POV-Ray : Newsgroups : povray.general : Images on a Sphere Sweep Server Time
10 Sep 2025 19:28:03 EDT (-0400)
  Images on a Sphere Sweep (Message 1 to 4 of 4)
Subject: Images on a Sphere Sweep
Date: 10 Feb 2005 07:22:11
Message: <420b51f3$1@news.povray.org>
I'm using a sphere sweep for a cat5 cable (that blue ethernet cable
hanging out the back of your computer). Along a real cable is a text
designation declaring the cable to be cat5 (or 6). I want to include
that in my model. However the shere sweep is (surprise!) not a straight
line.
Is there any way to do this? What if the sweep was made up of many REAL
spheres or cylinders (each cylinder would be a lot smaller than the text
so I can't just put the text on every nth cylinder)
Any help, as usual, will be greatly appreciated.
Cheers!
Subject: Re: Images on a Sphere Sweep
Date: 10 Feb 2005 09:50:19
Message: <LwEhTAAkK3CCFwQk@econym.demon.co.uk>
>line.
I guess you need uv_mapping, but that's not currently available for
sphere sweeps. What you might be able to do is to use the SweepSpline
macro to produce a mesh that closely approximates the sphere sweep,
since uv_mapping is available for meshes.
See the last section of page
<http://www.econym.demon.co.uk/isotut/more.htm>
Mike Williams
Gentleman of Leisure
Date: 11 Feb 2005 12:55:01
Message: <web.420cefed5d0d0bd2fcabfe660@news.povray.org>
> >line.
> Mike Williams
I'm a newbie, but I would think that if you're able to do a cylindrical
image map and somehow use a spline for a path with it, it might work?  just
an idea.
Date: 11 Feb 2005 17:12:47
Message: <420d2ddf@news.povray.org>
"Rick Measham" <nomail@nomail> wrote in message
news:420b51f3$1@news.povray.org...
> line.
> Cheers!
> Rick
Why not cut text, made with the text object out of the side of the sphere
sweep.
You can use the Spline_Trans() macro from "transforms.inc" to position it
along a cubic spline, so as long as you use the cubic spline for your sphere
sweep too, then it should line all up.
I've put a sample source file on povray.binaries.scene-files and an image on
povray.binaries.images.
(see "Text on Sphere Sweep")
Chris B.
