POV-Ray : Newsgroups : povray.general : JCGrid (a tools for POVRay rendering on clusters) Server Time
1 Feb 2026 13:26:17 EST (-0500)
  JCGrid (a tools for POVRay rendering on clusters) (Message 1 to 10 of 15)
Subject: JCGrid (a tools for POVRay rendering on clusters)
Date: 13 May 2004 10:24:15
Message: <40a3850f$1@news.povray.org>
I have written a tool for POVRay rendering on clusters. The name of the
tool is JCGrid. Thanks to JCGrid, you can use as many
Workstations/PCs/Macs as you like for the rendering of a single POVRay
image.
It doesn't require a any patch for POVRay and it works running POVRay
like an external command. Any file required for the rendering is
transferred between the nodes of the grid by JCGrid. Once you have setup
a JCGrid, it can be used by many user even at the same time. You can
look at a POVRay JCGrid like a rendering service. Check the demos page
for some interesting performance comparison.
The homepage is at http://jcgrid.sourceforge.net/
You can download sources and binaries from:
http://sourceforge.net/project/showfiles.php?group_id=109146
Just to give you a raw idea of the kind of performance results you
obtain by using JCGrid:
Rendering time (Plants.pov available at http://www.f-lohmueller.de/
image 1280x1024 AA enabled)
POVRay
1xAthlon XP 1800+ (BogoMIPS=3014)
Total rendering time = 01:58:29 (184pixel/sec) (1.0 speed-up)
Total Grid BogoMIPS = 3014 (1.0 speed-up)
Total Grid Index = 1.00 speed-up
Grid 1 with JCGrid(128 fragment size)
[1xAthlon XP 1800+ (BogoMIPS=3014)] => Server+Client+1xWorker
Total rendering time = 01:26:07 (253pixel/sec)
Total Grid Index = 0.89 speed-up
Grid 2 with JCGrid(128 fragment size)
[1xAthlon XP 1800+(BogoMIPS=3014)] => Server+Client+1xWorker
[2xAthlon MP 2800+(BogoMIPS=2x4246)] => 2xWorker
Total rendering time = 00:17:40 (1235pixel/sec)
Total Grid BogoMIPS = 11506 (3.81 speed-up)
Total Grid Index = 4.34 speed-up
Grid 3 with JCGrid(128 fragment size)
[2xAthlon MP 2800+ (BogoMIPS=2x4246)] => 2xWorker
Total rendering time = 00:10:20 (2110pixel/sec)
Total Grid BogoMIPS = 19998 (6.63 speed-up)
Total Grid Index = 7.42 speed-up
Grid 3b with JCGrid(64 fragment size)
Total rendering time = 00:11:13 (1946pixel/sec)
Total Grid Index = 6.85 speed-up
NOTE: JCGrid is in a very early stage of the development so be patience
if the documentation is incomplete or if the tool is untested (any help
is wellcome).
David Bucciarelli
Pisa
Italy
Subject: Re: JCGrid (a tools for POVRay rendering on clusters)
Date: 13 May 2004 12:20:02
Message: <c8073v$od3$1@chho.imagico.de>
> image.
Very well but you miss the most important information: *how* are the
files transferred between the nodes?
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 14 May 2004 03:22:14
Message: <40a473a6@news.povray.org>
>> the tool is JCGrid. Thanks to JCGrid, you can use as many
>> image.
A working directory and a session name is defined each time you run a
JCGrid client. The client sends the list of files/subdirectories in the
working directory with MD5 checksum and size to the server.
The server checks the cache and if the file/subdirectory doesn't exists
or if the MD5 checksum doesn't match, it requires to the client to send
the entire file.
There is exactly the same kind of interaction between the server and all
the workers. The client and all the workers are connected to the server
by using sockets.
Only required files will be transfered and only modified files will be
transferred between different runs with the same session name.
It works very well with POVRay: you can put all the files of a scene in
a directory, use that directory like the JCGrid client working directory
and run the rendering. You can modify some file and rerun the rendering
(and only modified files will be transferred).
I hope this has answered to your question.
David Bucciarelli
Pisa
Italy
Date: 14 May 2004 04:05:02
Message: <c81uit$21i$1@chho.imagico.de>
No, i was not asking for the caching mechanism, i was interested in
information about the method of *transport* of data between the nodes.
I assume some kind of network protocol.  Are there
authentification/encryption techniques used (would be important for use
via internet)?
Date: 14 May 2004 05:34:38
Message: <40a492ae$1@news.povray.org>
> information about the method of *transport* of data between the nodes. I
> via internet)?
The client and all the workers are connected to the server by using
TCP/IP sockets. The default port 10101 is used by the server to receive
client connections and default port 10102 is used to receive worker
connections. You can use command line options in order to change default
ports. The clients and workers can be beyond a NAT. If the server is
beyond a NAT, you have to map used ports to the server.
The JCGrid communication protocol between client/server/worker uses Java
Object Serialization in order to exchange messages. Exchanged data can
be compressed (GZIP) by using a command line option in order to save
bandwidth. SSL encryption can be enabled by using a command line option
too. The access to the server can be restricted by using a password.
You can setup public grid over Internet with anonymous access. People
can donate their CPU time and use other user's CPU like in P2P network.
NOTE: JCGrid is still in a very early stage of the development and
setting up a public anonymous Grid is too dangerous. Enabling encryption
is untested too and require some more complex setup (creating the Java
keystore, etc.).
Any other question ?
David Bucciarelli
Pisa
Italy
Date: 29 May 2004 11:35:59
Message: <40b8addf$1@news.povray.org>
> image.
Version 0.03 is now available.
Change log since 0.02: JCGridWorker can now run multiple workers (useful
on SMP); Investigated the "Failed to execute" problem under RedHat 9.0;
Grid statistics can be accessed by using the GUI; Grid statistics are
now available; Grid administration mechanism is now available; New class
design in the server package; The GUI client for POVRay now supports
partial image rendering; Written a GUI client for POVRay.
Since 0.01:  Written installation instruction for Windows; Will
Lloyd-Davies has written the scripts for using JCGrid with POVRay under
Windows; Docs are now included in binary releases.
David Bucciarelli
Pisa
Italy
Date: 31 May 2004 10:20:22
Message: <40bb3f26$1@news.povray.org>
Hi, How well will this work for animations across, say 150 computers?
Thanks,
Dennis
"David Bucciarelli" <dav### [at] tinit> wrote in message
news:40b8addf$1@news.povray.org...
> > image.
> David Bucciarelli
> Pisa
> Italy
Date: 31 May 2004 11:26:44
Message: <40bb4eb4@news.povray.org>
The larger grid I have ever used until today includes 8 nodes: 3xDual
Athlon SMP and 2xPC. It is something very small compared to one with 150
nodes so the true answer is: I don't know :-)
Anyway, I don't see why it shouldn't work. The performances of a so
large grid will be highly related to the amount of data (.pov files,
etc.) JCGrid needs to transfer between the server and the nodes for the
rendering.
JCGrid uses a centralized model (1 server, many workers) and this model
can not scale up infinitely. However the limit can be very high for a
time consuming task like rendering.
In a grid with 150 nodes, if the rendering of a single image fragment
requires 3 minutes, the server will have to handle something like 1 or 2
requests for seconds (a low load for a good workstation). More time
requires the rendering of the single image fragment and less load the
server has to handle.
I would really like to run a test on a 150 nodes grid.
David Bucciarelli
Pisa
Italy
Date: 1 Jun 2004 03:38:15
Message: <40bc3267@news.povray.org>
>> image.
i seem to have a couple of minor problems,
first was a classpath error, but did a re-install of j2sdk1.4.2, seems
to have gone now (rtfm next time) - works now on dual p3-1ghz, now to
fix the xeon :-)
xeon now ok
second is
edited the .sh scripts for server/worker/client and fired them off
box sizes in gui are rather squished, in particularly the host and
session name boxes
using the gui to select an ini file, browse to /usr/share/povray-3.5/ini
and select allscene.ini, gives "-3.5/ini/allstill.ini" on clicking ok
should give "/usr/share/povray-3.5/ini/allscene.ini"
another silly suggestion, check if JAVA_HOME is none null before
configuring as /opt.... ?
looking better
in the scripts i see the server option as
  -server org.homedns.dade.jcgrid.cmd.povray.JCGridServer
is there an explanation of what this does?
should it be something different on home network of
[amd32|xeon|dual|zmemw16].lan.uk hosts
on a network do i only run a server on one host or on all? i suspect one
is the answer
a thought occurs that this is the -server field, so if i run
jcgrid-server on xeon.lan.uk -  if i then run server on other hosts, do
i need
something along lines of
-server xeon.lan.uk or export JCGRID_SERVER_NAME=xeon.lan.uk
where does the rest of it "jcgrid.cmd.povray.JCGridServer" come from
or is it specific for your setup?
ok i have three machines for doing this, povray available on all
xeon.lan.uk - best box
amd32.lan.uk
zmemw16.lan.uk
server on xeon or all?
client or clients on each ?
workers on all?
any chance of a structure diagram for such a setup, useful for a
tutorial :-)
slightly confused set of questions i'm afraid, but i'm slightly confused
as to the topology(sp?)/structure of this
stephen
Date: 1 Jun 2004 10:24:39
Message: <40bc91a7@news.povray.org>
> fix the xeon :-)
> xeon now ok
> second is
> session name boxes
This could be related to your system default font (larger than mine I
guess). Anyway the default window size should be larger and it will be
larger in next release. BTW, you can resize the window.
This one looks like a bug, I will check.
> looking better
"-server" is an option of the java virtual machine. It should give some
performace advantage for server-like applications. It is an
optimization, it is not strictly required.
"org.hmedns.dade.jcgrid.cmd.povray.JCGridServer" is the name of the
class (a file with Java code) to run (if you unzip the jcgrid.jar
archive, you will find a file named
org/homedns/dade/jcgrid/cmd/povray/JCGridServer.class")
The two keywords are not related.
No, it is just the name of a file (it is the java way to name packages).
It is not related to the workstation where you run the software.
> amd32.lan.uk
> zmemw16.lan.uk
> workers on all?
I suggest you:
- One Server on Xeon;
- Workers on all (don't forget to set JCGRID_WOKER_CPU=4 on dual xeon
and JCGRID_WOKER_CPU=2 on dual PentiumIII);
- Clients on any host where you want to use JCGrid/POVRay for rendering.
Run a client and the rendering will be splitted among the 7 workers
available on your grid.
Let me know if it is still unclear.
David Bucciarelli
Pisa - Italy
