POV-Ray : Newsgroups : povray.general : Improved Perlin noise Server Time
15 Jan 2026 14:19:58 EST (-0500)
  Improved Perlin noise (Message 1 to 9 of 9)
Subject: Improved Perlin noise
Date: 5 Jul 2004 23:44:28
Message: <40ea201c$1@news.povray.org>
29. June Mike Andrews posted an image to
povray.binaries.images:
"Perlin's Improved Noise comparison ... (24K)"
The same day he also posted code for his test image to
povray.binaries.scene-files:
"Perlin's Improved Noise - SDL version"
I have now had a look at his code and have made a macro
that can produce noise functions that don't have the
"defects" of earlier Perlin noise functions. (I haven't
really verified this, but the results seems ok so far.)
My macro can be found in my reply today to his post
in povray.binaries.scene-files
I haven't yet looked at the source code for the noise
generators in POV-Ray v3.5 (or v3.6), so I don't know
if any or all of them use the "old" Perlin noise.
Tor Olav
http://subcube.net
http://subcube.com
Subject: Re: Improved Perlin noise
Date: 6 Jul 2004 04:00:02
Message: <ccdltk$1rp$1@chho.imagico.de>
There are two critical issues about the noise generator: 1) possible
regularities.  This does not only mean regular structures in the noise
pattern like in current ng3 but also periodicity and degeneration of the
function in 'far areas'.  This all can be really tricky to test of
course.  2) performance.  This is quite impossible to conclude from an
SDL version.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 6 Jul 2004 07:24:48
Message: <40ea8c00$1@news.povray.org>
> course.
You can give the periodic interval as an argument to the
macro. This makes it easy to study the periodicity when
the interval is set small.
Do you know where the 'far areas' are and how the functions
typically degenerates ?
> SDL version.
Why is that ?
The macro can produce noise functions that behave simlar
to f_noise3d()
Tor Olav
http://subcube.net
http://subcube.com
Date: 6 Jul 2004 07:45:02
Message: <cce3a9$67a$1@chho.imagico.de>
For most purposes the noise generator should have a periodicity as large
as possible.
try rendering:
   orthographic
   location <0,0,1>
   look_at  <0,0,0>
   right 1*x
   up 1*y
box {
   <-0.5, -0.5, 0>, <0.5, 0.5, 0>
       bozo
       color_map {
         [0.0 color rgb 0.0 ]
         [1.0 color rgb 1.0 ]
       scale 0.01
       translate 3e7*x
     finish {
       ambient 1.0
       diffuse 0.0
>> SDL version.
> Why is that ?
> to f_noise3d()
But much slower.  The noise generator is quite critical for the render
speed in a lot of scenes.  That's why the Windows version of POV-Ray
contains a special hand optimized version of the noise function.
Date: 6 Jul 2004 08:26:33
Message: <40ea9a79$1@news.povray.org>
> as possible.
> try rendering:
> camera {
>   orthographic
>   location <0,0,1>
>   look_at  <0,0,0>
>   right 1*x
>   up 1*y
> box {
>   texture {
>     pigment {
>       bozo
>       color_map {
>       scale 0.01
>       translate 3e7*x
>     finish {
>       ambient 1.0
>       diffuse 0.0
I see. But this works ok:
       function { f_noise3d(x + 3e7, y, z) }
       color_map {
       scale 0.01
>>> SDL version.
>> Why is that ?
>> to f_noise3d()
Nice to know.
Tor Olav
http://subcube.net
http://subcube.com
Date: 6 Jul 2004 08:52:47
Message: <40eaa09f$1@news.povray.org>
- But now the results doesn't seem ok any longer.
When I render this scene, I can see vertical and
horizontal "lines" in the noise.
#declare NoiseFn = PerlinNoise3DFunction(478696, 300, 0, 1)
box {
       function { NoiseFn(x, y, z) }
       color_map {
       scale 0.01
     finish {
       ambient 1.0
       diffuse 0.0
   orthographic
   location <0,0,1>
   look_at  <0,0,0>
   right 1*x
   up 1*y
If make the macro not use the POV-Ray's rand() function,
the noise improves a bit.
Tor Olav
http://subcube.net
http://subcube.com
Date: 7 Jul 2004 13:01:03
Message: <40ec2c4f$1@news.povray.org>
Hmmm... When I replace "NoiseFn(x, y, z)" in the
code below with "f_noise_generator(x, y, z, 3)" from
"functions.inc" I see the same short "lines".
With "f_noise_generator(x, y, z, 2)" I get no such
lines. - The results seems more random with this
noise generator.
> box {
>   texture {
>     pigment {
>       color_map {
>       scale 0.01
>     finish {
>       ambient 1.0
>       diffuse 0.0
> camera {
>   orthographic
>   location <0,0,1>
>   look_at  <0,0,0>
>   right 1*x
>   up 1*y
Tor Olav
http://subcube.net
http://subcube.com
Date: 7 Jul 2004 13:15:02
Message: <cchar4$kku$1@chho.imagico.de>
> noise generator.
This is exactly the problem of NG3.
Date: 7 Jul 2004 13:48:21
Message: <40ec3765$1@news.povray.org>
>> noise generator.
OK, so it's not my coding that is bad.
I see now that this problem has been discussed before in
a thread that Ingo started in povray.beta-test.binaries
back in 22. Oct. 2001: "noise_generator histograms"
http://tinyurl.com/25c39
Tor Olav
http://subcube.net
http://subcube.com
