POV-Ray : Newsgroups : povray.general : "Failed to save file:" Server Time
20 Nov 2025 22:31:40 EST (-0500)
  "Failed to save file:" (Message 1 to 10 of 18)
Subject: "Failed to save file:"
Date: 2 Nov 2007 03:34:55
Message: <472ae12f@news.povray.org>
I've been assuming (correctly) that this was a known issue and I haven't
worried too much about it, so it's taken me quite a while to get around
to asking or looking into it at all.   Anyway I get:
The process cannot access the file because it is being used by another
process."
...in a self-compiled version of POV-Ray 3.6.0 for Windows which I've
been using for a while now to avoid the spline / token_count issue.
The only entry I see on the server is this partial-thread:
http://news.povray.org/povray.beta-test/thread/%3C430daeda@news.povray.org%3E/?ttop=249422&toff=150
...in which Chris mentions it being fixed now, although that's for the
beta.   I was just wondering if  I could find out the secret to Change
3003 if it is indeed the same thing:
Change 3003 on 2004/07/22 by thorsten@host27
   Fixes file "saving" bug thanks to Massimo Valentini
Or is it just a matter of installing a newer version of the editor dll
or something?
Thanks in advance!
Charles
Subject: Re: "Failed to save file:"
Date: 2 Nov 2007 13:44:07
Message: <472b6ff7$1@news.povray.org>
Charles C nous apporta ses lumieres en ce 2007/11/02 04:34:
> process."
> or something?
> Thanks in advance!
> Charles
Are you on Windows Vista? Is POV-Ray installed in the "program files" folder?
If so, Vista don't let you edit/change/save files in that location.
The solution is simply to install into a different folder. Or you can redirect
all files to a user provided alternate folder.
Creationism: God made all shit.
Date: 2 Nov 2007 17:22:59
Message: <472ba343@news.povray.org>
> folder?
> redirect all files to a user provided alternate folder.
No, sorry I should have said this is XP.  I'm well aware of the Vista
issues though, and this is not that.  See the link.
Thanks,
Charles
Date: 2 Nov 2007 20:09:08
Message: <472bca34@news.povray.org>
> process."
Whenever I have received that message it was because the file was still
open in some other application.
Try ctrl+alt+delete to see if there's something running in the
background which may be using the file.
Sam
Date: 2 Nov 2007 21:04:56
Message: <472bd748$1@news.povray.org>
>> haven't worried too much about it, so it's taken me quite a while to
>> get around to asking or looking into it at all.   Anyway I get:
>> process."
Or get Sysinternals Process Explorer which is a far more powerful task
manager, it can actually tell you what files each app has open (and
search for a filename to see *which* app has it open).
Date: 2 Nov 2007 22:16:19
Message: <472be803$1@news.povray.org>
Charles C nous apporta ses lumieres en ce 2007/11/02 18:22:
>> folder?
> Thanks,
> Charles
OK
Check if the file exist and if it's read only or system. Same with the folder
itself.
Can you open the offending file, edit it with another application and save it back?
Is the file opened by any other application?
Do you have ownership of the file? I had some instances where files and folders
on my system got eroneous ownership, with only one user. Some folders/files had
been set with an owner whose name was just a bunch of random characters.
Is you drive full?
To the world you may be one person, but to one person you may be the world.
Date: 2 Nov 2007 23:23:22
Message: <472bf7ba@news.povray.org>
This is pretty cool.  Thanks for telling me about it.  Now to run into
the problem and see what it can tell me.  I'm pretty sure it'll tell me
that POV-Ray is using the file but this'll show it for sure.
Charles
Date: 2 Nov 2007 23:25:19
Message: <472bf82f@news.povray.org>
I'm pretty sure it's just POV-Ray.  Re-starting POV-Ray and not changing
  anything else lets me make the change and save again.
Charles
Date: 2 Nov 2007 23:34:41
Message: <472bfa61@news.povray.org>
Alain wrote:
> OK
> folder itself.
> save it back?
> folders on my system got eroneous ownership, with only one user. Some
> folders/files had been set with an owner whose name was just a bunch of
> random characters.
> Is you drive full?
Thanks Alain.  This happens with any non-read-only file in my P-Scenes
directory (which btw is not next to the installation directory) where I
continually save and re-save as I edit and test and edit and test.  It
seems to happen with just POV-Ray running, and maybe Windows Explorer.
The drive has dozens of gigs left.  It's pretty reproducable when it
happens, but it doesn't always happen.  It only happens following a
parse-error and an attempted *minor* edit and save.
Here's a better version of the link.  Hopefully it'll work a little better:
Charles
Date: 3 Nov 2007 02:24:14
Message: <472c221e@news.povray.org>
Charles C napsal(a):
>> still open in some other application.
> Charles
It seems to me POVray doesn't close the file handle and tries to open a
new one. This fails because there cannot be two file handles to the same
file if one of them is a writable one.
I've never seen the POVray code but if handle closing depends on a
garbage collector+destructor then this is certainly wrong. In this case
either force GC before opening a file or, if that fails, trace the
references to it (if you don't mind debugging yourself).
You can use Sysinternals taskmanager to see if the image handle is still
open by POVray.
