POV-Ray : Newsgroups : povray.general : Needed: up & down in normals! Server Time
25 Apr 2026 04:44:47 EDT (-0400)
  Needed: up & down in normals! (Message 1 to 10 of 11)
Subject: Needed: up & down in normals!
Date: 15 Dec 2000 08:24:14
Message: <3A3A1A19.B90A2BF0@my-dejanews.com>
I have a building texture for a city where I have a texture map:
   gradient y
    texture_map{
         [0.00 Bricktex]
         [0.35 Bricktex]
         [0.35 BlackGlasstex]
         [0.65 BlackGlasstex]
         [0.65 Bricktex]
         [1.00 Bricktex]
         scale 1/10
The Bricktex defintion includes a normal{bumps scale 0.01} .
I want the BlackGlasstex definition to have its normal be "inny",
"down", or  "flat & depressed"  **RELATIVE** to the bricks.  How do I do
this?
I think it would be wonderful if I could simply say normal{down} .
Subject: Re: Needed: up & down in normals!
Date: 15 Dec 2000 08:46:58
Message: <3A3A213E.EDA2A82D@inapg.inra.fr>
> this?
It may not be what you're looking for, but specifying negative values for
the bump_size parameter inverts the apparence of the normal.
normal{bumps bump_size -0.5}
G.
Date: 15 Dec 2000 09:30:14
Message: <3A3A2AEB.92A70DA8@gmx.de>
> this?
I'm not sure if i understand what you mean, but have you tried slope_maps?
Furthermore remember that normal{} only changes the normal vector but not
the geometry.
Date: 15 Dec 2000 13:23:32
Message: <3A3A6040.9A128B84@my-dejanews.com>
> the geometry.
Consider this analogy.
Many people might like to use the wrinkles pattern to describe a color map,
where one might ascribe the color "black" to where the function is 0, and
"white" where the function is 1.   Some other people might want an all-black
image. Instead of going through a color_map, they are allowed so simply say
pigment{Black}.  There are situations, mine most acute, where it would be
wonderful to say "normal{down}".  Using an analogy comparing an unideal normal
nomenclature  to pigment, we'd be forcing someone to say:
    pigment{
        gradient y  //or wrinkles
        pigment_map{
            [0 Black]
            [1 Black]
Date: 15 Dec 2000 13:54:48
Message: <chrishuff-A7C4B7.13554915122000@news.povray.org>
In article <3A3A6040.9A128B84@my-dejanews.com>,
How would this be useful at all?
I suspect that you do not understand how the normal feature works. The
normal to a surface at each point is a vector with a length of 1 that is
perpendicular to the surface at that point. The "normal" feature
generally takes a pattern, figures out how it is changing at that point,
and modifies the calculated normal using this information. The result is
that it can simulate the shading of bumps without actually moving the
surface. It does not define "height", and "normal {down}" doesn't make
much sense, and I certainly don't see any use for it...
It sounds like you are looking for the slope_map feature, which can do
some of what you seem to want. However, this was suggested before and
you ignored it, what doesn't it do that you want? If you need the actual
shape of the surface to change, try using CSG to actually model those
situations, or maybe use a height_field object to do the job.
Christopher James Huff
Date: 15 Dec 2000 14:55:03
Message: <3A3A75AB.C699C2C4@my-dejanews.com>
It's possible.
Aren't the bright spots "up" and the dark ones "down" ?
I'd really like to have, as I said,
    texture{
        gradient y
        texture_map{
            [ n1    Texture_1]
            [ n2    Texture_1]
            [ n3    Texture_2]
            [ n4    Texture_2]
Where Texture_1 contains normal{bumps}.
If I use a slope map, I assume I have the following problems:
1. I have to break normal out of the texture_map and instead use pigment_map
and a normal_map: more typing .
2. I'm frequently a adjusting n1,n2,n3.. etc. to get the right look: more
editing in two or three places each time, depending on how I set it up.
3. I don't understand a slope_map when I just want it all to be "down", or
like in the color_map, all black.
   Is the suggestion that I define Texture_2 as:
#declare Texture_2=texture{
    pigment{rgb ....
    finish{ rgb ...
    normal {
      gradient x
      slope_map {
      [0   <-1, 0>]
      [1   <-1,0>]
Hopefully annoying only by my ignorance and not by my disrespect or failure
to RTFM,
greg.
Date: 15 Dec 2000 15:52:25
Message: <chrishuff-538756.15532515122000@news.povray.org>
In article <3A3A75AB.C699C2C4@my-dejanews.com>,
Nope. The bright spots are facing the light source more, the darker ones
are facing away from it. Try using multiple light sources, each with a
different color, and a highlight in your texture.
Or were you talking about the "brightness" of the pattern? Well, the
answer is still no. Only the change in the pattern matters. For example,
if you use a "checker" pattern as a normal, only areas along the edges
of the pattern will have any effect, the "interior" of the cubes will be
constant, whether they are "black" or "white" cubes. It doesn't modify
the height of the surface, it just modifies the direction it considers
"up" at each point. Since the "low" parts will have the same "up"
direction as the "high" parts, the lighting will be the same for them.
> pigment_map and a normal_map: more typing .
Yes, it's more typing, but that is how you do it. However, I suspect
slope_map won't do what you want, because you seem to need large, sharp
variations in height. You need to actually model the shapes in your
scene.
Just declare the slope_map and use it in all the textures if you have it
multiple times.
> or like in the color_map, all black.
Well, that doesn't really mean anything...normals aren't "up" or "down".
Again, the normal feature is just a way to simulate the effects of small
surface variations. You need real geometry in your scene.
Date: 15 Dec 2000 16:24:58
Message: <3A3A8C2A.9712E1E2@gmx.de>
>     texture{
>         gradient y
>         texture_map{
>             [ n1    Texture_1]
>             [ n2    Texture_1]
>             [ n3    Texture_2]
>             [ n4    Texture_2]
>     pigment{rgb ....
>     finish{ rgb ...
>     normal {
>       gradient x
>       slope_map {
>       [0   <-1, 0>]
>       [1   <-1,0>]
I'm no expert in this stuff, but i think in this case it would suffice to
declare one normal like:
    normal{
        gradient y
        normal_map{
            [ n1 bumps 0]
            [ n2 bumps 0]
            [ n3 bumps 1]
            [ n4 bumps 1]
And use it in all textures of the texture_map.
Date: 18 Dec 2000 08:27:21
Message: <3a3e10b9@news.povray.org>
Greg M. Johnson <gre### [at] my-dejanewscom> wrote:
: 3. I don't understand a slope_map
  Then you should learn it, don't you think?
: when I just want it all to be "down"
  That doesn't make any sense.
  How can a normal be "all down"? What does that mean?
  A slope map can have positive and negative slopes (or 0 slopes for that
matter).
  There's no such thing as "slope which is down" or "slope which is up".
Slopes do not express the height of anything. Slopes express the change
in height. There's a difference there.
  A negative slope means that the surface is "going down". It doesn't define
the actual height of the surface.
  If you want a normal pattern at a constant height, then don't define a
normal pattern at all. Then you'll get an unmodified surface normal.
Date: 20 Dec 2000 14:56:28
Message: <slrn9423nd.i6.ron.parker@fwi.com>
Just don't anyone mention derivatives and we'll be okay.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
