POV-Ray : Newsgroups : povray.general : Is this an effective approach for large projects? Server Time
13 Aug 2025 12:41:21 EDT (-0400)
  Is this an effective approach for large projects? (Message 1 to 10 of 10)
Subject: Is this an effective approach for large projects?
Date: 14 Feb 2005 21:29:31
Message: <42115e8b$1@news.povray.org>
I'm going to work on a project to create a virtual museum and render
images from many points within it with a spherical camera to view on the
inside surface of a sphere in an OpenGL program.
Would it be effective to have macros to create scene files with their
contents depending on the location of the camera rather than having
scene files that each contain an entire floor of the museum?
I'm thinking of making data files with information about rooms that
macros could read. Then the code that the macros write would depend on
the given location of the spherical camera. That way, only the rooms and
objects that are visible from the current location are parsed and
rendered. What those macros would do is to use the data files to
determine what room the camera would be in and check for things like
doorways and windows other rooms could be visible through. Then a scene
file that includes the include files for those rooms would be written.
Had anyone done something like this before?
Brendan
Subject: Re: Is this an effective approach for large projects?
Date: 15 Feb 2005 16:39:53
Message: <2559882.U0UYy4bKFR@raf256com>
I would suggest to use a shell script to render all scenes, script could
write some temporary file (based on current timestamp) and pass name of
such configuration file to POV-Ray using -Ddeclare=... command line option.
Seems like another good approach. Or, perhaps, it would be best to write a
small C program to generate POV-Ray syntax list of locations to some
location.inc? I suggest to use with programming language You find most
comfortable :)
Rafal Maj Raf256
Date: 16 Feb 2005 20:48:33
Message: <4213f7f1$1@news.povray.org>
Go ahead and split the building up into different rooms, but don't write
complicated code to only draw visible parts. If you find that it's too slow
to render, *then* you can write that code to speed things up, but it might
not be a problem.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 17 Feb 2005 19:00:54
Message: <42153036$1@news.povray.org>
"Brendan Ryan" <bjr### [at] ritedu> wrote in message
news:42115e8b$1@news.povray.org...
You do know that a sky box is faster and more accurate than a sky sphere in
opengl, right?  You only have 6 quads and because they are squares, you have
less distortion on your textures.
cu!
Date: 17 Feb 2005 22:35:36
Message: <42156288$1@news.povray.org>
If I make images for a sky box, I'd use orthographic cameras pointed in
six directions from each location. Maybe I could do experiments to see
the difference.
Brendan
Date: 17 Feb 2005 22:37:33
Message: <421562fd$1@news.povray.org>
> not be a problem.
Ok, I don't have a complete list of the stuff I'll put into the museum,
so I don't know how big each room and floor would be yet. So, I'll wait
to see if it grows large and slow.
Brendan
Date: 17 Feb 2005 22:40:40
Message: <421563b8$1@news.povray.org>
Ok, I'll need to experiment with passing command line options to the
windows version of povray because I haven't done that before.
> comfortable :)
If the projects becomes large and slow even after being divided into
multiple files and too large to easily manage by hand, I'll try writing
a C++ program to read the data files about the rooms and generate the code.
Brendan
Date: 17 Feb 2005 22:45:30
Message: <421564da$1@news.povray.org>
> the difference.
No; it's important to use perspective cameras. The idea is to map each point
on the "sky box" to the color you see when you look from the center of the
box in that direction. This can only be achieved with perspective cameras.
 - Slime
Date: 23 Feb 2005 06:48:54
Message: <421c6da6$1@news.povray.org>
I read something about having to use a 90 degree field of view for this
purpose. Would the default values for the camera parameters work? I'll
need to review the stuff on the camera in the manual.
Brendan
Date: 23 Feb 2005 18:20:21
Message: <421d0fb5@news.povray.org>
You do need a 90 degree field of view. (Think about it like this: 4 sides of
a cube = 360 degrees, so 90 degrees for each side.) Also, you need square
images (since they'll be sides of a cube). The default camera is made for a
4:3 aspect ratio, so this needs to be changed. This should work:
location 0
direction z
up y
right x
look_at z // set to which side of the "cube" you want to render. (+-x, +-y,
+-z)
 - Slime
