POV-Ray : Newsgroups : povray.general : White gas Server Time
18 Feb 2025 17:51:05 EST (-0500)
  White gas (Message 1 to 8 of 8)
Subject: White gas
Date: 3 Jun 2005 16:12:31
Message: <42a0b9af@news.povray.org>
Is it possible to create a white non-emitting gas in radiosity
environment without light sources (light_source)?
Subject: Re: White gas
Date: 3 Jun 2005 17:32:41
Message: <42a0cc79$1@news.povray.org>
No, radiosity can't illuminate scattering media. You can still get the
absorption effect, of course.
However, you can fake the illumination with emitting media, if you carefully
construct a density pattern which has higher values in areas which would be
lit up. Unfortunately, this must be done manually.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Jun 2005 19:17:02
Message: <42a0e4ee@news.povray.org>
In this case the faked scattering can brighten (or completely wipe) some
shadowy areas, which can be inacceptable for some scenes. Also the gas
(media) does not take into account the environmental lighting (for the
scattering effect), because it does not scatter (diffusely reflect) light.
Will POV-Ray support at least type 1 scattering for radiosity environment?
Thank you,
William
Date: 3 Jun 2005 20:41:26
Message: <42a0f8b6$1@news.povray.org>
I'm not *exactly* sure what you're saying here, but I'm pretty sure that, if
scattering media interacted flawlessly with radiosity (and so was lit up
exactly correctly), it would be (theoretically) possible to sample it in
terms of density and illumination (as long as we're talking about scattering
type 1), and use the density data for an absorption media and the
illumination data for emission media, creating exactly the same result. So
what I was suggesting was that you guess at the illumination data and use it
in emission media to do just that.
Yes, this may brighten up some shadowy areas. But that would happen anyway
with scattering media that responded to radiosity: light bouncing off a
surface would brighten the media (that is, reflect off it) and then that
would hit the shadowed areas, brightening them.
I don't speak for the POV Team but AFAIK there aren't any plans for this. I
would also worry about its speed if it were implemented.
 - Slime
Date: 4 Jun 2005 04:15:02
Message: <d7rnqo$3q2$1@chho.imagico.de>
You can use scattering media in radiosity scenes without problems and
scattering media is taken into account by radiosity when you use 'media
on'.  The only limitation is that for the media simulation the diffuse
lighting is not taken into account.
Doing this would not be completely impossible but it would be quite
different from how radiosity works on surfaces and increase in memory
use and calculation time would be enormeous.  You can assume they will
be similar to memory use of media photons compared to surface photons
(just that for media photons only the memory use is much larger and not
the calculation time).
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 4 Jun 2005 06:48:09
Message: <42a186e9@news.povray.org>
This limitation can be inacceptable for scenes which contain mainly/only
diffuse lighting.
Maybe there is a resource effective way to do that.
William
Date: 4 Jun 2005 07:00:02
Message: <d7s1f9$7nl$1@chho.imagico.de>
I thought i made it clear that the required time and memory would be
enormeous no matter how efficient the implementation is.
Date: 4 Jun 2005 07:02:30
Message: <42a18a46$1@news.povray.org>
Faking scattering with emission will not create "exactly the same
result" if the illumination of the nearby objects is different in the
long run.
> with scattering media that responded to radiosity ...
The difference in the brightening can be significant - sufficiently to
compromise the overall reality of the scene.
William
