POV-Ray : Newsgroups : povray.general : sphere sweeps and render time Server Time
22 Apr 2026 03:34:29 EDT (-0400)
  sphere sweeps and render time (Message 1 to 10 of 12)
Subject: sphere sweeps and render time
Date: 7 Dec 2002 13:01:48
Message: <3df2378c$1@news.povray.org>
Hello all. I'm working on a little model of a lamp which uses sphere_sweeps.
Getting very low PPS in the first part of the image where the sphere sweep
isn't visible, i began to wonder why this is so. If I take the sphere sweep
out, render time increases a lot. the sphere sweep and texture is as follows
if it helps/matters, if not, ignore the code. I am using radiosity, but the
slow down occurs with or without radiosity. Please note if you try rendering
this, i use z as the "up" vector.
With the sphere_sweep i get about 30 PPS and without it I get 340 PPS, and
this is where there is nothing but a blue wall with just a simple pigment
{ rgb <0.05, 0.30, 0.80> }. So my question is, if its not apparent yet, why
does a sphere sweep affect the render time so much even when it is not
currently rendering any part of the sphere_sweep? Is there any way to reduce
this affect (i'm no master pov'er, i don't know such things)
thankyou,
ross
/* texture */
#declare shiney_black_iron =
    granite
    color_map {
      [0.0 rgb <0, 0, 0>]
      [0.4 rgb <.1, .1, .1>]
      [0.5 rgb <.3, .3, .3>]
      [0.6 rgb <.2, .2, .2>]
      [1.0 rgb <.05, .05, .05>]
  finish {
    phong 0.38
    phong_size 34
    specular 0.35
    reflection 0.15
  normal {
    granite
  scale .4
#declare lamp_post =
sphere_sweep {
  cubic_spline
  51
  <0.00 , 0.00 , 5.00>, .1
  <0.00 , 0.00 , 3.25>, .1
  /* crimp 1 */
  <1.00 , 0.00 , 3.00>, .1
  <0.30 , 0.30 , 2.95>, .1
  <0.00 , 1.00 , 2.90>, .1
  <-0.30, 0.30 , 2.85>, .1
  <-1.00, 0.00 , 2.80>, .1
  <-0.30, -0.30, 2.75>, .1
  <0.00 , -1.00, 2.70>, .1
  <0.30 , -0.30, 2.65>, .1
  <1.00 , 0.00 , 2.60>, .1
  /* small straightaway */
  <0.00 , 0.00 , 2.55>, .1
  /* crimp 2 */
  <0.00 , 0.00 , 1.60>, .1
  <1.00 , 0.00 , 1.60>, .1
  <0.30 , 0.30 , 1.55>, .1
  <0.00 , 1.00 , 1.50>, .1
  <-0.30, 0.30 , 1.45>, .1
  <-1.00, 0.00 , 1.40>, .1
  <-0.30, -0.30, 1.35>, .1
  <0.00 , -1.00, 1.30>, .1
  <0.30 , -0.30, 1.35>, .1
  <1.00 , 0.00 , 1.30>, .1
  /* long straightaway */
  <0.00 , 0.00 , 1.00>, .1
  <0.00 , 0.00 , -2.0>, .1
  <0.00 , 0.00 , -2.95>, .1
  /* base */
  <.75, 0, -2.95>, .1
  <1.5, 0, -3.0>, .1
  <0, 1.5, -3.0>, .1
  <-1.5, 0, -3.0>, .1
  <0, -1.5, -3.0>, .1
  <1.45, 0, -2.9>, .1
  <0, 1.45, -2.9>, .1
  <-1.45, 0, -2.9>, .1
  <0, -1.45, -2.9>, .1
  <1.4, 0, -2.8>, .1
  <0, 1.4, -2.8>, .1
  <-1.4, 0, -2.8>, .1
  <0, -1.4, -2.8>, .1
  <1.35, 0, -2.7>, .1
  <0, 1.35, -2.7>, .1
  <-1.35, 0, -2.7>, .1
  <0, -1.35, -2.7>, .1
  <1.3, 0, -2.6>, .1
  <0, 1.3, -2.6>, .1
  <-1.3, 0, -2.6>, .1
  <0, -1.3, -2.6>, .1
  <1.25, 0, -2.5>, .1
  <0, 1.25, -2.5>, .1
  <-1.25, 0, -2.5>, .1
  <0, -1.25, -2.5>, .1
  translate <0, 0, 3>          /* top of this object is at 10, bottom is at
0 */
Subject: Re: sphere sweeps and render time
Date: 7 Dec 2002 13:31:20
Message: <chrishuff-51A024.13281607122002@netplex.aussie.org>
In article <3df2378c$1@news.povray.org>,
Well, a sphere sweep is a difficult object to bound, POV probably just
doesn't know the sweep is not visible. Sphere sweeps are just pretty
slow, though I think there is work being done on speeding them up, with
better bounding and other optimizations.
http://tag.povray.org/
Date: 7 Dec 2002 13:34:58
Message: <3DF23FB7.F7D16E4D@pacbell.net>
It might even render faster with automatic bounding turned off.
Ken Tyler
Date: 7 Dec 2002 14:01:47
Message: <3df2459b@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3DF23FB7.F7D16E4D@pacbell.net...
and
pigment
yet, why
reduce
> Ken Tyler
I don't really know what this entails. i just read how i can turn it off,
but then do i have to manually set bounded_by for the sphere_sweep? or do I
just leave bounding off alltogether? Thankyou all for the info.
sphere_sweeps are fun, too bad they take a bit of time to render :)
ross
Date: 7 Dec 2002 14:10:56
Message: <3DF24823.843D8DED@pacbell.net>
Just leave it off and see if the render time decreases. Automatic bounding
is useful for most scenes and helps decrease render times. However, in some
cases where the geometry is very complex, it may actually increase the render
times and it helps to turn it off completely when this happens. You may also
try manual bounding but you may have limited success if your object is too
complex to bound by hand.
Ken Tyler
Date: 7 Dec 2002 16:09:08
Message: <chrishuff-A597C2.16060207122002@netplex.aussie.org>
In article <3DF23FB7.F7D16E4D@pacbell.net>, Ken <tyl### [at] pacbellnet>
Depends on the exact situation...if it tests for the bounding for every
pixel or nearly every pixel, turning the bounding off will not have any
effect on the sweep tests, but will get rid of the bounds tests, making
things slightly faster. Probably not enough to matter though.
Date: 7 Dec 2002 18:42:05
Message: <3df2874d$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
aye. I tried turning bounding off and making my own (simple) bounding box. I
only waited for the first couple lines to make comparisons, but the
differences were negligable it seemed. They're all slow :) I'll be sure to
post my lamp to p.b.i since this is my first 4+ hour render (still going at
4.25 hours) in a long time. besides, its all hand coded which is also a
first for a somewhat complete object. its nothing special, but i just feel
like posting something!
thanks for the help christopher and ken!
ross.
Date: 7 Dec 2002 19:07:15
Message: <3df28d33@news.povray.org>
Please post it! IMHO it's way too silent at pbi and pba! I post almost all
the crap I'm producing here heheheheheh :-)
Apache
"Ross Litscher" <lit### [at] osuedu> wrote in message
news:3df2874d$1@news.povray.org...
I
at
> ross.
Date: 7 Dec 2002 19:36:42
Message: <3df2941a$1@news.povray.org>
its still rendering! oh no! and i noticed a control point mistake in the
sphere sweep! ack!
ross
"Apache" <apa### [at] yahoocom> wrote in message
news:3df28d33@news.povray.org...
> Regards,
> Apache
every
any
making
box.
> I
to
> at
feel
> > ross.
Date: 7 Dec 2002 23:36:17
Message: <3df2cc41$1@news.povray.org>
ah, its nice when outlook express actually has more messages from the
newsgroup to search through. I just found the "sphere_sweep woes" post from
september. thanks for helping me regardless of redundancy.
guess i'll be doing my searches on the web interface from now on. much more
thorough!
