POV-Ray : Newsgroups : povray.general : Toughts about texturing system Server Time
13 Sep 2025 03:49:15 EDT (-0400)
  Toughts about texturing system (Message 1 to 10 of 39)
Subject: Toughts about texturing system
Date: 3 Oct 2000 07:57:17
Message: <39D9C88D.C0ABE99D@skynet.be>
I recently had some toughts about POV-Ray's texturing system, and tried
to point out some incoherences and suggest some remedies.  Please note
that I'm not whining, or requesting anything.  These are just toughts
for a possible future.  Read it, keep it, throw it, as you feel.
Here's the first of these toughts.
FINISH - Change in material structure
 What's wrong with "finish"* ?  "finish" is at the same hierarchic level
as
"pigment" and "normal", though it works very differently.  "pigment" and
"normal" require a pattern and a map, while "finish" just has some
keywords.
 Of course, "finish" could get some "finish_map", but since, anyway, a
pattern isn't *required*, it's still incoherent with "pigment" and
"normal".
 So, my idea is to put "finish" at the same level as "texture", and
create
a "surface" entity to group both.  Also, this require that, inside the
"finish" statement, finish properties are also grouped into separate
entities.  Given the recent growth of the "finish" content (thanks to
MegaPOV), having all the keywords 'thrown' in a single statement became
annoying.  This would, of course, allow the declaration of the finish
items : finish {reflection {Mirror1} highlights {VeryShiny} ..}
(*note to Warp : I didn't say 'What's wrong with Finnish ?' ;-))
Here is the proposed material structure :
material {
          surface {
                   [pattern - surface_map]
                            [pattern - texture_map]
                            pigment {..}
                            normal {..}
                   finish {
                           [pattern - finish_map]
                           reflection {type .. min .. max .. exponent
                           highlights {phong .. specular .. blinn ..}
                           iridescence {irid .. thickness ..}
                           light {ambient..  brilliance ..}
          interior {
                   refraction {..}
                   media {..}
Subject: Re: Toughts about texturing system
Date: 3 Oct 2000 09:12:24
Message: <39d9db38@news.povray.org>
Hello,
Very well put.
I like your ideas, and agree that the nontrivial complexity inherent to
complete declaration of materials was implemented here-to-fore in a vexing
and insipid manner.
I intend not to bash Pov-Ray, but to state as the growth of the program has
increased, old methods of handling things must be changed.
This vast syntax alteration will cause many incompatibilities, but is
logical relative to the present form.
ian
Fabien Mosen wrote in message <39D9C88D.C0ABE99D@skynet.be>...
>material {
>          surface {
>                   texture {
>                            pigment {..}
>                            normal {..}
>                   finish
>          interior {
>                   refraction {..}
>                   media {..}
Date: 3 Oct 2000 13:01:35
Message: <39da10ef@news.povray.org>
Shudder... I *guess* I could adapt... if it's for the best...
Date: 3 Oct 2000 13:24:52
Message: <39DA155F.AC8F0E0A@skynet.be>
If a change is made towards something that is more logical, it's
easy to get used to it.  "ior" going from "finish" to "interior"
was logical, and no one complained about it.
Fabien.
Date: 3 Oct 2000 15:31:41
Message: <39da341d@news.povray.org>
I like this new structure very much. I've only just come across the need for
a "finish map" (No, not a map of Finland!)
this would solve the problem nicely and is much more logical.
Mick
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:39D9C88D.C0ABE99D@skynet.be...
> as
> keywords.
> "normal".
> create
> material {
>           surface {
>                    texture {
>                             pigment {..}
>                             normal {..}
>                    finish
>           interior {
>                    refraction {..}
>                    media {..}
Date: 3 Oct 2000 18:00:42
Message: <39DA5343.227D2EE3@global2000.net>
This looks like it's more logical than the present syntax.  How about making
it the syntax for POV 4.0, which will be a total rewrite?
Brendan
> as
> keywords.
> "normal".
> create
> material {
>           surface {
>                    texture {
>                             pigment {..}
>                             normal {..}
>                    finish {
>           interior {
>                    refraction {..}
>                    media {..}
Date: 3 Oct 2000 20:08:51
Message: <39da7513$1@news.povray.org>
In article <39da341d@news.povray.org> , "Mick Hazelgrove"
You are aware that you can just use a texture_map, so except for consistency
reasons the current syntax should not limit you, or does it?
       Thorsten
Date: 3 Oct 2000 20:47:23
Message: <39DA7D0F.8790C3F4@pacbell.net>
Logical to whom ?
I did :)
Subject: Re: Thoughts about texturing system
Date: 3 Oct 2000 22:51:58
Message: <39da9b4e@news.povray.org>
How about this? Notice that "map" replaces all the other maps (less typing),
"light" is now "lighting", and that interior has "fading {...}" now. You
like?
material
 surface
  [pattern - map]
  texture
   [pattern - map]
   pigment {..}
   normal {..}
  finish
   [pattern - map]
   reflection {type .. min .. max .. exponent ..}
   lighting {ambient..  brilliance ..}
 interior
  ior
  media {..}
  fading {distance .. power .. color ..}
Date: 4 Oct 2000 02:32:26
Message: <39dacefa@news.povray.org>
Yes I am aware of that but I found that it was quite hard to control. Much
easier if there was one finish for the whole texture.
Mick
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:39da7513$1@news.povray.org...
for
consistency
>        Thorsten
