POV-Ray : Newsgroups : povray.general : Memory consuming...? Server Time
14 Jun 2026 23:17:38 EDT (-0400)
  Memory consuming...? (Message 1 to 10 of 14)
Subject: Memory consuming...?
Date: 29 May 2002 12:02:13
Message: <3CF4FB72.D0F9731D@gmx.de>
I've been tracing lots of animations lately, and after
some time my computer starts stuttering, WINAMP
freaks out, my internet-connection zaps out...
I'm wondering if this has got anything to do with
the reported bug of POV 3.5s memory-handling,
and want to do some checks.
Anyone know a good, easy to use freeware programm for
Win98, so that I can check memory usage?
Tim Nikias
Email: Tim### [at] gmxde
Subject: Re: Memory consuming...?
Date: 29 May 2002 13:05:16
Message: <3cf50a4c$1@news.povray.org>
In article <3CF4FB72.D0F9731D@gmx.de> , Tim Nikias <tim### [at] gmxde>  wrote:
Which bug???  I am not aware of any such bug report and I am sure there isn't
any problem with the memory handling either ... so what is the purpose of your
message?
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 29 May 2002 14:23:04
Message: <3cf51c88@news.povray.org>
Try Start -> Programs -> Accessories -> System Tools -> System Monitor, and
add the charts you want.  It's a pretty powerful tool.
- Kevin R.
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3CF4FB72.D0F9731D@gmx.de...
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 29 May 2002 16:58:56
Message: <3CF540FE.6B43B2F5@gmx.de>
No offense!
I read several reports stating that memory usage
increased during animations/interrupted renders,
as if POV-Ray wasn't making all memory available
again after the termination of a render.
I'm not sure of the status of those reports, if
they were confirmed officially, or if something
else might be causing the memory increase.
I just noticed that when POV-Ray is tracing
several scene as animations, my computer at
some point gets sloppy and sometimes finally
crashes.
The purpose is to get some means to actually
check what is going on. Please note that
this post was put in "general", not
"beta-test" and was asking for freeware
programs to monitor memory usage.
I'm aware that you are actually a little "afraid"
of rumours, so I'll be less POV-offensive
the next time, okay? ;)
> message?
>     Thorsten
Tim Nikias
Date: 29 May 2002 17:28:18
Message: <3cf547f2@news.povray.org>
In article <3CF540FE.6B43B2F5@gmx.de> , Tim Nikias <tim### [at] gmxde>  wrote:
Those have been explained a very long time ago in p-beta-test:  Some people
observed memory use increasing by a few KB with each render using the system
monitor, which is exactly the size needed to store the statistics and other
message output.  So there is no problem and never was.
I should point out that the system monitor just like any other external tools
are completely unsuitable to measure any memory usage in a correct manner.
There is no way to get the correct information without access to the source
code and linking it with libraries suitable for that task or enabling the
POV-Ray internal memory tracking.  All other measurements gained with external
methods could just be replaced by random data which would say as "much"!
> of rumors, so I'll be less POV-offensive
Well, you already responded to a rumor so I suppose you now know why they are
a problem :-)  Even if they were explained long ago as being false and
baseless someone will have missed that explanation...
    Thorsten
Thorsten Froehlich
Date: 29 May 2002 18:05:59
Message: <3CF550B4.1E0D633F@gmx.de>
Yeah, like me... ;)
Tim Nikias
Date: 30 May 2002 08:16:13
Message: <3cf6180d@news.povray.org>
In article <3cf612bb$1@news.povray.org> , "Gilles Tran" <tra### [at] inapginrafr>
> Memory problems that became apparent in animations have been reported before
> Change 1512 on 2002/04/14 by chrisc@lilliput
>   Fix pigment_pattern memory leak reported in
>     http://news.povray.org/3cb3217f$1@news.povray.org
> Change 1300 on 2001/12/30 by thorsten@host27
>   Should fix the JPEG image reading memory leak
> http://news.povray.org/3be2ef0d@news.povray.org
> (note: this one was fixed, apparently...)
These are not those reports I have been referring to or which this thread is
about.  There was a long thread in p.beta-test (I don't feel like searching
for it now) that was about someone insisting there was a problem while there
was not.
> A last one was reported recently but not confirmed.
> http://news.povray.org/3CDFFDB3.F24905A9@gmx.de
As explained, looking at the system monitor is absolutely unsuitable to check
memory usage...
    Thorsten
Thorsten Froehlich
Date: 30 May 2002 09:02:13
Message: <3CF622D4.238E3ABA@gmx.de>
> memory usage...
I have not been able to supply a test scene for this until now so no need
to have much fuzz about it, but if the harddisk starts trashing after 250
frames despite 256 Mb RAM this IMO is a suitable indication for memory
consumption.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 30 May 2002 09:38:28
Message: <3cf62b54@news.povray.org>
In article <3CF622D4.238E3ABA@gmx.de> , Christoph Hormann
>> memory usage...
> consumption.
Well, how many messages are in the message window by then?  I suppose many.
And they are likely all over the application memory space which suggests a lot
of memory fragmentation.  Consequently after each frame there can a little
memory that is no use as it is a leftover fragment when rendering the next
frame which uses a similar memory allocation pattern.
The effect many not be as visible when rendering different scenes, but it is
simply in the nature of memory allocation.  Just like your harddisk memory
gets fragmented, and even worse, with memory there is no way to "defragment"
it other than freeing all memory allocated, which is essentially restarting
the program ... essentially you are chasing ghosts here.
    Thorsten
e-mail: tho### [at] trfde
Date: 30 May 2002 13:20:49
Message: <3CF65F5F.C315AAFC@gmx.de>
This note got me thinking. Is there a way to have POV-Ray
(in Windows) flush the message-stream? Perhaps that's whats
causing the most trouble for Windows users...
And I mean something different than restarting POV manually.
Something automatic would be helpful, I guess...
Suggestions?
Tim Nikias
