POV-Ray : Newsgroups : povray.general : sun/earth/moon/day/night Server Time
27 Feb 2026 00:49:32 EST (-0500)
  sun/earth/moon/day/night (Message 1 to 10 of 31)
Subject: sun/earth/moon/day/night
Date: 6 Jan 2009 04:42:29
Message: <49632785@news.povray.org>
Hello all,
First of all, my best wishes to all of you. And to the developers of
PovRay: keep up the good work; we're all grateful for the job you're doing.
My 5-year old son is very interested and intrigued by the interplay of
the sun/earth/moon and how this creates day, night, seasons, ... Also
the mechanism of a solar and lunar eclipse (who is casting a shadown on
who) has caught his attention.
Since I lack a mechanical model of this three body system (I remember we
had this in our geography classroom when I was in secondary school: you
could turn a handle and then by means of gears the bodies would rotate
and move), I was planning to do some animations with PovRay.
I don't want to re-invent the wheel, hence my question: is there anybody
here who has done something similar with PovRay? I would like to end up
with a small number of input files (or a single one) for which the clock
variable would both make the bodies rotate and move the camera to show
the different aspects (night/day, eclipse,...). Do you know of a site or
reference work where I could get approximate data (good enough for this
purpose of an educational animation) for the astronomy data?
Thanks for your tips!
bye,
gert
Subject: Re: sun/earth/moon/day/night
Date: 6 Jan 2009 08:33:20
Message: <49635da0$1@news.povray.org>
You might want to try Celestia, a real-time planetarium program.
Certainly, you can do the same things in POV-Ray, but there are several
caveats:
1) POV-Ray is not a real-time program. You can't preview changes or
interact with the scene in real-time. The best you can do is render
individual frames to create a movie--which can be a time consuming
process, and you'll have to start the process over from the beginning
each time you make a mistake.
2) POV-Ray can suffer from floating point/rounding errors when the
objects get too large and/or too distant.
3) POV-Ray takes a long time to master, in general; and creating scenes
is usually a laborious process.
You could also try GeoGebra, which is a real-time dynamic geometry
software. You could create representations of the planets as well as the
shadows they cast on other bodies using geometric objects. This program
is limited, however, to two dimensions.
Hope that helps.
-Mike
gvdeynde wrote:
> Hello all,
> bye,
> gert
Date: 7 Jan 2009 03:51:15
Message: <49646d03$1@news.povray.org>
Hi Mike,
Thanks for the info. I've tried Celestia but thought it might be too
complex for my son.
Concerning PovRay: I have some experience already (I'm playing with it
since version 2 or so, have modeled our house in it, did some artwork
for some websites I made, etc). So I think I can come up with something,
I was just wondering if somebody already did something close to this and
I could work further based on that...
I'll have a look at Geogebra...
thanks again,
gert
> caveats:
> Hope that helps.
> -Mike
> gvdeynde wrote:
>> Hello all,
>> doing.
>> on who) has caught his attention.
>> we had this in our geography classroom when I was in secondary school:
>> you could turn a handle and then by means of gears the bodies would
>> rotate and move), I was planning to do some animations with PovRay.
>> anybody here who has done something similar with PovRay? I would like
>> to end up with a small number of input files (or a single one) for
>> which the clock variable would both make the bodies rotate and move
>> the camera to show the different aspects (night/day, eclipse,...). Do
>> you know of a site or reference work where I could get approximate
>> data (good enough for this purpose of an educational animation) for
>> the astronomy data?
>> bye,
>> gert
Date: 7 Jan 2009 11:39:07
Message: <4964daab$1@news.povray.org>
This may not help much, but here goes...
I wanted to do something similar but not for the Earth/Moon/Sun system.
  It was for a science fiction story I was working on that takes place
on a planet that orbits a star 20 lightyears away.  This is actually a
binary planet where two approximately equal mass planets orbit each
other (or around the center of mass of the two planets) and both orbit
the star.  The two planets are tidally locked to each other.  I wanted
to discover the dynamics of this world.
I wrote a simple model in POVRay and created an animation that captured
one frame per hour for one year (143 Earth days) and clearly showed the
geometry and timing of eclipses.
Notes:
	- as was mentioned, you have to be careful about scale
	- I didn't try modeling the elliptical nature of orbits - all orbits
are simple circles
	- since I'm creating the world as a work of fiction, I have some  room
to adjust the parameters to my suiting.
I can make this model available to you if you wish.  It could be
adjusted to give an "impression" of the Earth/Moon system but couldn't
be used to give accurate predictions of eclipses, etc.
David Buck
gvdeynde wrote:
> Hi Mike,
> complex for my son.
> thanks again,
> gert
>> several caveats:
>> scenes is usually a laborious process.
>> the shadows they cast on other bodies using geometric objects. This
>> program is limited, however, to two dimensions.
>> Hope that helps.
>> -Mike
>> gvdeynde wrote:
>>> Hello all,
>>> doing.
>>> of the sun/earth/moon and how this creates day, night, seasons, ...
>>> Also the mechanism of a solar and lunar eclipse (who is casting a
>>> shadown on who) has caught his attention.
>>> school: you could turn a handle and then by means of gears the bodies
>>> would rotate and move), I was planning to do some animations with
>>> PovRay.
>>> the astronomy data?
>>> bye,
>>> gert
Date: 7 Jan 2009 14:30:01
Message: <web.496501f14590b7f0e6fcd2f30@news.povray.org>
Out of curiosity: Would such a system actually be stable in reality?
Date: 7 Jan 2009 15:12:41
Message: <49650cb9$1@news.povray.org>
Hash: SHA1
	It is: look at the Pluto-Charo pair of planets (planetoids?) in the
solar system.
		Jerome
PS: Of course, Pluto and Charo aren't 20 ligth-years away from their
sun, but that's probably just me being obtuse ;)
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkllDOYACgkQd0kWM4JG3k+h4gCeK/oOHu0ymwsNP/Bjacmu13NX
iw8AoLfXyZz3X0QgX63JRYE/ur9n8tYp
=jlwG
-----END PGP SIGNATURE-----
Date: 7 Jan 2009 16:53:33
Message: <h29am4ps1fochf1is8l69ck6dhvaeooms4@4ax.com>
Hi Gert,
Out of interest I started to model an Earth Moon Sun system in a modeller and
quickly found that it not really easy to see what is happening when you use
proper scaling. For a five year old I assume that a non realistic model would
do.
Using a modeller you can show how the moon moves round the earth before
rendering. The modeller I used is Bishop3D and as it is in Beta it is free
http://www.bishop3d.com/
http://uk.youtube.com/watch?v=wsh6l7KpMEg
OK I know that the Earth should be moving but it is just a demonstration of a
shadow :)
Regards
Date: 7 Jan 2009 17:57:37
Message: <49653361$1@news.povray.org>
You need to have the two planets separated more than the Roche Limit
otherwise the tidal forces will tear them apart.  In this case, they are
about 10x the Roche Limit.  Within that range, it should be fine over
long periods of time (billions of years) but I haven't done the
simulations to verify that.
David Buck
Date: 7 Jan 2009 18:02:33
Message: <49653489$1@news.povray.org>
Jérôme M. Berger nous illumina en ce 2009-01-07 15:13 -->
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> solar system.
> 		Jerome
It's 20 lightyears away from HERE.
A planet orbiting it's sun at a 20 lightyears radius would need to have an
extra-galactic sun, or get snatched away by nearby stars. Such a planet would
also be frozen solid, with, maybe, sone seas of liguid hydrogen and helium. It's
"year" would last several 100's of millenias.
You know you've been raytracing too long when your source files are starting to
get bigger than the image files.
     -- Matt
Date: 7 Jan 2009 18:48:09
Message: <49653f39$1@news.povray.org>
> David Buck
Based on my undergraduate level physics education, I would say the other stability
limit is that the separation of the two planets should be substantially less than the
separation of the center of mass from the star.
Stability issues primarily occur with 3-body systems: they have a habit of ejecting
one of their members.  So as long as the system is a 2-body system, where one of these
bodies is itself a 2-body system, you're okay.
Dan
