POV-Ray : Newsgroups : povray.general : Mesh-Modifying-Macros released... Server Time
28 Dec 2025 14:24:07 EST (-0500)
  Mesh-Modifying-Macros released... (Message 1 to 5 of 5)
Subject: Mesh-Modifying-Macros released...
Date: 14 Jan 2003 20:22:45
Message: <3e24b7e5$1@news.povray.org>
...and I'd like to hear some comments, if anyone actually
has use for it. Never sure about that last part... :-)
Before people begin shouting: the macros are meant to
do some basic stuff with an array of two dimensions, filled
with vertices. It doesn't generate that one, but builds upon
it, by generating the required triangles, calculating the normals,
do some little modifying (hence the name).
So, basically you take your rectangular grid of vertices,
and the macros work with it.
Anyways, even if no one has use for it, enjoy!
Tim
PS: The link is in my signature...
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Mesh-Modifying-Macros released...
Date: 15 Jan 2003 10:03:06
Message: <3e25782a$1@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3e24b7e5$1@news.povray.org...
Very cool stuff. The docs are quite nice. My suggestions for a future
release would be optimized quad splitting and a few examples of array
creation for those who might not immediately grasp the concept.
One very small problem is that your macros write out unneeded duplicate
vertices for cylinder and torus shaped meshes. Not a big deal, but it adds
just a small amount to the parse time.
 -Shay
Date: 15 Jan 2003 11:37:10
Message: <3e258e36$1@news.povray.org>
That's a side-effect I can't easily handle. If that information had to be
inserted somewhere into the array, it wouldn't be as easy of use as it is.
IMHO
its a minor drawback, but I was thinking about implementing some macro which
will just join a side (for a cylinder, for example), so that one does not
need to
have the vertices twice.
And, as mentioned somewhere in the docs, the idea was to have something very
easy to visualize without a graphic interface, and at some point I want to
implement
UV-Mapping. It's easier to imagine if you've got your rectangular grid and
work
with that, at least for me.
Thanks.
I understood the part of "grasping the concept", but that quad-splitting...
I've
implemented it so that the shorter cross-section will be used for the
triangulation,
instead of an always lowerleft-upperright (or reverse) splitting. What's
wrong
with that?
Tim Nikias
Date: 15 Jan 2003 12:40:01
Message: <3e259cf1$1@news.povray.org>
news:3e258e36$1@news.povray.org...
: Tim Nikias:
:   That's a side-effect I can't easily handle. If that
:   information had to be inserted somewhere into the
:   array, it wouldn't be as easy of use as it is.
You wouldn't need the information in the array, but you would need a switch
perameter in each macro. I agree with you that this may very well be less
intuitive for the user.
: Tim Nikias:
:   but that quad-splitting...
:   I've implemented it so that the shorter cross-section
:   will be used for the triangulation, instead of an always
:   lowerleft-upperright (or reverse) splitting. What's
:   wrong with that?
Sorry, missed it. A slightly better way of doing it might be to select the
dividing line which is closest to a point representing the average of the
four corners. I doubt it would make a noticeable difference, however.
 -Shay
Date: 15 Jan 2003 13:19:23
Message: <3e25a62b@news.povray.org>
For that matter, I could easily just create four instead of two triangles
and
use the average of the four corners as a vertex for each of the four
triangles. This way of looking for closest connection I found somewhere
on the net, and when using smooth_triangles, most issues with this quad-
splitting are solved anyways.
If you've got any other suggestions, I'm open for almost anything,
and you know where to find me...
Tim
Tim Nikias
