POV-Ray : Newsgroups : povray.general : Polygon masking possibility? Server Time
11 Jun 2026 15:20:36 EDT (-0400)
  Polygon masking possibility? (Message 1 to 8 of 8)
Subject: Polygon masking possibility?
Date: 27 Oct 2006 04:09:55
Message: <4541bed3$1@news.povray.org>
Hello,
   I'am now working on some bitmap based grass, bush etc. I'am trying to
place a lot of rectangles with bitmap grass patches on the groud.
Bitmaps are partially transparent. The result is, that I have a lot of
rectangles on every ray hittng the ground, so I must set very high
max_trace_level to render it correctly...
My idea is to create some "masked_polygon", or to add a "mask" into the
polygon and use this mask when determing, if some ray hits the polygon.
When the ray hits completely transparent part of the polygon, consider
it as "no hit" and return hits only with full opaque or semi-transparent
parts. Something like
#declare BitmapPig = pigment {
   image_map {png "something.png"}
polygon {
   5, <0, 0>, <1, 0>, <1, 1>, <0, 1>, <0, 0>
   mask {BitmapPig}
   pigment {BitmapPig}
This will remove the neccesasrity of high max_trace_level and I think,
that it can be faster, than shooting new ray from every hitted, but
completely transparent part of polygons.
What do you think about this?
Regards
Vaclav
Subject: Re: Polygon masking possibility?
Date: 27 Oct 2006 07:08:08
Message: <4541e898$1@news.povray.org>
Vaclav Cermak schrieb:
> Hello,
> polygon {
>   mask {BitmapPig}
>   pigment {BitmapPig}
Not the answer, but you might consider bounding boxes (see "bounded_by"
pov-help 3.4.9.2), if your bitmap doesn't vary much. So you can clip
parts of the polygons that are always transparent. But you have to
declare a nice bounding-shape...
KK
Date: 27 Oct 2006 20:06:27
Message: <45429f03$1@news.povray.org>
Vaclav Cermak wrote:
> Hello,
Make a mesh for each unique piece of bitmap.  Don't put triangles except
where there's grass.
Color the ground like dirt.
When I want to do grass, I generally make a mesh (or a few meshes),
representing a patch of grass.  The I copy it a bunch of times, with
rotation and skewing, to eliminate a tiled appearance.
John
Date: 28 Oct 2006 05:15:24
Message: <45431fac$1@news.povray.org>
Speaking from a technical point of view I don't think it's possible. It's a
good idea but pov can only check the mask for a polygon after computing a
ray intersection with that polygon, meaning it's doing exactly the same
amount of work as just having a high max_trace_level.
Tek
http://evilsuperbrain.com
"Vaclav Cermak" <dis### [at] disnelcom> wrote in message
news:4541bed3$1@news.povray.org...
> Hello,
> place a lot of rectangles with bitmap grass patches on the groud. Bitmaps
> are partially transparent. The result is, that I have a lot of rectangles
> on every ray hittng the ground, so I must set very high max_trace_level to
> When the ray hits completely transparent part of the polygon, consider it
> polygon {
>   mask {BitmapPig}
>   pigment {BitmapPig}
> Regards
> Vaclav
Date: 28 Oct 2006 07:00:16
Message: <45433840@news.povray.org>
But then there is no need to have high max_trace_level at all, this can
lead to faster rendering of other parts of the scene.
I don't know POV internal structure well, but probably you are right,
POV must first determine, if the ray intersects that polygon and then
look, if the polygon is transparent at the intersection point or not.
But all overhead caused by need of shooting new ray is removed (I don't
know, how much it is, can be saved some work with etc bounding??).
V.
Date: 28 Oct 2006 07:04:45
Message: <4543394d$1@news.povray.org>
Godd idea, will try it.
Also good idea, but such a grass is very slow with radiosity, bitmap one
looks promising in my current tests. It is also slow, but acceptable ;-))
> Regards,
> John
Date: 28 Oct 2006 07:11:18
Message: <20061028121119.2ef3e731@mekanori.mon.istic.org>
>don't know, how much it is, can be saved some work with etc
>bounding??).
The only cost saved is that of initializing a new RAY structure in
memory, which is tiny. However, your scheme would mean that every
time a ray-object intersection is performed, POV-Ray has to check
whether there is a mask object, and of course it increases code size
slightly. This would slow down the general case (where there is no
mask) just as much as it speeds up this particular case, and as the
general case is more common, it results in an overall slow-down.
Sufficiently advanced humour is indistinguishable from tedium.
corollary:
Humour distinguishable from tedium is insufficiently advanced.
http://surreal.istic.org/          Calm down, it's only ones and zeroes.
Date: 28 Oct 2006 17:27:19
Message: <4543cb37$1@news.povray.org>
Vaclav Cermak nous apporta ses lumieres en ce 28/10/2006 07:03:
> V.
>> It's a good idea but pov can only check the mask for a polygon after
>> computing a ray intersection with that polygon, meaning it's doing
>> exactly the same amount of work as just having a high max_trace_level.
In that case, you can use adc_bailout with a slightly smaller value than the
default (about 1/256).
That way, you don't always go to the max_trace_level. Also, if there is no
reflection nor refraction, or only refraction or only reflection, you stay with
only one ray, meaning minimal slowdown.
If you choke a Smurf, what colour does he go!
