POV-Ray : Newsgroups : povray.general : The world is glowing Server Time
30 Mar 2026 12:30:58 EDT (-0400)
  The world is glowing (Message 1 to 9 of 9)
Subject: The world is glowing
Date: 18 Jun 2004 02:09:40
Message: <40d28724$1@news.povray.org>
//Here is a Glow object, with 3 differents densities, spherical, boxed,
cylindrical.
//Is it possible to get an object like  Torus_glow,Text_glow,
everything_glow  etc
//Thanks a lot
//Friendly
//Sylvain
// GLOW001
#declare toto=  0.5/0.1  ;
union {//Start
#macro Glowc(GlowColor, Scale, FadeDistance, FadePower) // From Warp
               sphere  { 0, 1
                        hollow
                        no_shadow
                        pigment   { rgbft <1,1,1,0,1> }
                        interior  { media
                                    { emission 1/Scale
                                      density {
        //Here is 3 ways. How to get torus form ? etc...
//spherical
boxed
//cylindrical
                                         density_map
                                        { [0 rgb 0]
                                          [0.3 rgb 0] //couronne
                                          [0.5 rgb GlowColor*.5/toto]
                                          [1 rgb GlowColor*1]
             warp {turbulence <0,0,0> octaves 4 omega 0.3 lambda 3}
              }  scale 1
                                      samples 1,1
                                      intervals 1
                                      confidence 0.1
                                      method 3
                        scale Scale
object {Glowc(<1,1,1>*1*1, 1 ,6,2   )}
scale <1,1,1>
rotate <0,0,0>
translate <0,0,0>
}//end GLOW
// ********  OBJECTS  *******
box {  <-1, -1, -1>, <1, 1, 1> pigment {color rgb <1,1,1>}
  hollow
  scale <7.234578, 15.856436, 13.15844>
  translate  <-4.549722, -9.695265, 12.010537>
camera {  //  Camera Camera01
  location  <     -2.524,     -10.435,       2.208>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.33811,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray) aspect
ratio
  angle         17.86818    // Vertical      13.401
  look_at   <      0.039,      -0.151,       0.036>
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  photons {
  translate  <0.984692, -14.212549, 19.073553>
Subject: Re: The world is glowing
Date: 18 Jun 2004 09:19:45
Message: <40d2ebf1@news.povray.org>
leseur sylvain nous apporta ses lumieres ainsi en ce 18/06/2004 02:09... :
>cylindrical.
>everything_glow  etc
>//Thanks a lot
>//Friendly
>//Sylvain
>// GLOW001
>union {//Start
>              // sphere  { 0, 1
//Use a torus as a container:
          torus{.5, .25
>                        hollow
>                        no_shadow
>                        interior  { media
>                                    { emission 1/Scale
>                                      density {
>//spherical
>//boxed
>//cylindrical
wood rotate 90*x
>                                         density_map
>                                        { [0 rgb 0]
>                                          [1 rgb GlowColor*1]
>              }  scale 1
>                                      samples 1,1
>                                      intervals 1
>                                      confidence 0.1
>                                      method 3
>                        scale Scale
>#end
>scale <1,1,1>
>rotate <0,0,0>
>translate <0,0,0>
>}//end GLOW
>  hollow
>handed-system
>ratio
>  <0.0, 0.0, 0.0>
>  photons {
There are other ways to have some pattern in a media.
If you want a toroidal media, use a torus as a container. I've tested
that with a wood pigment as a density pattern and the result is interesting.
In fact, you can use just about any pigment pattern as a base for your
density.
Date: 18 Jun 2004 09:47:07
Message: <40d2f25b$1@news.povray.org>
interesting.
> density.
> Alain
Ok thanks a lot...
But i'm not able to build this kind of pattern can you give me a exemple ?
And for the "text/glow" do you have an idea?
Thanks again
friendly
Sylvain
Date: 18 Jun 2004 10:08:09
Message: <40d2f749$1@news.povray.org>
leseur sylvain nous apporta ses lumieres ainsi en ce 18/06/2004 09:46... :
>interesting.
>>density.
>>Alain
>Ok thanks a lot...
>Thanks again
>friendly
>Sylvain
In your sample scene, change your containing sphere to: torus{.5, .25...
Comment out boxed, spherical and cylindrical.
Add: wood rotate 90*x
Thats all!
You may try granite with this density_map:
[.75 rgb 0]// Mostly empty
[.9 rgb 5]// but with some high density spots
For the text, give it a transparent pigment: pigment{rgbt 1}
Then give it an unpatterned media. It will look like:
interior{media{emission 1 density{ rgb 1}}}}
That media will probably have to have a high density.
Date: 18 Jun 2004 10:12:44
Message: <40d2f85c$1@news.povray.org>
Thanks again again. I try that
Friendly Sylvain
> Thats all!
> Alain
Date: 18 Jun 2004 10:48:40
Message: <40d300c8$1@news.povray.org>
leseur sylvain nous apporta ses lumieres ainsi en ce 18/06/2004 10:12... :
>Friendly Sylvain
>>Thats all!
Scale the pigment by .5 give something more interesting.
>>Alain
One more experiment you may try:
crackle scale .4
density_map{[.01 rgb 2][.12 rgb 0][.7 rgb 0][.9 rgb<2,0,0>]
An irregular 3D latice with some red fuzy spots
Date: 18 Jun 2004 11:34:17
Message: <40d30b79$1@news.povray.org>
That's working!
Thanks a lot. Now i "work" on text.
If you haves tips, no troubles i take then.
Friendly
Sylvain
Date: 18 Jun 2004 18:32:28
Message: <40d36d7b@news.povray.org>
Could you please stop quoting the entire original article when it's not
necessary?
  Just quote the *relevant* part of the original article (or nothing at
all if there isn't any specific short relevant part you are answering to
but you are answering to the original article as a whole).
  Quoting the entire original article and answering at the end just
makes it more difficult to find your answer and wastes valuable server
space and bandwidth for no good reason.
Date: 19 Jun 2004 10:52:18
Message: <40d45322$1@news.povray.org>
Warp nous apporta ses lumieres ainsi en ce 18/06/2004 18:32... :
Sory, I forgot to snip
