can get a way of calculating them. Or you can
use your own SDL code with the raw script plugin.
Best Regards,
Date: 14 Jan 2010 12:21:35
Message: <4b4f529f@news.povray.org>
"Stephen" <mca### [at] aolDOTcom> wrote in message
news:4b4f295b$1@news.povray.org...
> Miri is quite good at making these forms free hand. She created some grass
> leaves as I remember. There is also a method of uploading control points
> from a file if you can get a way of calculating them. Or you can use your
JimC's approach shows promise, and it also off loads my guilt about using
Bishop after the trial period. I MUST find money in my budget if I'm going
to continue using it.
Jim
Date: 14 Jan 2010 13:55:29
Message: <4b4f68a1$1@news.povray.org>
There is that, personally I think it is a bit overpriced. One of the
benefits of testing is getting a free copy :D
Best Regards,
