POV-Ray : Newsgroups : povray.general : Where's that rotation advice? Server Time
25 Apr 2026 00:58:06 EDT (-0400)
  Where's that rotation advice? (Message 1 to 10 of 13)
Subject: Where's that rotation advice?
Date: 21 Jan 2001 17:54:58
Message: <3a6b68c2@news.povray.org>
I thought I saw somewhere around here recently a post where someone got
advice on how to find the
rotate <xang,yang,zang>
to make vector <x1,y1,z1> parallel to vector <x2,y2,z2>
but I'm sorry I cannot find it.
Subject: Re: Where's that rotation advice?
Date: 21 Jan 2001 18:10:15
Message: <3vqm6tgnhr038d9bngvtu8q9go1hcg0tfp@4ax.com>
On Sun, 21 Jan 2001 17:53:45 -0500 "Greg M. Johnson"
  Greg, the articles you are looking for may be in p.advanced-users,
posted from 09-Jan-2001 to 13-Jan-2001. There is more than one thread
that pertains to that topic but you may have to hunt through ambiguous
Subject lines.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 21 Jan 2001 18:55:45
Message: <3A6B76C9.1D38516@online.no>
In news://news.povray.org/povray.advanced-users
I found these threads:
08. Sept. 2000, matrix help....
news://news.povray.org/39B93D2B.781F84C5%40psu.edu
23. Nov. 2000, Rotate object to lie along a vector
news://news.povray.org/3a1c61d8%40news.povray.org
If the answers you seek are not within these threads,
then I can try to help if you want me to.
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Date: 22 Jan 2001 09:52:25
Message: <3A6C47CE.59086ECB@my-dejanews.com>
Thanks all.  Rune actually answered this question in July. Because it was
so useful, I'm pasting it here again:
// By Rune Johansen, Thu, 6 Jul 2000
// Perpendiculize will adjust the vector V1
// so that it is perpendicular to the vector V2.
// The input is V1 and V2, and the macro returns
// the adjusted version of V1.
#macro Perpendiculize (V1,V2) // by Rune S. Johansen
   vnormalize(vcross(vcross(V2,V1),V2))
// FindAngle will find the angle between V1 and V2.
// The third parameter "About" is a vector which must be
// perpendicular to both V1 and V2. If the rotation from
// V1 to V2 about "About" is negative, the returned angle
// is negative. ( When you look in the direction of "About"
// clockwise is negative and anticlockwise is positive. )
// If you set "about" to <0,0,0> the returned angle will
// always be positive (or zero).
#macro FindAngle (V1,V2,About)
   degrees(acos(vdot(vnormalize(V1),vnormalize(V2))))
   *(vdot(About,vcross(V1,V2))<0?-1:1)
// Given 2 vectors, a vector for the X direction
// (similar to the 1st - 3rd number in a matrix),
// and one for the Y direction (similar to the
// 4th - 6th number in a matrix), Vectors2Rotate will
// return a rotation vector which will transform an
// object in the same way as a matrix using the
// vectors would do. VectorX and VectorY must be
// perpendicular to each other.
#macro Vectors2Rotate (VectorX,VectorY) // by Rune S. Johansen
   #local RotZ = FindAngle(x,<VectorX.x,VectorX.y,0>,z);
   #local RotY = FindAngle(x,vrotate(VectorX,-RotZ*z),y);
   #local RotX = FindAngle(vrotate(y,<0,RotY,RotZ>),VectorY,VectorX);
   <RotX,RotY,RotZ>
Date: 22 Jan 2001 12:08:30
Message: <3a6c690e@news.povray.org>
I see you found it... :)
Just curious - what are you going to use it for?
Rune
\ Include files, tutorials, 3D images, raytracing jokes,
/ The POV Desktop Theme, and The POV-Ray Logo Contest can
\ all be found at http://rsj.mobilixnet.dk (updated January 6)
/ Also visit http://www.povrayusers.org
Date: 22 Jan 2001 13:21:51
Message: <3A6C78D9.3E7AC508@my-dejanews.com>
Going to a pure IK leg in a new character, following some of the advice
you gave H.E.Day last year, and keeping true FK construction.  See start
of code in p.b.i.
But frankly at this hour I'm still not out of woods, and when I looked
at your Vectors2Rotate  I saw it wasn't what I was looking for....
I used FindKnee successfully to find the knee. But I *do not* want to
simply make my thigh a cylinder from hip point to knee point. I want a
transform{} to be placed on an object{thigh}.
Date: 22 Jan 2001 16:41:47
Message: <3a6ca91b@news.povray.org>
> of the advice you gave H.E.Day last year, and keeping
I still don't see why you stick to that FK idea... :)
Anyway, why does the output have to be rotation vectors? Why not transforms?
Transforms are much easier to handle...
> when I looked at your Vectors2Rotate  I saw it wasn't
Not directly anyway...
> *do not* want to simply make my thigh a cylinder from
> hip point to knee point. I want a transform{} to be
And that's what I explained in the post for H.E.Day. But maybe that's
exactly what you meant.
Rune
Date: 22 Jan 2001 17:13:18
Message: <3A6CAF18.5B9452FA@my-dejanews.com>
Thanks, am using transforms.  I never did figure out how to get the operations
that happen in jvs' Reorient macro to happen inside a transform. I instead had
to redefine my shinobject with the Reorient macro.
I just sacrificed a little elegance in my code by using:
  $rshinobj=object{rshinobj Reorient(rankpt-rkneept,rtemprankpt-rtempkneept)}
  $rshintrans= transform{ translate rtempkneept}
when I was hoping for:
  $rshintrans= transform{ rotate An_UnAttainableVector  translate rtempkneept}
But thanks I now have a working system, with lifting heel and rotatable
head,neck, hip,lumbar,ribcage.  Will show anims eventually.
While we're talking, what exactly do you use to vary your variables in an anim?
exactly what kind of spline, etc.?
Thanks.
Date: 23 Jan 2001 07:52:15
Message: <3A6D7D19.99613415@my-dejanews.com>
Here's how:
#macro Oritransform(Axis1,Axis2)
      #declare vX1=vnormalize(Axis1);
      #declare vX2=vnormalize(Axis2);
      #declare vY=vnormalize(vcross(vX1,vX2));
      #declare vZ1=vnormalize(vcross(vX1,vY));
      #declare vZ2=vnormalize(vcross(vX2,vY));
      transform{
        matrix < vX1.x, vY.x,vZ1.x, vX1.y,vY.y,vZ1.y, vX1.z,vY.z, vZ1.z, 0,0,0 >
        matrix < vX2.x,vX2.y,vX2.z,  vY.x,vY.y, vY.z, vZ2.x,vZ2.y,vZ2.z, 0,0,0 >
> I instead had
Date: 23 Jan 2001 09:20:33
Message: <3a6d9331@news.povray.org>
> variables in an anim? exactly what kind of spline, etc.?
I use cubic_splines. This works well for me since I've never used rotation
vectors to define poses, but direction vectors instead.
(Personally I have always disliked specifying poses with rotation_vectors. I
find it difficult to find the right combination of x, y, and z-rotation
required to align a limp as I want it.)
Rune
