Consider the following POV-Ray code:
#include "functions.inc"
background{1}
location 1.5
look_at 0
isosurface{
function { f_noise3d(3*x, 3*y, 3*z) - 1/2 }
max_gradient 4
hollow
pigment { rgbf 1 }
interior{
media{
intervals 100
absorption 1
What is the reason for the black spots and is there a way to avoid them?
Thank you,
Maxime
The most common of the reasons: max_trace level.
Try: global_settings { max_trace_level 12 }
Maxime Marrow nous apporta ses lumieres en ce 2008/03/23 10:32:
> background{1}
> camera {
> location 1.5
> look_at 0
> isosurface{
> max_gradient 4
> hollow
> pigment { rgbf 1 }
> interior{
> media{
> intervals 100
> absorption 1
> Thank you,
> Maxime
Apart from the obvious isue with max_trace_level.
You may need to add "all_intersections" to your isosurface. Without that, you
will miss most surfaces after the first one encountered.
Maybe the 100 intervals are causing some artefacts.
Try this for your media:
media{ samples 300 absorbtion 1}
This will guive you the same total number of samples as your current setting.
Should be a lot faster to.
Media defaults: method 3, samples 3, intervals 1.
Don't change intervals.
Keep samples larger than 2.
Please read about media sampling method 3, whitch is the default with all
versions greater than 3.5.
In short, it's always beter to increase the samples that increasing the
intervals. LOT faster, beter quality, reduction of possible artefacts.
An unbreakable toy is useful for breaking other toys.
>> background{1}
>> camera {
>> location 1.5
>> look_at 0
>> isosurface{
>> max_gradient 4
>> hollow
>> pigment { rgbf 1 }
>> interior{
>> media{
>> intervals 100
>> absorption 1
>> Thank you,
>> Maxime
Thanks to you and Warp for the max_trace_level suggestion. I changed the
value to 20 and this removed almost all artefacts. Is there way to
remove the remaining artefacts?
> that, you will miss most surfaces after the first one encountered.
Doesn’t this apply only to isosurfaces which are used in CSG operations?
If no, can you give an example (not involving CSG) where the omission of
all_intersections results in omission of surfaces?
I tried it – the image is visually the same. It seems that the 100
intervals are not causing artefacts in this scene.
> setting.
These values contradict the values in the POV-Ray help (POV-Ray version
3.6.1c.icl8.win32). The default values for media in the help are: method
3, samples 1, 1, intervals 10.
> all versions greater than 3.5.
Thanks for this advice,
Maxime
Max_trace_level for the black spots, like Warp said,
and use accuracy 0.000001 with the isosurface
to get rid of the remaining arifacts where the isosurface
hits the containing box, then you can get away with just
media {absorption 1} and the default media sampling.
Maxime Marrow nous apporta ses lumieres en ce 2008/03/23 18:13:
>> setting.
> Maxime
I know that there is a contradiction. The values of samples 1,1 intervals 10
where valid with version 3.5 when the default was method 1. (at the time, it was
the only sampling method available)
Now, the default is method 3. Method 3 require at least samples 3 and ignore any
second samples value: samples 3,7 is the same as samples 3. The default
intervals also changed from 10 to 1.
With method 3, it's beter to increase samples. Increasing intervals greatly
increase the rendering time.
If needed, method 3 can dynamicaly create more intervals.
samples 300 // fast.
samples 3 intervals 100 // very slow, no quality gain.
Both have the same final number of samples. The first can give beter results.
At the feast of ego everyone leaves hungry.
Bentley's House of Coffee and Tea, Tucson, AZ
>>> background{1}
>>> camera {
>>> location 1.5
>>> look_at 0
>>> isosurface{
>>> max_gradient 4
>>> hollow
>>> pigment { rgbf 1 }
>>> interior{
>>> media{
>>> intervals 100
>>> absorption 1
>>> Thank you,
>>> Maxime
Anytime you have transparency.
My wife is such a bad cook, if we leave dental floss in the Kitchen the
roaches hang themselves.
Rodney Dangerfield
> background{1}
> camera {
> location 1.5
> look_at 0
> isosurface{
> max_gradient 4
> hollow
> pigment { rgbf 1 }
> interior{
> media{
> intervals 100
> absorption 1
It looks like something that is *designed* to have black spots.
John
>>>> background{1}
>>>> camera {
>>>> location 1.5
>>>> look_at 0
>>>> isosurface{
>>>> max_gradient 4
>>>> hollow
>>>> pigment { rgbf 1 }
>>>> interior{
>>>> media{
>>>> intervals 100
>>>> absorption 1
>>>> them?
>>>> Thank you,
>>>> Maxime
>> the value to 20 and this removed almost all artefacts. Is there way to
>> of all_intersections results in omission of surfaces?
That's not true. The following POV-Ray code is a counterexample:
global_settings { max_trace_level 20 }
background{1}
location 1.5
look_at 0
isosurface{
function { sin(10*x) + 0.9 }
max_gradient 10
hollow
pigment{ function{ (sin(10*y) - 0.9)*(sin(10*z) - 0.9) > 0 }
pigment_map{
[0 rgbf <0.2, 0.2, 0.2, 0.9>]
[1 rgbf 0.9]
finish{diffuse 1 ambient 1}
interior{
media{
intervals 1
samples 10
absorption 2
Maxime
I agree with your reasoning, and the documentation seems to indicate so as well.
Yet, it does work. (And IMO, decreasing the isosurface accuracy value makes the
spots worse, not better.) There *might* be a bug involved. Here's a post you
should take a look at, involving the issue of media and isosurfaces. Several of
us out here have been trying to figure out what might be going on. It's a long
post, but read it all the way to the end.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.47dd7cf19ebc6382a5d4a01d0%40news.povray.org%3E/
Ken W.
