POV-Ray : Newsgroups : povray.general : joining objects for latter manipulation Server Time
11 May 2026 06:03:18 EDT (-0400)
  joining objects for latter manipulation (Message 1 to 8 of 8)
Subject: joining objects for latter manipulation
Date: 15 Jun 2005 10:22:49
Message: <42b039b9$1@news.povray.org>
I would like to join spheres into a single object for easier manipulation
(rotation for example):
OBJECT {BALLS =
 #declare Count=0;
 #while (Count < 5)
  sphere { <(-2+Count), Count, Count>, 1
   pigment {  color rgb <0.4 0.8 0.8>}
  #declare Count=Count+1;
}; ROTATE BALLS <0 90 45>
Subject: Re: joining objects for latter manipulation
Date: 15 Jun 2005 10:39:41
Message: <42b03dad$1@news.povray.org>
> OBJECT {BALLS =
>  #declare Count=0;
>  #while (Count < 5)
>  #end
#declare BALLS = union
   #declare Count=0;
   #while (Count < 5)
object { BALLS rotate  <0 90 45> }
~Mike
Things! Billions of them!
Date: 15 Jun 2005 11:16:14
Message: <42b0463e@news.povray.org>
Can you then multiply this object and position them into different places
(translation, repositioning)?
Like:
BALLS Bplanes[5];
#declare Count=0;
#while (Count < 5)
 Bplanes[Count]
  NEWPOSITION <Count 0 0>
  rotate  <0 20*Count 45>
Date: 15 Jun 2005 11:45:52
Message: <42b04d30$1@news.povray.org>
OK, i've found this one: object { BALLS translate x*20 }.
Still searching for multiplication, like:
> BALLS Bplanes[5];
Date: 15 Jun 2005 11:59:47
Message: <42b05073$1@news.povray.org>
> Like:
> BALLS Bplanes[5];
> #declare Count=0;
> #while (Count < 5)
>  Bplanes[Count]
> #end
Just:
  #declare Count=0;
  #while (Count < 5)
    object { BALLS rotate <0 20*Count 45> }
~Mike
Date: 15 Jun 2005 12:42:58
Message: <42b05a92$1@news.povray.org>
Thank you.
Can you move the reference point (coordinate system) for the rotation?
I translate the object <0 0 10>. From there I would like to rotate <0 90 0>.
Right now, I still rotate from <0 0 0> so the object is also translated.
Date: 15 Jun 2005 13:01:40
Message: <6CYNfDAs7FsCFwlR@econym.demon.co.uk>
Wasn't it Andrej who wrote:
>Thank you.
You have to translate the object to the origin, rotate it there and
translate it back. Or you could use Rotate_Around_Trans() which does
exactly those operations.
#include "transforms.inc"
object {BALLS
  transform { Rotate_Around_Trans(<0,90,0>, <0,0,10>) }
Mike Williams
Gentleman of Leisure
Date: 15 Jun 2005 14:08:17
Message: <42b06e91@news.povray.org>
Mike Williams <nos### [at] econymdemoncouk> wrote:
> object {BALLS
  I don't think the 'transform' is strictly necessary there.
  And by the way, you can also do it like this (which is actually how
that macro does it):
translate -LocalOrigo
rotate whatever
translate LocalOrigo
