POV-Ray : Newsgroups : povray.general : Request Server Time
25 Apr 2026 15:15:21 EDT (-0400)
  Request (Message 1 to 10 of 18)
Subject: Request
Date: 28 Aug 2000 11:39:27
Message: <39aa87af@news.povray.org>
What I'd like to be in v3.5 (in addition to megapov). I don't know advanced
math, so these functions are mostly convenient stuff I'd like to see.
I'd like a "preview mode", which made all the objects in a scene white, (and
eventually random colors), removed lights, fog, etc.. A option you could
turn on in the INI file maybe?
The ability to use the norwegian "special" characters in the text object.
Easier sin/cos/tan functions like on graphical calculators? I find the use
of inverted tan a bit strange (I heard about radians for the first time at
school last week).
And a request for the Windows version: Longer "drop down menu" (if that's
the name of the thingy you select resolutions from the ini file with), it's
annoying to have to scroll when changing  between resolutions from top and
bottom of the list.
Peter
http://hertel.no/bigone
Subject: Re: Request
Date: 28 Aug 2000 12:10:40
Message: <chrishuff-B89711.11121028082000@news.povray.org>
In article <39aa87af@news.povray.org>, "Peter Hertel" <pet### [at] hertelno>
> white, (and eventually random colors), removed lights, fog, etc.. A
> option you could turn on in the INI file maybe?
This already exists, look at the quality level feature. It is documented
in the manual: section 3.2.6.1 "Quality Settings".
This may be fixed by the Unicode patch in MegaPOV, which might be
included in 3.5.
> the use of inverted tan a bit strange (I heard about radians for the
> first time at school last week).
Easier in what way? I can't imagine a better way to use them...
Christopher James Huff
Date: 28 Aug 2000 12:20:26
Message: <39AA917A.6D9F060@schunter.etc.tu-bs.de>
> bottom of the list.
It's called combobox and on my computer it's 15 entries long which i found quite
enough.  NTL, it shouldn't be a great problem to modify that, but there will be
problems with lower screen resolutions.
I'm not sure but maybe there is a major redesign of the Windows GUI anyway (I
don't know), so this would become obsolete.
Date: 28 Aug 2000 12:23:55
Message: <39AA9261.CF852DE3@geocities.com>
> included in 3.5.
Yes, it would allow for those. And now that I have the time for POV coding
again, I have a good chance of getting my Unicode patch cleaned up enough for
the official team to use. Of course, if there is end-user need for this, then
it might up the chances of it getting in.
Date: 28 Aug 2000 14:12:30
Message: <39AAAB8E.60985C79@yahoo.com>
not only are there quality settings you can put in your ini file, but
you can also use your own variables to set your own settings.  for
example, #declare a variable called MyQuality or something and then use
#if to see what it is set to at various key places in your scene, using
it as a switch to turn features on or off.  There is also the
quick_color keyword which is used to specify a simple color for use in
previews rather than the full texture.
Date: 28 Aug 2000 14:56:37
Message: <39AAB582.8D778BC6@mindspring.com>
Peter Hertel wrote:
> <snip>
> bottom of the list.
You could just change the list itself, so that things you use switch between
frequently are close together on the list.  Just change your quickres.ini file.
Hope that helps.
> Peter
Kevin Jackson-Mead
http://www.mindspring.com/~jacksonmead
Date: 29 Aug 2000 02:23:28
Message: <39AB55A7.8FE62F04@skynet.be>
> included in 3.5.
I'd like to point out that a problem appeared with that patch.
While MegaPov 0.4 used to render well extended chars, MP 0.5A
and your particle patch do it wrong, though differently.
I can post a sample scene, if needed...
Fabien.
Subject: SV: Request
Date: 29 Aug 2000 11:49:17
Message: <39abdb7d@news.povray.org>
Why rotate degrees(etan2(A/B)) instead of rotate etan(A/B)?
I know it's nothing big, and there surely are a reason they are like they
are, I just don't know why.
Peter
Date: 29 Aug 2000 11:49:18
Message: <39abdb7e$1@news.povray.org>
quite
will be
(I
Mine is 20entries long, and I use almost everyone regulary.
In case of a remake, I hope it won't take longer to change resolution, since
I do it very often.
I'd like a way to change the icons too :) To make you own "skin" to the GUI.
Peter
Date: 29 Aug 2000 11:49:20
Message: <39abdb80@news.povray.org>
between
file.
> Hope that helps.
good idea!
Peter
