POV-Ray : Newsgroups : povray.general : Beta 28 now available Server Time
27 Aug 2025 00:51:46 EDT (-0400)
  Beta 28 now available (Message 1 to 10 of 18)
Subject: Beta 28 now available
Date: 2 Aug 2008 11:54:54
Message: <4894834e@news.povray.org>
Beta 28 is now available for Windows 32-bit. 64-bit will follow shortly. I
will also be updating the source to beta 28 in the next day or so.
I can't at this point provide any information about the availability of
Linux binaries, however with the source updated it will be fairly easy for
Linux users to build their own.
-- Chris
Subject: Re: Beta 28 now available
Date: 2 Aug 2008 13:37:09
Message: <48949b45$1@news.povray.org>
> -- Chris
This might be a dumb question, but now that we're using an installer,
should we uninstall the old beta before installing the new one or simply
install over it?
...Chambers
Subject: Re: Beta 28 not installing on my Vista user or admin
Date: 3 Aug 2008 00:25:52
Message: <48953350$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:48949b45$1@news.povray.org...
> install over it?
I tried to install as-is and got a message stating the previous one must be
uninstalled. Says the same in the actual installer, too, but after the fact.
I figured that was best anyway but I actually saw your message here first
and thought I'd take the risk. ;)
Problem is... it never finished the install, giving a error 1925. Says it
couldn't be done without administrator privileges (or some such), and yet
the Vista OS user account was already set to that being the only one
present.
Added another account, set that to administrator and the original to
standard user. Staying logged in and switching to the new administrator
account, again the installer was interrupted by that same error 1925.
Still haven't tried going back to the now "standard" user account to try it
that way, just about to do that so I will post back here.The installer
choices (radio buttons) of one user or all did not change the end result so
far.
Date: 3 Aug 2008 00:41:18
Message: <489536ee$1@news.povray.org>
"Bob Hughes" <omniverse charter net> wrote in message
news:48953350$1@news.povray.org...
> ---8<---snip---
> it that way, just about to do that so I will post back here.The installer
> so far.
no luck going back to "standard" user account and also logging off the
administrator account (did have both logged on before). The installer seems
to want administrator privileges regardless of the "Only for me" choice.
/*bob hughes*/
Subject: Re: Beta 28 successful install Vista user
Date: 3 Aug 2008 04:34:49
Message: <48956da9$1@news.povray.org>
This is only a guess about why I succeeded in getting the beta 28 installer
to put POV onto my Vista Home notebook... UAC set to off. Simple as that
maybe. However, I don't know anything about multiple users in Windows having
seldom ever done it. And Vista is a complete unknown to me in that
department.
The installer actually greyed out the two choices for "only me" or "all", so
apparently without UAC it ignores that. Now this is the confusing part, I
believe I ran the installer from the new administrator account yet the file
was in my other user/downloads subfolder. The greyed out portion still had
the "me" option as the other user name and not the new user.
Maybe others of you know about this user account stuff and understand that,
I sure can't explain it or if it might be something peculiar to the beta 28
installer itself.
To further describe my particular experience with this, I found I needed to
get the povray.ini and quickres.ini files put back in place like I had been
using them. The readme.txt in the installation folders \Scenes\ and \ini\
certainly help but since Vista (Home anyhow) has the destination paths
hidden and a different location (AppData\Roaming) from XP or 2000, as told
of, I'm still wondering what will happen when people try to migrate from 3.6
to 3.7 and can't figure this out.
Also, trouble with writing to the \include\ subfolder, lacking permission.
What I'm doing now is making a C:\include\ folder to put INC files into and
then adding that to the povray.ini library paths, which in itself isn't
straightfoward yet since the tools.ini isn't available for editing from
within POV-Ray itself.
I don't want to be negative about the whole thing... ;^) I like the new look
and installer thus far. Congrats on the work.
/*bob hughes*/
Date: 3 Aug 2008 07:34:28
Message: <9t5b94tfhq19bkokf11js6afmdbs46k15h@4ax.com>
On Sat, 2 Aug 2008 23:25:50 -0500, "Bob Hughes" <omniverse charter net> wrote:
>present.
I had problems too. I could not install it as an administrator neither as a
single user nor multi user ??? So I switched of the User Account Control.
I disconnected from the internet then:
Switched off UAC
Restart
install Pov
Switched on UAC
Restart
Play with Pov-Ray :)
Regards
Date: 3 Aug 2008 07:53:35
Message: <48959c3f@news.povray.org>
Apologies to those who attempted to install on Vista and weren't able to.
The problem was due to the fact that despite setting the INSTALLPATH
property to the appropriate location (under AppData), Windows Installer was
still attempting to install the files into program files. This should now
be rectified. There will still most likely be weirdness installing for all
users under Vista - probably UAC will not trigger, blocking the install.
This isn't really an issue since All Users isn't fully supported yet.
-- Chris
Date: 3 Aug 2008 08:07:17
Message: <op.ufa7ygwo7bxctx@e6600>
On Sun, 03 Aug 2008 06:25:50 +0200, Bob Hughes <omniverse charter <"net>">
> it couldn't be done without administrator privileges (or some such), and
> yet the Vista OS user account was already set to that being the only one
> present.
Under Vista, with UAC enabled, even administrator accounts do not have
full administrator privileges. Either disable UAC or right-click the
executable and choose "Run as administrator".
Typically, Vista will notify you when an installer needs administrative
privileges, and prompt the user, but not always. It may have something to
do with the name of the installer; at least that is how it worked in XP.
FE
Date: 3 Aug 2008 11:40:01
Message: <web.4895d0a2a249cb29bd42b07a0@news.povray.org>
3.7 beta 28 installed perfectly on Vista Basic with UAC turned on, no errors
like the 27 version.
Date: 3 Aug 2008 17:41:50
Message: <4896261e$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:48959c3f@news.povray.org...
> was
Good to know there was a reason other than something I was doing with Vista.
Glad you figured it out Chris.
As the others have said, UAC off was what finally made sense, which must
have been the difference between a no-go and successful install. I chose to
try this in the middle of the night (again) when I wasn't thinking clearly
to begin with.
Curious thing then that the posting by SafePit here was okay even though UAC
was on... something about Vista Basic? This was another lesson for me in
using Vista, to look at UAC first not last.
/*bob hughes*/
