POV-Ray : Newsgroups : povray.general : Color help... Server Time
28 Nov 2025 05:42:18 EST (-0500)
  Color help... (Message 1 to 10 of 22)
Subject: Color help...
Date: 14 Jul 2001 21:31:16
Message: <3b50f264@news.povray.org>
Does anyone know how I can make a texture vary depending on the
angle from which it is viewed?  I've thought about using a radial, but that
isn't quite what I want...  As in, the angle of incidence between the
intersecting ray and the surface normal would act as a sort of index
into a pigment map.
...Chambers
Subject: Re: Color help...
Date: 14 Jul 2001 21:35:53
Message: <3b50f379@news.povray.org>
Ben Chambers <bdc### [at] hotmailcom> wrote:
: Does anyone know how I can make a texture vary depending on the
: angle from which it is viewed?  I've thought about using a radial, but that
: isn't quite what I want...  As in, the angle of incidence between the
: intersecting ray and the surface normal would act as a sort of index
: into a pigment map.
  AFAIK patterns do not get info about the incoming ray nor the normal
vector, so they can't produce a pattern depending on them. Not even a function
pattern can do this.
  I don't know how the shaders of the povman patch work, but that might be
one solution.
Date: 15 Jul 2001 01:19:31
Message: <3B5152F4.5ACF52FA@aol.com>
Perhaps if you built your own mesh to describe the surface you could apply a
color calculation to individual triangles.
> into a pigment map.
> ...Chambers
Date: 15 Jul 2001 01:33:27
Message: <3b512b27$1@news.povray.org>
Ben Chambers wrote in message <3b50f264@news.povray.org>...
Sounds like what you want is anisotropic shading.  Check out RenderMan
shaders and the POV-MAN unofficial version of POV-Ray.
Mark
Date: 15 Jul 2001 13:14:34
Message: <3b51cf7a@news.povray.org>
Unfortunately, then the colors would be fixed.  What I want is similar to
those cars that change color based on the angle from which you view them.
Its not a real high priority for me right now, so I'm not too sure I want to
try out POV-Man for it yet, but when I _do_ really need it now I know
where to go.
...Chambers
jim charter <jrc### [at] aolcom> wrote in message
news:3B5152F4.5ACF52FA@aol.com...
a
that
> > into a pigment map.
> > ...Chambers
Date: 15 Jul 2001 16:29:07
Message: <3B51FEDE.2FFD6732@erols.com>
Ben Chambers wrote:
> > > but that isn't quite what I want...  As in, the angle of incidence
> > > between the intersecting ray and the surface normal would act as a
> > > sort of index into a pigment map.
> > apply a color calculation to individual triangles.
> to those cars that change color based on the angle from which you view
> them. Its not a real high priority for me right now, so I'm not too
> sure I want to try out POV-Man for it yet, but when I _do_ really need
> it now I know where to go.
If the colors were calculated based on the current camera settings,
and the .INC file called only after the camera settings were made,
then it should be no difficulty animating it.
John
ICQ: 46085459
Date: 16 Jul 2001 02:34:36
Message: <3b528afc@news.povray.org>
But what if it showed up in a reflection or a refraction?  Then the
rays wouldn't even be coming from the camera.  Of course, you
could work around this (avoid reflections and refractions, or render
the image in two portions with and without the reflection, and other
such tricks) but it would be easier to give the texture information on
the angle of incidence (is that the correct term?).
...Chambers
John VanSickle <van### [at] erolscom> wrote in message
news:3B51FEDE.2FFD6732@erols.com...
> Regards,
> John
Date: 16 Jul 2001 09:01:33
Message: <3B52E6F8.4D86963@reading.ac.uk>
The way I'd have done it with a POVMan shader would be something like
#declare incoming = pigment {
  shader{
    shader_file "incoming.slp"
    "falloff" 5
    shadow_type shader_shadow
sphere { 0,5
    pigment_pattern { incoming }
    pigment_map {
      [0.5 granite colour_map {[0 rgb x][1 rgb y]} ]
      [0.5 bozo colour_map {[0 rgb z][1 rgb 1]} ]
  finish { ambient 1 diffuse 0 specular 0 metallic }
where the shader just returns the dot product between I (the incoming
ray) and N (the surface normal).
Unfortunately, POVMan seems to count the pigment_pattern interior as a
non-object pigment definition so neither I nor N are defined. I'm having
to assume this from the fact that it does not work; usually it warns you
about an incomplete initialization (when a shader is used in a warp, for
instance) but in this case the pigment_pattern simply returns a value of
1 without any warnings.
If anyone can see another way of doing it I would also like to know ...
Bye for now,
	Mike Andrews.
> ...Chambers
> > Regards,
> > John
Date: 16 Jul 2001 09:46:30
Message: <3b52f036@news.povray.org>
"Michael Andrews" <M.C### [at] readingacuk> wrote in message
news:3B5### [at] readingacuk...
What I just thought of was to use the MegaPOV angle dependent reflection in
a two layered texture, trick being to use opposing min and max color
vectors.  Maybe that has already been mentioned, if so I didn't notice.
Bob H.
Date: 16 Jul 2001 10:08:36
Message: <3b52f564@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message
news:3b52f036@news.povray.org...
in
Okay, maybe that wasn't relating to the previous message reply so much but I
just gave it a try to see how it would look.  It's close to that kind of car
paint, since cars do reflect it's about all it might pass for becuase it
certainly isn't a ny sort of angle dependent pigment.
sphere {0,1
 pigment {rgb .25}
  finish {
        reflection_type 0 reflection_min <.1,0,0> reflection_max <1,0,0>
 pigment {rgbt .75}
  finish {
        reflection_type 0 reflection_min <0,0,1> reflection_max <0,0,.1>
Bob H.
